Welcome to the North American Subaru Impreza Owners Club Friday January 30, 2015
Old 11-27-2004, 11:01 PM   #1
elektrikheadx
Member#: 37077
2002 WRX Sedan
WR blue
Default both front parking lights = OUT
Passenger side was the first to go, aboubt 4-5 months ago ( replaced and then it went out again). Now the driverside has gone out as well.
Are there any documented issues about electrical problems causing these to blow? Any info is appreciated.
Thx !
elektrikheadx is offline   Reply With Quote
Old 11-27-2004, 11:16 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
You could check your system voltage at the battery, it should not exceed about 14.5V with no load. If it's 15V or above the voltage regulator in the alternator may be bad and this will cause bulbs to burn out prematurely. However if this were the case I'd expect to see other bulbs blowing as well.
Front Parking Light LEDs 06impreza Vancouver Impreza Club Forum -- VIC 20 09-04-2006 06:20 PM
Using Front parking light as blinkers o2sys Electrical & Lighting 3 01-07-2006 07:19 AM
parking lights out RacingJester Electrical & Lighting 1 03-02-2004 12:37 PM
Oem\fatory alarm\front parking light and turn signal glitch Webber Technical Forum Archive 4 10-05-2000 11:51 AM
