Old 12-25-2008, 11:39 AM   #3901
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
Originally Posted by anickode View Post
The most common place to mount is attached to the subframe. That's how most of the commercially available bars are.
this is a good place if you want your lights lower. if you want your lights higher (at or above the hood) I'd recommend doing it like I did and using the bumper beam to minimize the distance between the lights and the attachment point
carl s. is offline   Reply With Quote
Old 12-25-2008, 02:13 PM   #3902
Handsdown
Member#: 29355
i'm definitely thinking i'll copy your design. the only thing i don't like about it is how much bumper cover i'll have to cut. then again, if painted black it would look just fine.
Handsdown is offline   Reply With Quote
Old 12-25-2008, 02:15 PM   #3903
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
I didn't have to cut any bumper cover that isn't visible. the only stuff i cut is underneath the bumper opening - you'd never see it unless you were lying under the bumper
Old 12-25-2008, 02:20 PM   #3904
Handsdown
Member#: 29355
yeah I know. when i photograph cars I'm usually down that low anyway
Old 01-03-2009, 06:08 PM   #3905
maxipad
Member#: 85635
'05 2.5RS
CGM
ok ive searched and im over it, whats the easiest way of mounting hella 500's in the bottom rad opening without buying a rally innovations bar. i have an 05 rs wagon. how much do the RI bars go for?
THANKS FOR ANY INFO!!!
maxipad is offline   Reply With Quote
Old 01-03-2009, 06:39 PM   #3906
Chuck Annicelli
Member#: 3265
2013 WRX Hatch ISM
2013 Outback Limited
Chuck Annicelli is offline   Reply With Quote
Old 01-03-2009, 06:43 PM   #3907
maxipad
Member#: 85635
'05 2.5RS
CGM
im looking for something that's somewhat "barless", since with a bar = most expensive. ideally some simple sturdy brackets would be sweet, if someone can make some i'd totally pay for em!
EDIT: i found this bar setup that seems simple and really sick: http://public.fotki.com/snoozeSTI/ca...la_500_on_sti/
anyone know who's car it is?? i assume the guys name on here is snooze?
Old 01-03-2009, 07:35 PM   #3908
asaturn
Member#: 166269
86 Standard
having them mounted that low is asking for something bad to happen...
but if that's where you want to mount them, I'd do two mounts coming off of the bolts in the front (the ones that hold the skid plate on) and then weld a curved bar to that. you'll want a secondary point since just that sort of setup will surely wobble a lot... you could probably figure out a way to use the license plate mounts
asaturn is offline   Reply With Quote
Old 01-04-2009, 02:47 PM   #3909
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
If those lamps were mounted up by headlight level they'd be safer and much more useful as driving lights.
Superorb is offline   Reply With Quote
Old 01-04-2009, 03:00 PM   #3910
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
You guys didn't even bother to find out if he means 500 fogs or 500 drivings before you started telling to mount them higher....
Old 01-04-2009, 03:27 PM   #3911
asaturn
Member#: 166269
86 Standard
I was just saying they'll get ripped off sticking out from the bottom of the bumper... unless he never pulls into driveways or parking lots
Old 01-04-2009, 03:28 PM   #3912
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
While that's a valid consideration, if he's planning on fogs, the higher he places them the worse they're going to work.
Old 01-04-2009, 08:30 PM   #3913
maxipad
Member#: 85635
'05 2.5RS
CGM
they are fogs for sure, mounting them that low would be risky, but i really like them in front of the rad opening, if not, right where the plate mount is. im just looking for something cheap, clean, and doesnt have to be absolutely deadly stiff like huge bar or anything.
Old 01-04-2009, 08:41 PM   #3914
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Fogs don't work if you mount them high. The single most important thing with fogs it the vertical distance between your eyes and the lights. In other words, they have to be as low as possible to work well. If you take fog lights and put them at the plate mount or higher, what you'll end up with is lights that suck as fogs and suck as drivings.
