Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 11-26-2004, 12:04 PM   #1
NinosAutoAccesories
Member#: 17347
1999 A year in th
Making....UL B SRY
Default Holiday specials on Sonin parts and installs
Almost 100% open for buisiness here in south florida sop I wanted to get some sales under way.
Full installaton services are available at discount Nino's style prices. Stop paying too much for installtions and start getting it done right. We will install your parts, someone elses parts or our own parts. Just email or PM for a quote.
Sonin Pulley
Fits Most EJ series engine equipped subarus including WRX, 2.5RS, TS, other Imprezas, Legacy, Forester, etc.
- Weighs only 1.19 lbs!
- Average gain of 8 hp at the wheels!
- Better throttle response and engine braking.
- CNC cut 6061-T6 aluminum, very strong!
- No noticeable increase in engine noise or vibration.
- NOT an underdrive pulley.
The pulley is the same diameter as stock, so you may reuse your stock belts and replace your belts with stock belts in the future.
89.99 shipped or 129.99 installed
Sonin Uppipe
This is the best uppipe for the WRX/STi you can buy. Sonin Engineering's up-pipe is manufactured to the highest quality standards using mandrel bent 321 stainless steel. The 1.75 pipe matches the turbo inlet perfectly ensuring minimal disruption in exhaust gas flow due to turbulence. All joints are 100% TIG welded for rigidity and long life. The inch flanges are machine cut for optimum acurracy as well as fit and finish and all the flange faces are surface milled perfectly flat to insure a leak free seal.
The EGT sensor is eliminated to prevent the ECU from recieveing modified signals due to the higher flow that can hinder performance as well as cause a CEL.
Each uppipe comes with Doorman studs, EGT resistor fix, comprehensive installation directions, and a limited LIFETIME WARRANTY.
Fitment - MY02 - MY04 WRX, MY04 WRX STi, and MY04 Forester.
All Sonin Engineering parts are intended for off-road use only.
199.99 shipped or 279.99 installed
[/url]Sonin Engineering rear solid endlinks are CNC machined from high strength aluminum. This makes them an excellent replacement for your factory plastic endlinks which tend to twist and bend upon corner-loading.
The addition of Sonin's solid sndlinks significantly increases cornering response and tightness, regardless of the use of an aftermarket sway bar or not.
Sonin's use of spherical bearings allow for a much wider range of angular movement and eliminates the squeaking and creaking associated with the deterioration of rubber or urethane bushings. The spherical bearings are teflon coated to prevent dirt and debris from fouling movement.
These links come complete with installation instructions as well as Sonin's limited lifetime warranty.
This new batch on sale now thru paypal only at 89.99!!! After that the price will go up.
Check out other Sonin Engineering products on my site
paypal whtezmbej@aol.com
NinosAutoAccesories is offline   Reply With Quote
Old 11-26-2004, 05:38 PM   #2
zoomfactor
Member#: 30440
03 WRX
WR Blue
Bump & good luck on getting things going!
Headers are sounding great BTW
zoomfactor is offline   Reply With Quote
Old 11-26-2004, 09:44 PM   #3
ami2fst4u
Member#: 40638
'04 PSM STi
Has some work done... ;)
Nino, check your email/VM, still awaiting the price on the replacement Enkei wheel.
Rick
ami2fst4u is offline   Reply With Quote
Old 11-26-2004, 10:46 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
Nino,
dropping you a note about your sti
rear trailing arms..waiting for them
so i can send you back my stockers.
Ben
Old 11-27-2004, 01:07 AM   #5
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
How long will this sale be going on?
Thanks,
Steven
Crash477 is offline   Reply With Quote
Old 11-27-2004, 11:08 AM   #6
NinosAutoAccesories
Member#: 17347
1999 A year in th
Making....UL B SRY
zoomfactor : Cool man, thanks
ami2fst4u : I am waiting for enkei to reopen on monday, then Ill get the price and all to you.
jaxscuby : Been at the shop all week and the car is on jackstands at the house. Ill have them out and shipped by monday though.
Crash477 : Till jan 1st
Old 11-28-2004, 12:51 AM   #7
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
Hey Nino, would you happen to have rear sway bar bushings(bushings only, already have a Cusco sway bar) for an '04 STi? Hardened if possible. Also, how about rounding up a combo for end links(sonin) shipped to 76021? Thanks dude
Mika
finnRex is offline   Reply With Quote
Old 11-29-2004, 01:30 PM   #8
NinosAutoAccesories
Member#: 17347
1999 A year in th
Making....UL B SRY
I dont have any bushings alone. I could call cusco and see if they sell them though which Im sure they do.
Old 11-29-2004, 09:22 PM   #9
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
Hey Nino, if you could call Cusco, that'd be great. Thanks
Mika
Old 11-29-2004, 09:30 PM   #10
wagonman
Member#: 971
Nino, any update on the cats from rs25.com? thanks.
Jeff
wagonman is offline   Reply With Quote
Old 11-30-2004, 03:34 PM   #11
M32WRXin3seconds
Member#: 36797
Thanks for the Up pipe and Pulley, Finish/quality looks great, I'll reply later after they are installed.
M32WRXin3seconds is offline   Reply With Quote
Old 11-30-2004, 10:54 PM   #12
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
Nino, could you quote me for (1) rear sway bar bushings/brackets for bushings and (2) sonin end links. Thanks man
Edit: These are for an '04 STi. Shipped to 76021.
Mika
Old 12-09-2004, 02:15 AM   #13
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
PM'd you Nino
Old 12-09-2004, 12:52 PM   #14
M32WRXin3seconds
Member#: 36797
Nino will be doing my 240sx/silvia swap now if i can only convince him to let me get a large turbo..haha
And thats also from Automagic to manual!
Old 12-09-2004, 12:59 PM   #15
NinosAutoAccesories
Member#: 17347
1999 A year in th
Making....UL B SRY
finnRex :, I am not quite done with the STi links, Unlike some other guys, I chose to make them from machined alumninum instead of tie rod ends to make them a little better.
Old 12-13-2004, 01:58 PM   #16
M32WRXin3seconds
Member#: 36797
bump
Old 12-14-2004, 12:40 PM   #17
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
PM'd you Nino
Old 12-16-2004, 11:51 PM   #18
garie
Member#: 26607
2002 wrx wagon
Pm'd you nino about the pulley
garie is offline   Reply With Quote
P&L's Holiday Brake Special! Prices CUT on Parts AND Install! P&L Motorsports Inc. Suspension/Brakes/Handling 4 12-13-2007 02:13 PM
Holiday Specials on APS, TXS, Cobb, Invidia, etc!!! RaceComp Engineering Engine/Power/Exhaust 15 01-26-2007 01:10 PM
Holiday Specials on Alcohol/Methanol/Water Injection kits... Ultimate Collision Center Engine/Power/Exhaust 16 01-15-2007 07:54 PM
Holiday Specials on Alcohol/Methanol/Water Injection kits... Ultimate Collision Center Tri-State Area Vendor Classifieds 21 01-14-2007 12:46 AM
Holiday Specials on Alcohol/Methanol/Water Injection kits... Ultimate Collision Center Engine/Power/Exhaust 5 12-15-2006 12:10 PM
