Old 11-30-2004, 06:00 PM   #26
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
Originally Posted by satrya
Thank you and you're welcome. How about mounting a pair of the FF75s in front of the grille side pieces instead of replacing the 4000s & 500s?
Call them pairs of aux. foglights, aux passing lights, aux driving lights, and aux spot lights, and you're all set.
I am not replacing the 4000s, I am adding four of the FF75s to the top of the bar
If I ever get any extra money I might get some Hella Projector Fogs and finish that little project and mount them in the side pieces. I still really like the way that looks
RR
Rapid_Roo is offline   Reply With Quote
Old 11-30-2004, 06:39 PM   #27
satrya
Member#: 5887
2002 GDAA
797
Default Safari Rally lights?
By the way, have you (or anyone else) considered mounting aux lights on the side mirrors like older safari rally cars? I know that this means the mounts need to be easily detachable to maintain compliance with California Vehicle Code, but making a pod on the side mirrors for small aux units like the PIAA004Xs isn't that difficult. All you need are a few bracket material, spare side mirrors, and pod-like material like the roof flashing I used for the fog trims. Imho, it'll make a nice addition to the extensive array of lighting you already have on.
Originally Posted by Rapid_Roo
...I am adding ...
Oooh. My mistake.
Maybe the Hella 90mm fogs are better candidates since they won't be dwarfed by the rest. Iirc, a member by the name of wrxlvr made custom side pieces for 90mm Hella fogs.
satrya is offline   Reply With Quote
Old 11-30-2004, 06:43 PM   #28
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
I have discussed this at length with Rally Innovations, but thus far we have yet found the time for it. I for one wanted it. One of the other things I was thinking of was adding little motors to it, so that you can use them a search spot lights, and have them remote controlled in the cabin.
Yeah its funny that a majority of the posts are from Cal. Gotta wonder what we are doing
but if you must ask, I Road Rally... at night. There's nothing like getting out on to the back roads and canyons in the wee hours while everyone else is dead alseep.
Old 11-30-2004, 06:59 PM   #29
ubryaj8
Member#: 76199
1995 Impreza L
Red
I am thinking of replacing my stock, broken fog lights on my 95 Impreza L. Anyone know of some aftermarket fog lights or driving lights that would fit the space alright? I've searched with no luck.
Thanks
ubryaj8 is offline   Reply With Quote
Old 11-30-2004, 07:19 PM   #30
satrya
Member#: 5887
2002 GDAA
797
... I Road Rally... at night...
Yes, as you previously indicated. Nevertheless, I would've expected states that experience severe winters to post more responses.
If your my1995 L looks like this L below, then even the rectangular Hellas like in post #4 in the previous page would probably not fit. You may want to remove the foglight housing altogether and fit Hella Optilux projector fogs there. Imho, any reflector type foglight that is small enough to fit that space wouldn't be as useful as projector fogs. Most of the Optilux Projectors would fit there. You just need to make some custom brackets. Other than Hella Optilux Projectors, PIAA 959 projectors, Hella DE Driving lights, and Hella Optilux Xenon DE lights would probably fit as well.
Old 11-30-2004, 07:49 PM   #31
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
same here but oh well. We are all together for the quest for more light
Old 11-30-2004, 07:52 PM   #32
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
Thanks
or maybe something like this.
I have a 97 Impreza LX as well, and I was thinking of fitting so of these. I can check later in the week to see if they actually fit. I have the lamps for another project.
Old 11-30-2004, 08:19 PM   #33
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
Ok, here is one for the "Please don't do it this way column."
RR
Old 11-30-2004, 08:38 PM   #34
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
RR
t3h win.
Old 11-30-2004, 08:49 PM   #35
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
1.8-2.5-2.2-2.5-2.2-3.3
Ok, here is one for the "please don't do it this way column."
HOW DID YOU GET A PICTURE OF MY CAR!!!!
j/k.
tooocool49723 is offline   Reply With Quote
Old 11-30-2004, 09:27 PM   #36
ubryaj8
Member#: 76199
1995 Impreza L
Red
I was wondering if these would fit, I was thinking about Hella's. If you could find out and maybe take a picture, that'd help. Satrya, I'm kinda of interested in a replacement that will fill the weird shaped hole, look close to stock, and are not too expensive but thanks for the info. I may add more lights later though. Also what kinda of lights are the stock ones, driving or fog? I'm still not sure if i should get driving or fog lights.
