Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Old 10-24-2010, 02:22 PM   #4901
Landin2010
Member#: 231674
2010 Impreza WRX
Obsidian Black Pearl
2010 wrx, i had some left over tubing from welding up a roll bar in my 240 so i decided to take a crack at it/
Landin2010 is offline   Reply With Quote
Old 10-24-2010, 04:01 PM   #4902
cps102
Member#: 222776
'08 OBS
^^Nice! Now you can make one up for me!
cps102 is offline   Reply With Quote
Old 10-25-2010, 02:26 PM   #4903
SnakeFart
Member#: 217632
2009 Impreza WRX
Dark Grey Metalliac
Looks a little funky. Or is it just me? BTW Are those OEM Fogs?
SnakeFart is offline   Reply With Quote
Old 11-12-2010, 12:40 AM   #4904
Teneighty23
Member#: 179698
Nice! looks just like my car, i have an 08 WRX black too. i just ordered some Hella's tonight, gunna make a light bar once the lights come in.
Teneighty23 is offline   Reply With Quote
Old 11-16-2010, 08:39 PM   #4905
wisconsinsubaru
Member#: 232342
Heres my lightbar! Made it myself
wisconsinsubaru is offline   Reply With Quote
Old 11-17-2010, 04:05 PM   #4906
RoxyTheImpreza
Member#: 205171
2004 Forester XT
Cayenne Red Pearl
Just mounted my 4 hella 500 FF's to my roof rack I like it.... now I just need to make a wire harness.... QUESTION.... how would i get wires from my roof into my engine bay? without it being too visible?
RoxyTheImpreza is offline   Reply With Quote
Old 11-17-2010, 10:59 PM   #4907
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
Drill a hole. It would be easier if you had a wagon.
JourdanWithaU is offline   Reply With Quote
Old 11-17-2010, 11:11 PM   #4908
Xcelr8to1320
Member#: 131272
2003 WRX Wagon
i tucked my wires under the windshield trim.
Xcelr8to1320 is offline   Reply With Quote
Old 11-18-2010, 03:48 AM   #4909
Jaren1
Member#: 195061
1997 \_(ツ)
Green
This.
Jaren1 is online now   Reply With Quote
Old 11-18-2010, 11:57 PM   #4910
RoxyTheImpreza
Member#: 205171
2004 Forester XT
Cayenne Red Pearl
How many wires are you running? And are they in tubing? Also how did you get them between there?
Old 11-19-2010, 12:43 AM   #4911
Xcelr8to1320
Member#: 131272
2003 WRX Wagon
I had a 4 wire trailer harness running to the lights. They were in wire loom until they reached the window trim, then I just tucked the wire under the molding.
I just lifted up the edge of the trim and slid the the wire in as I moved down the molding.
Old 11-20-2010, 11:43 PM   #4912
2.5i guy
Member#: 151509
2003 WRX
black
here's my set-up.
Rally innovation light bar with Hella 500 driving lights and 500ff fog lights. fogs are controlled by a switch and can be turned on or off anytime. The driving lights are wired into the high beam circuit and only come on when the high beams are on. I had to make a brace for the top of the bar to keep it from shaking, but other than that its been a good light set-up. Here's a picture of the whole car. Nothing fancy, just a 2.5i with RA mudflaps and bunch of lights on the front of it!
2.5i guy is offline   Reply With Quote
Old 11-21-2010, 12:02 AM   #4913
premier00000
Member#: 251060
2008 Impreza Outback
pics of that, or details? I need to do the same, it shakes REALLY bad some times.
premier00000 is offline   Reply With Quote
Old 11-21-2010, 12:55 AM   #4914
2.5i guy
Member#: 151509
2003 WRX
black
you are in luck! I just did a write up at Dirtyimpreza.com about how I made my brace. being you have an 08, You will have to check the bottom of your bumper beam to see it it has the two holes that I mention in my write up.
http://www.dirtyimpreza.com/forums/s...ad.php?t=18771
Old 11-23-2010, 08:46 AM   #4915
premier00000
Member#: 251060
Did you drill the holes in the light bar because mine doesn't have those holes. Maybe I'll use the bump stops and use aluminum to hold them to where the front plate holes are.
Old 11-23-2010, 11:55 AM   #4916
Xcelr8to1320
Member#: 131272
2003 WRX Wagon
Old 11-23-2010, 12:03 PM   #4917
2.5i guy
Member#: 151509
2003 WRX
black
Yes, I drilled the holes into the top of my bar. Being that the bottom two riv-nuts came loose within 3 months of owning the bar, I wasn't going to trust them when it came time to mount my top driving lights. (notice how my bottom fog lights are also through bolted). Your Idea may work also, but I'm not sure mounting the braces to the bumper cover only would do much in stiffing up the bar to the point were it eliminates the shake. thought, I could be wrong.
Old 11-23-2010, 12:09 PM   #4918
Xcelr8to1320
Member#: 131272
2003 WRX Wagon
RoxyTheImpreza,
Here are the couple pictures that I could find as to how I ran the wires on my wagon when they were on the roof. The wires weren't actually tucked under the trim in these, but you can get the idea of where they were going.
Old 11-25-2010, 01:21 AM   #4919
bheinen74
Member#: 92858
factory Cyclops offroad lamp, 100watt, motorlzed flip up cover. they only put this in the 82 Brat, i retrofit it to my 85
bheinen74 is offline   Reply With Quote
Old 11-25-2010, 01:32 PM   #4920
LGT+WRX
Member#: 91119
05/9 LGT-me/FXT-wife
ABP-me/SSM-wifey
^ Holy crap that's cool!!!!!!
LGT+WRX is offline   Reply With Quote
Old 11-25-2010, 02:13 PM   #4921
sammyb913
Member#: 198817
2006 WRX Wagon
grey
that thing is awesome
sammyb913 is offline   Reply With Quote
Old 11-25-2010, 06:01 PM   #4922
hoookie
Member#: 236122
2005 Wrx
Sweet setups guys!
Here's my setup.
and here's how i did the switch
(second fog switch, not the rocket launcher switch)
Light bar, as far as i can tell is completely custom, lights are the $10.00 harbor freight aux lights. rubber coated, they don't quite cut it but they're better than nothing
hoookie is offline   Reply With Quote
Old 11-26-2010, 08:37 AM   #4923
Justin Horne
Member#: 262294
Just looking for quick confirmation... Does the RI light bar work on non-sti 2008+ models? On their site, they only list 2008+ STi models, but they also list 2008+ Outback Sport.
Thoughts?
Justin Horne is offline   Reply With Quote
Old 11-29-2010, 10:06 PM   #4924
TommySWRX
Member#: 106032
2008 WRX wagon
Spark Silver
Thoughts?
yes it does
TommySWRX is offline   Reply With Quote
Old 12-10-2010, 08:35 PM   #4925
hella_sti
Member#: 139289
2003 WRX Wagon
Got more pics of the mounting points on this? Its awesome!
hella_sti is offline   Reply With Quote
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs Yesitsdrew5310 Electrical & Lighting 596 01-30-2016 12:33 PM
The Ultimate DIY Water/Alc Injection Thread hippy Water/Methanol Injection, Nitrous & Intercooler Cooling 33 03-08-2008 04:11 AM
My new Hella FF200 Driving Lights and mounts wrxinfx Electrical & Lighting 14 04-17-2005 01:24 PM
WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. Yamaha600Biker Private 'Wanted' Classifieds 2 06-08-2004 04:37 PM
