Old 11-26-2004, 01:06 AM   #1
ImprezaWRXFan
Member#: 66888
Default is rotating tires on a WRX really purposeful?
given that both sets of wheels are turning with the same force, is there much purpose to it?
only thing i could see different is the front tires getting slightly more wear from having to steer maybe
ImprezaWRXFan is offline   Reply With Quote
Old 11-26-2004, 01:32 AM   #2
Pronto_Breakneck
Member#: 74874
1991 Legacy L
White with rust accents
Quoth ImprezaWRXFan...
> purpose to it?
Absolutely.
...for varying definitions of "slightly". I wouldn't be at all surprised to see a rear set of tires last four or five times as long as the fronts, if they aren't rotated regularly.
Front tires will also wear more unevenly than rears, due to the castor of the wheel when you're turning and the increased friction on the outside edge. Moving them to the rear every few thousand miles will correct this.
There are also different ways of rotating tires to compensate for cupping and other unusual wear patterns. If your tires are wearing in strange ways and you can't pin the cause on something concrete (alignment, whatever), any competent tire person should be able to tell you how to rotate them to correct it. (Note that this doesn't apply to directional tread tires, which can only really be rotated one way.)
As if the tread life benefit wasn't enough, rotating your tires also gives you a chance to check the tire pressure regularly, as well as inspect your brake system.
In short, rotating your tires is a Good Thing. Do it.
Pronto_Breakneck is offline   Reply With Quote
Old 11-26-2004, 05:42 AM   #3
AzN121184
Member#: 40943
2003 subaru wrx
aspen white
clift notes for above ^^
yes, do it. Please.
AzN121184 is offline   Reply With Quote
Old 11-26-2004, 07:09 AM   #4
Karl
Member#: 13110
Don't forget the front of the car is heavier than the rear. The front tires wear out just a little faster than the rears.
Karl is offline   Reply With Quote
Old 11-26-2004, 07:37 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
You should rotate your wheels MORE often with a Subaru.....they need to maintain as close as possible to the same OD to keep the center diff happy
Old 11-26-2004, 05:40 PM   #6
ImprezaWRXFan
Member#: 66888
ah, that tempermental center diff
Old 11-29-2004, 02:06 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
Pushing pigs need their shoes rotated.....
Jay Storm
Old 11-29-2004, 11:00 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
Jay Storm
You may drive a 'pushing pig', but I can assure you that I do not.
If your car is a 'pushing pig', then maybe you need to look at changing your setup.
Old 11-29-2004, 11:28 AM   #9
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
This, combined with the fact that roughly 2/3 of your braking power comes from the front wheels is why the front tires on *almost* any car will wear faster. I say *almost* because if you are routinely pushing a high powered rear driver you can quickly roast the rears to nothing. My first car was a '71 Nova with a 350, and I found that out the hard way!
As stated above, the center differential is sensitive to different diameters, as it's job is to insure that the front and back wheels are moving at the same speed. I know my tranny makes a lot of racket on deceleration in 2nd and 3rd if the fronts don't have a few more pounds of air than the back, and I suspect it is a related issue.
Stanley is offline   Reply With Quote
Old 11-29-2004, 06:37 PM   #10
eyeballs
Member#: 31629
2012 Mazda 2
Spirited Green
All you need to do is inspect the tires. After 1-2 months of driving and 1 auto-x event I can clearly tell its time to rotate.
If you never put your tires to work (aka granny driving) you can go much longer w/out rotating, especially if you have a good alignment. But if thats the case then you bought the wrong car.
eyeballs is offline   Reply With Quote
Rotating tires on an AWD car... Paraskass Tire & Wheel 7 09-21-2006 06:13 PM
how is Craven Tire on Ox Rd for mountin/balancing and alignment? nhluhr Mid Atlantic Impreza Club -- MAIC 21 02-25-2004 11:37 PM
what is the proper tire rotation method on the wrx? SpeedShift Tire & Wheel 0 06-07-2003 02:03 PM
Follow-up on M + S Tires on '02 WRX rssmith Brakes, Steering & Suspension 0 06-09-2001 01:26 PM
Rotating tires on rims gumby647 Brakes, Steering & Suspension 2 05-17-2001 05:06 AM
