Old 02-13-2011, 10:47 PM   #5051
andrew's bug eye
Member#: 254997
2014 Impreza
Pearl White
2 hella 500's and 2 hella 500 fogs in the mail
andrew's bug eye is offline   Reply With Quote
Old 02-14-2011, 12:50 AM   #5052
Teneighty23
Member#: 179698
Originally Posted by Superorb View Post
I don't have a welder, that's why I was looking for a design with a receiver/hitch type deal. I only want a single bar for 2-4 Hella lamps around headlight level. Nothing special or complex.
Well as long as you just have a solid place to mount it, to the bumper beam most likely. Then any design should work, just go outside and stare at your car for a while, maybe take off the bumper, do some measuring and drawing. and talk to a metal shop and see what they have for bar that fits over one another, these pieces fit over each other REALLY snug.
Teneighty23 is offline   Reply With Quote
Old 02-14-2011, 01:14 AM   #5053
Teneighty23
Member#: 179698
last build update
Powdercoated flat black to match the 4000's
Old 02-14-2011, 01:18 AM   #5054
Teneighty23
Member#: 179698
Finally have completed photo's! went out to aim them tonight, tho the car is super dirty (usually will be) its super warm right now, hovering just above freezing, so its really wet and slushy. Nice clean photos will have to wait till its cold again, or elseee summertime. Wall comparison
Stock Low beams:
Stock Low beams+Stock Fogs:
Stock high beams:
Stock high beams+Hella 4000 Driving beams, 55W bulbs:
Old 02-14-2011, 01:10 PM   #5055
02wrxRally
Member#: 205994
'02 Bawkeye WRX
'04 tOtaledBS | '68 MGBGT
I have a removable bar, but it just uses 2 bolts not a hitch.
1" steel bolted to the bumper with nuts welded to the bottom for easy mount/dismount(my mechanic did it for a few bucks, I have no welder either). The angle stock I ended up cutting another piece and doubling them up - there was shake with just 1, with 2 sandwiched together it's solid.
02wrxRally is offline   Reply With Quote
Old 02-14-2011, 01:15 PM   #5056
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
^^ Looks good.
Superorb is offline   Reply With Quote
Old 02-14-2011, 01:26 PM   #5057
02wrxRally
Member#: 205994
'02 Bawkeye WRX
thanks
Old 02-14-2011, 02:28 PM   #5058
This Is Not Mike
Member#: 131737
2006 STI OBP
2013 Tacoma TRD OR
My setup:
Two Hella 500 Amber fogs utilizing the OEM wiring. I cut the OEM wiring at the connector and spliced in my own weatherproof 2 wire connector and ran those to the fog lights. I then bought the OEM relay and OEM fog switch to complete the kit.
The mounts are set up in a way that it uses all existing holes and can be removed without a trace on the car. My friend designed the system for his 2006 wagon and then built this setup for me. It doesn't require anything but hand tools.
There are (2) "S" shaped (but with 90 degree bends instead of curves) main bars. One end bolts to the core support using OEM holes. The second end bolts to the cross bar that goes behind the license plate. There are two bars that drop down from the license plate bolts that tie into the cross bar behind the plate and center the fogs on either side of the plate.
Maybe not a "beefy" solution to the problem, but it seems to work well enough for my application.
This Is Not Mike is offline   Reply With Quote
Old 02-14-2011, 09:52 PM   #5059
Geek Guy
Member#: 8151
2002 WRX Rally Car
Atlantic Rally Cup Champ!
My car last weekend at the Sandblast Rally.
Geek Guy is offline   Reply With Quote
Old 02-15-2011, 08:01 AM   #5060
climbhigh09
Member#: 254163
2011 WRX 20GXTR
Originally Posted by Teneighty23 View Post
Your handiwork *almost* makes up for that wallpaper. Almost.
climbhigh09 is offline   Reply With Quote
Old 02-15-2011, 08:14 AM   #5061
RoxyTheImpreza
Member#: 205171
2004 Forester XT
Cayenne Red Pearl
It's his moms house, don't ask me how I know
RoxyTheImpreza is offline   Reply With Quote
Old 02-15-2011, 08:15 AM   #5062
JourdanWithaU
Member#: 146287
2009 Impreza 2.5i 5D
Sunlight Gold Opal
I was thinking the same thing...
