Old 11-27-2004, 02:15 PM   #1
kevinsUBARU
Member#: 2263
2012 Impreza Sport
Default 95 Impreza: Front Differential Drain Plug/Washer question
Is a crush washer used on the front differential of an automatic tranny (1995) Impreza? Owners manual says yes, ScoobyMods says nothing, Chiltons says nothing, and I found an old thread re: 2000 Outback that said no crush washer was present.
If I need one, what size? I don't want to drain it only to find out anything that I put in is just going to come back out. Thanks for the quick help!
Kevin
kevinsUBARU is offline   Reply With Quote
Old 11-28-2004, 09:58 PM   #2
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
I'm not positive, but I believe you'll find a 26mm aluminum crush washer down there. The replacement part is now copper.
You can actually reuse aluminum or copper crush washers a few times if you reanneal them -- heat them up with a torch until they glow, and then quench them in water.
vrg3 is offline   Reply With Quote
Old 11-30-2004, 01:21 PM   #3
ImprezaVA
Member#: 32846
1998 Impreza L-SOLD
Arcadia Green
Post
I don't recall a crush washer being on my front diff. drain plug. It doesn't leak either. Wouldn't hurt to have one though.
-Charles-
ImprezaVA is offline   Reply With Quote
Old 11-30-2004, 05:02 PM   #4
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
It does take one- part number is 803926070.
Brian
Old 12-01-2004, 02:02 PM   #5
Hayes
Member#: 11808
Anneal them by heating to a red glow and SLOWLY cool them. ed
Hayes is offline   Reply With Quote
Old 12-01-2004, 02:05 PM   #6
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
You don't need pay any special attention to how quickly you cool it. Unless you're dunking it in liquid nitrogen, you won't cool it fast enough to harden it. I know that's true for copper, anyway.
Quenching helps keep the surface from oxidizing up, which is why I prefer it.
Old 12-09-2004, 03:46 PM   #7
TheJonesBoy
Member#: 55779
2004 WRX Wagon
WR Blue
Ummm. Only with the copper. If your aluminum is glowing its on fire.
Copper should be brought to a glow, held there for a little, and air cooled to prevent precipitate hardening. Aluminum should be made hot (but not melting, very hard to judge) and water quenched. For our purposes, the quenching REALLY doesn't matter.
TheJonesBoy is offline   Reply With Quote
Front Differential Drain Plug Torx Bit Size? 02TREX Baja Forum 2 04-11-2005 06:58 AM
Drain plug washer (gasket) vicmanblue Texas Impreza Club Forum -- TXIC 8 12-14-2004 02:27 AM
Those pesky drain plug washers. blitzpb Southern California Impreza Club Forum -- SCIC 8 02-14-2004 07:39 PM
Oil drain plug washer removable? ironsteel Legacy Forum 8 03-28-2002 12:19 AM
drain plug washer and oil temp sensor haic18 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 03-19-2002 09:36 AM
