Old 11-27-2004, 10:03 PM   #1
dr_keef
Member#: 70410
2001 2.5 RS Coupe
Blue Ridge Pearl
Subaru Stars Suggestions for ignition
I am doing a rs-t conversion and am wondering what my options are for ignition. I need a good coil but also need a boost timing controller. I was looking at the msd dis-2 and boost timing master but i do not believe these will work. please help. Thanks
dr_keef is offline   Reply With Quote
Old 11-27-2004, 11:44 PM   #2
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
I like my TEC 3. 66k volt coil pack, controll boost via a 30 dollar GM boost solenoiid.
subiekid is offline   Reply With Quote
Old 11-30-2004, 01:36 AM   #3
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
I have a DIS-2 on my Legacy Turbo and love it.
Your coil pack has the ignitor integrated, I think, so if you want to use a DIS-2 you need to switch to the older style setup which has a separate ignitor and coil pack. It's easy to do; you just need to source an ignitor and coil pack from an earlier car; the wiring is very straightforward. Three of the wires you'd be adding in would have to be cut for installation of the DIS-2 anyway.
If you're lucky and find a coil pack that has male coil towers like your stock one, that'll be nice. But it'll be easier to find a coil pack with female towers, and if you do you'll want to switch to the coil terminals and boots. If you're buying Magnecor wires (which I would recommend for your application), Magnecor will happily make you the custom wires you need.
If you get one of the new Programmable DIS-2 units (MSD part number 6212) you can program in boost retard, too.
So... yeah. That's what I suggest. An ignitor/coil conversion, Magnecor wires, and a Programmable DIS-2.
Actually ... if you do decide to go this route, PM me. I might be able to get you the wires, ignitor, and coil pack.
vrg3 is offline   Reply With Quote
Its time for ignition and straight up automobile pimpin Hedbergsuby07 New England Impreza Club Forum -- NESIC 3 03-15-2009 12:50 PM
Help: Candidate for Ignition upgrade on an RS-T? kgb Normally Aspirated with bolt-on Forced Induction Powertrain 18 12-07-2006 12:01 AM
FS: SUN Automobile Hyper Force Systems for Ignition coils stiii Private 'For Sale' Classifieds 5 06-02-2006 04:46 PM
I need currents (Amps) for ignition and door switch for TT + Security Alarm mod Vew Electrical & Lighting 0 01-12-2006 09:58 PM
Looking for ignition ring light mod mrl859 Interior & Exterior Modification 5 05-24-2005 12:29 AM
