Old 06-30-2001, 03:43 PM   #1
M8
Member#: 949
06 F2000
Speed Triple
Question Special tools for stereo removal?
Hi, i finally picked up a new head unit... i did a search but most of the info i found was on the WRX. do i need any special tools to remove the stock 2.5RS stereo? or the trim around it? ....and, does anyone have a part# for the piece that i'll need to fill the gap left when i go to a single DIN? thanks...
M8 is offline   Reply With Quote
Old 06-30-2001, 03:57 PM   #2
blub blub
Member#: 7566
it was a dark and
stormy night.....
small philips head
that should be all
metra pocket
MET 88-00-3001 i think is the model number.
thats the last one i used, seen used in a RS
also in a new WRX.
universal pocket put it on the bottom and fill it
with say a boost controler.....
mmmmmmmm......
boost controler........
or put a blank panal on the outside of it
and put your nitrous power up switches there
mmmmmmmmmmm....
NOS
blub blub is offline   Reply With Quote
Old 06-30-2001, 03:57 PM   #3
Cliff Ditchhanger
Member#: 418
Chapter/Region: HIIC
2001 RSTi
Steel Blue Mica
The trim and stereo are very easy to remove...all you need is a phillips screwdriver.
1. Open your armrest cover, take off the caps nearest to the ebrake and remove those screws.
2. Pull the trim cover for the ebrake forward...it will pop right off, just remember to unplug the power mirror connector.
3. Unscrew your shiftknob and pull that trim part off too.
4. Slide out your ashtray.
5. Pull off the front trim piece from the bottom...just be careful. It will seem like you are going to snap them off, but it won't
6. Unscrew the four screws that hold in the stereo and slide it out.
7. Remove the connectors for the lighter, ashtray light and so on.
Cliff Ditchhanger is offline   Reply With Quote
Old 07-01-2001, 03:50 AM   #4
M8
Member#: 949
06 F2000
Speed Triple
Talking
Hey thanks lads. to be honest i tackled it before i was able to come back here and check for any replies.... but thanks just the same. it went fine. i fumbled the trim off, while a friend soldered all the wiring together indoors. other than a little bit of dremelling to allow the new head unit (Rfd Fsgt RSX9000) to sit where i wanted it; it all went smoothly. i left the stock CDP in place, as i had nothing else to fill the gap with. i'll track something down soon enough. boost controller is in the works, so maybe.....
thumbs up to the 9000 for anyone that is interested. there is a lot to be said for a CDP that can play MP3's! i did'nt think i'd get much use out of it, until i had squeezed 8 hours of my favorite tunes onto one disc
next up; Speakers.
special tool crank sproket removal ? jimkelly Newbies & FAQs 9 09-23-2007 12:12 AM
Special tool for strut top nut removal? NicGordon Brakes, Steering & Suspension 35 08-12-2003 07:11 PM
Special tools for strut installation? dsc Brakes, Steering & Suspension 7 04-17-2002 05:01 PM
any special tools for installing lowering springs? SWEETWRX Brakes, Steering & Suspension 8 07-26-2001 04:12 AM
special tool for axle replacement? ARC Normally Aspirated Powertrain 7 05-14-2001 07:21 PM