Old 01-04-2009, 08:46 PM   #3915
fattie92
Member#: 118093
2015 WRX
+10000
Mount your fogs low.
/thread
fattie92 is offline   Reply With Quote
Old 01-04-2009, 10:32 PM   #3916
maxipad
Member#: 85635
'05 2.5RS
CGM
i still need some ideas for mounting them!!! i think i might just grab an RI bar because fabbing something isnt an option unless its very simple, i have basic tools where im living right now. maybe i can find a used one somewhere.... hmmmmmmmm
anyone have pics of brackets they wanna post up?
Old 01-04-2009, 10:36 PM   #3917
02boxer
Member#: 139853
2002 wrx....its tsxy
I wouldn't /thread..../current offtopic is better...but yeah...I found that out the hard way...sadly. High mount fogs b-low all sorts....lesson learned.
chris
02boxer is offline   Reply With Quote
Old 01-05-2009, 11:45 AM   #3918
maxipad
Member#: 85635
'05 2.5RS
CGM
still looking for creative and simple bracket ideas for a lower rad opening fog mount. not finding much right now, anyone wanna make me a light bar??
Old 01-05-2009, 12:05 PM   #3919
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
^^ From what I've seen, most people use the lower bolts that you'd normally use for a skid plate. Most also try somehow to use the license plate holes to reduce/eliminate vibrations.
Old 01-05-2009, 10:32 PM   #3920
fattie92
Member#: 118093
2015 WRX
I have an older bar laying around that I don't need but its made for driving lights. Its mounted up high, almost even with the headlights. I had some fogs on there, but they were pretty useless when I actually needed to use them as fogs.
Old 01-06-2009, 03:08 AM   #3921
maxipad
Member#: 85635
'05 2.5RS
CGM
Originally Posted by asaturn View Post
ok i got hella 500 fogs and all i have to do is hook up the green wire, supposed to be tapped to the high beam 12v+ for power or something, but i want my lights to be COMPLETELY independent from the lows and highs, not on when there's solar eclipse, or off when the moon lines up with pluto. i want the switch (hella switch) to turn them on, and off. nothing fancy.
THANK YOU!!!! AND I NEED INFO ASAP, im doing this next morning!
Old 01-06-2009, 03:30 AM   #3922
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Find a wire under the dash that's hot when the car is on. Tap that and connect it to one side of the switch. Connect the other side of the switch to the green wire.
Just remember that this gives you the ability to think that your lights are on because you've got light in front of you but you're completely dark out back. Good way to get rear ended. It's much safer to tap the parking light wire to feed the switch for your Hellas so that you are assured of at least having some rear illumination.
Old 01-06-2009, 03:56 AM   #3923
maxipad
Member#: 85635
'05 2.5RS
CGM
which wire is for the parking lights?
Old 01-06-2009, 03:59 AM   #3924
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Subaru changes the wire color more often than they change their underwear. Thankfully, you have the exact same model and year that I do. If you take the cover off the bottom of the steering column, you'll pretty clearly see the wiring harness for the headlight/blinker control stock. IIRC, it's the solid orange one from that bundle. Test it to make sure (off when parking lights are off, on when you twist the stalk to Parking Lights or Headlights).
Old 01-06-2009, 07:41 AM   #3925
fattie92
Member#: 118093
2015 WRX
Also under the dash there should be a few unused relay slots to the right of the fuse box. If you want something to be hot at all times, you can tap in there.
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs Yesitsdrew5310 Electrical & Lighting 602 09-06-2016 01:43 PM
The Ultimate DIY Water/Alc Injection Thread hippy Water/Methanol Injection, Nitrous & Intercooler Cooling 33 03-08-2008 03:11 AM
My new Hella FF200 Driving Lights and mounts wrxinfx Electrical & Lighting 14 04-17-2005 12:24 PM
WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. Yamaha600Biker Private 'Wanted' Classifieds 2 06-08-2004 03:37 PM