Old 11-30-2004, 10:26 PM   #37
Bluebull
Member#: 54424
04 STI
Keep'em coming,these are great ideas! On some of these i'm wondering how long the alternater will cry for mercy before it commits suicide! I wanted better lighting to see all my pretty snowy parking lot artwork..... KB
Bluebull is offline   Reply With Quote
Old 11-30-2004, 11:21 PM   #38
satrya
Member#: 5887
2002 GDAA
797
One thing that will surely fill the weird shaped hole is this one available off
http://www.subaruparts.com/catalog/?section=12#34
(see picture below). Although, US$165 hardly classifies as "not too expensive".
If you don't mind a bit of DIY, you can find some roof flashing and trim it to fit the profile of the bumper opening. I did something similar for my my2002 impreza. The material itself cost about US$4-5 per side, available from Home Depot. The roof flashing looks like the picture below (although you'd probably want one that has a smaller opening size.
Here is a comparison between before and after adding the trim. I believe a similar thing can be fashioned for your bumper.
Regarding what lights are better, that depends entirely on what your needs are. The stock ones are supposedly fogs, although I don't recall them being that useful in general anyway.
If you want better peripheral & near-field vision, especially during inclement weather or driving in twisty roads, then projector foglights like the Hella Optilux projector types or PIAA959 Turbojector (I think that's the name) would work best. The Hella Optilux projectors are slightly smaller than the 959, with the 959 using higher wattage bulb and costing much more. The 959 might not fit the recess.
If you want lights that aid the high beams or project a long beam for long, night drives in the middle of nowhere in good weather, then driving beam pattern is probably better. One model I can think of that fits that space is the Hella Micro DE. (see a post by brunetmj on the first page on this one).
Others here may have a different opinion.
Old 11-30-2004, 11:36 PM   #39
Caliber
Member#: 40199
2003 WRX
Platinum
Someone with Hella 500 yellow fogs light them up for me I'm considering some for my stock location fogs.
Caliber is offline   Reply With Quote
Old 12-01-2004, 03:10 PM   #40
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
I need to take some pics of my lights in the Dark.....DAMN they are bright.
I also have a set of Hella FF75's on the way (be here friday) for my Audi. I may test them out on the Subie first. They are the driving version, and Ill take some pics so you can get an idea of the size of them.
DDMan is offline   Reply With Quote
Old 12-01-2004, 04:15 PM   #41
Psydotek
Member#: 44168
2003 Yellow WRX
Looks like my FF1000s will be going on today.
Old 12-01-2004, 04:29 PM   #42
PARANOID56
Member#: 22035
2008 STI
damn man, make sure you post some pictures
Shane
PARANOID56 is offline   Reply With Quote
Old 12-01-2004, 10:56 PM   #43
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
Default Here are ATX25RS's lights
Old 12-01-2004, 10:58 PM   #44
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
Default I am not sure who's these are, but I like them.
good use of 90mm projectors
Old 12-01-2004, 11:01 PM   #45
tooocool49723
Member#: 67127
3.3 I <3/h8 my GF3
C'mon now, I know someone has mounted them in the hoodscoop...
Old 12-01-2004, 11:02 PM   #46
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
ask this guy, he may have tried it by now: http://forums.nasioc.com/forums/showthread.php?t=673729
Old 12-02-2004, 10:06 AM   #47
BoomerE30
Member#: 56178
1998 RS2.5
how much the rally innovations bar w/ fogs cost for the 99-01 RS?? i cant find the price on their website.
BoomerE30 is offline   Reply With Quote
Old 12-02-2004, 10:39 AM   #48
Psydotek
Member#: 44168
2003 Yellow WRX
www.southcoastperformance.com carries the Rally Innovations light bars. Abit over $200.
http://www.southcoastperformance.com...oduct=RALLYBAR
They also have a skidguard bar:
Clicky for more
Old 12-02-2004, 12:08 PM   #49
Drav
Member#: 52713
2004 WRX (black)
2000 RS (red)
Clicky for more
And they don't have that for an 04 either. Damn!
Drav is offline   Reply With Quote
Old 12-02-2004, 12:11 PM   #50
Psydotek
Member#: 44168
2003 Yellow WRX
Not yet.
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs Yesitsdrew5310 Electrical & Lighting 525 05-07-2013 10:38 PM
The Ultimate DIY Water/Alc Injection Thread hippy Water/Methanol Injection, Nitrous & Intercooler Cooling 33 03-08-2008 03:11 AM
My new Hella FF200 Driving Lights and mounts wrxinfx Electrical & Lighting 14 04-17-2005 12:24 PM
WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. Yamaha600Biker Private 'Wanted' Classifieds 2 06-08-2004 03:37 PM
Message Board Statistics All times are GMT -4. The time now is 11:01 AM.
