#276 | |
Member#: 40199
Vehicle:2003 WRX Platinum |
OH OH I WANT! Thats pimp!
#277 | |
Member#: 44168
SCIC
Vehicle:2003 Yellow WRX with too many lights... |
![]() One word comes to mind for those switches. "Engage..." ![]() |
#278 | |
Member#: 31511
SCIC
Vehicle:03 GD2 95 GM4 www.ITNRally.org |
thats what I was thinking.....damnit where's my radio going to go??? RR ![]() |
#279 | |
Member#: 4597
TXIC
Vehicle:2011 Mitsu Outlander Sport (Ex-Suby owner X3) |
#280 |
Member#: 43952
Vehicle:2004 WRX Wagon San Remo Red |
I'm mounting some Hella 500 driving lights up front of my grill using the radiator mounts. Conceptually, I've got the wiring down, but practically, I'm a little lost. WHICH high beam wire am I tapping, and where should I tap it? Recommendations are VERY welcome.
Thanks, Owen |
#281 |
Member#: 31511
SCIC
Just a little mental note: the Subaru system is switched ground, meaning that it is bassackwards to most other cars. There are three wires at the headlight socket. You could tap the ground that triggers the highbeam from there. I am unsure of the color code right now. You can search, or if I have time I will later when I am not busy.... (dang job getting in the way again.)
RR ![]() try here: http://forums.nasioc.com/forums/show...adlight+wiring |
#282 | |
Member#: 5887
BAIC
Vehicle:2002 GDAA 797 |
(1) Aside from the obvious difference in dual filament low/high bulbs on the my2002-2003 & separate low/high bulbs on the my2004+, the equivalent wiring diagram for the non-HID my2004+ lights have very little difference, one of them being in the way the DRL resistor is connected. Afaik, it doesn't affect how one would conceptually tap the high beam switched ground off the low / high beams. (2) If you're tapping the high beams, then, you can trace the highlighted paths to see if any of the upstream wiring is more convenient to tap. Particularly, the signal path of the high beam relay, or the lighting stalk. Tapping the lines near the high beams' connector means tapping a power line instead of the low current, signal line. Although the aftermarket system's relay should prevent excessive current draw on the signal side of the aftermarket's relay, imho tapping the low current signal line upstream is safer. (3) The second diagram I posted in that thread is when you want the aux light to function as either an aux driving light (i.e. automatically switched on when high beams are on) or an independent aux light, by means of a 2 on-position switch. A fellow member by the handle of brunetmj is in the middle of experimenting with that particular wiring approach for a pair of Hella FF1000s on a my2004 RS. He should be able to confirm whether the approach works or not. |
#283 |
Member#: 43952
I was wondering if I could just put the signal side of the Hella relay IN LINE with the switch signal of the high beam relay. I want the driving lights to be switched by the high beam switch AND a switch such that if I'm driving, I can have ONLY the high beams or the high beams and the Hellas, but both can be switched off with the light lever on the steering column.
Also, does anyone know if the wire grommet in my2004's is missing next to the steering column??? I looked down there for a while and never found anything. |
#284 | |
Member#: 63445
Vehicle:2002 WRX Wagon PSM |
Looks like something designed for a PC. Please... Where did you find this? I'm enough of a geek to use items such as these. ![]() |
#285 | |
Member#: 67127
Vehicle:3.3 I <3/h8 my GF3 1.8-2.5-2.2-2.5-2.2-3.3 |
#287 |
Member#: 4597
TXIC
okay so this is the new set up
as per requested ![]() ![]() ![]() ![]() ![]() |
#288 |
Member#: 52713
Vehicle:2004 WRX (black) 2000 RS (red) |
#289 |
Member#: 44168
SCIC
Sweet.
Are those Hella 500 foglamps that you added? |
#290 |
Member#: 31511
SCIC
Looking good
#291 | |
Member#: 62298
South East
Vehicle:2008 DGM STi MkII MR2 Turbo project |
#292 |
Member#: 72014
NESIC
Vehicle:05 Baja gone Winner best wax job 06WBM |
Have anyone tried using the rallitek light bar???
#293 |
Member#: 30789
Vehicle:2006 impreza dark blue |
Greetings,
Is the Rallitek light bar available to buy from a dealer? Thank you! blagon ![]() |
#294 |
Member#: 44168
SCIC
The rallitek looks nice.
But the lightbars that ATX25RS, Caliber, and i have look to do the same thing. ![]() |
#295 |
Member#: 31511
SCIC
funny thing I was talking with John to build me something just like that
#296 | |
Member#: 40199
And at a fraction of the cost. |
#297 |
Member#: 4597
TXIC
i had the PIAA 520's ..... i had the Hellas on my old GC8 ...i just added those to the GD6
#298 |
Member#: 43952
Just mounted Hella 500's. Thanks for the inspiration all!
Has anyone put 100W bulbs in Hella 500's? ![]() ![]() |
#299 | |
Member#: 4597
TXIC
#300 | |
Member#: 31511
SCIC
![]() I have put 130w Narvas in them. I haven't had any problems, but after a conversation www.rallylights.com I turn them off when I come to a stop. RR ![]() |
| Thread Tools | |
| Display Modes | |
| The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs | Yesitsdrew5310 | Electrical & Lighting | 525 | 05-07-2013 10:38 PM |
| The Ultimate DIY Water/Alc Injection Thread | hippy | Water/Methanol Injection, Nitrous & Intercooler Cooling | 33 | 03-08-2008 03:11 AM |
| My new Hella FF200 Driving Lights and mounts | wrxinfx | Electrical & Lighting | 14 | 04-17-2005 12:24 PM |
| WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. | Yamaha600Biker | Private 'Wanted' Classifieds | 2 | 06-08-2004 03:37 PM |