JourdanWithaU is online now   Reply With Quote
Old 02-15-2011, 08:21 AM   #5063
RoxyTheImpreza
Member#: 205171
2004 Forester XT
Cayenne Red Pearl
oh ****, so you mean to tell me that I am riding the town bike?
Old 02-15-2011, 09:04 AM   #5064
JourdanWithaU
Member#: 146287
Sunlight Gold Opal
Isn't ignorance bliss?
Old 02-15-2011, 08:08 PM   #5065
Teneighty23
Member#: 179698
I would offer a retort but supper is almost ready. cheers
Old 02-16-2011, 07:01 AM   #5066
climbhigh09
Member#: 254163
2011 WRX 20GXTR
I remember when my mommy made me dinner. You win.
Old 02-16-2011, 07:26 AM   #5067
RoxyTheImpreza
Member#: 205171
2004 Forester XT
Cayenne Red Pearl
ahhh the good days
I hope my Fiance doesn't see this haha
Old 02-17-2011, 11:43 AM   #5068
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
The days when mom cooked dinner every day have been missed. I hate cooking for the both of us every friggin day.
Old 03-11-2011, 05:22 AM   #5069
1986944t
Member#: 191367
Slow As Molasse's
Here's my first setup. Taking the yellow film off the headlights though. Going to clear them and maybe paint the insides of the housings yellow instead. Also thinking about taking a leap and making a light pod, as well as two more Hella's for the pod, and also making some pods to accomodate some Hella's in the stock fog location.
1986944t is offline   Reply With Quote
Old 03-12-2011, 06:23 AM   #5070
finebykris
Member#: 276561
2 amber fogs in the mail here
finebykris is offline   Reply With Quote
Old 03-26-2011, 12:36 PM   #5071
buyos1717
Member#: 82377
2003 S2000
Grand Prix White
I'm sure this was probably covered but can anyone suggest some lights for me?
I have a '92 civic that I daily drive in the morning before the sun is up. Any suggestions on what i should get that won't blind everyone? I'm not really concerned with aesthetics. I just want to be able to see more road in front of me. With that, I don't want to spend much more than $100.
To my understanding fog lamps won't light up much of the road in front of you. Driving lights are more to be used in conjunction with highbeams which would blind everyone. And i'm a bit confused with pencil beam because i thought driving lights had a pencil beam pattern, but saw that it was referred to separately in some places.
Hella 500 pencil beams?
FF1000's?
buyos1717 is offline   Reply With Quote
Old 03-26-2011, 03:57 PM   #5072
LGT+WRX
Member#: 91119
05/9 LGT-me/FXT-wife
ABP-me/SSM-wifey
^ Start by restoring the factory headlamps' covering/lens. My bet is that it's very cloudy/hazed.
If you can get that back to what it used to be, that's half of your battle, right there.
LGT+WRX is offline   Reply With Quote
Old 03-26-2011, 04:01 PM   #5073
Project Barnie
Member#: 123697
2006 Miata
Galaxy Gray
^^^^that
And see if there are any osram nightbreaker 90+ in your size. It helps PLENTY. I had it on my old wrx lights and it was a big difference! Or try the sylvania xtravisions, almost the same output and available at any autoparts store.
Project Barnie is offline   Reply With Quote
Old 03-27-2011, 12:13 AM   #5074
buyos1717
Member#: 82377
2003 S2000
Grand Prix White
That's a good idea. I'll probably still want more light output, considering I've gotten close to thinking I need to augment my HIDs on my S2000.
Even though different headlight bulbs might help I think something that can throw light further out (but not as much wide) would be more helpful on the freeway.
Old 03-27-2011, 05:41 PM   #5075
LGT+WRX
Member#: 91119
ABP-me/SSM-wifey
Man, if you're thinking about supplementing that on your S2K, then indeed, you'll need more light.
The problem is that with low-placed fogs, unless you go with a "trial-and-error" aiming, you're not going to have much usable light except for the very, very close foreground. If you're picking your way, slowly through dense snow or torrential rain - or fog - yes, that's great, but almost by-definition, that's very low-speed stuff. Even with hours of trial-and-error self-aiming, it's still more than likely not going to give you the penetration/throw that you want.
With anything that supplements the high-beams, such as set of properly placed (and properly patterned) driving lamps (with pencil-beams as a sub-category of driving lamps), being offensive to oncoming traffic (and thus a danger to yourself, as, seriously, who wants to blind oncoming traffic! ) becomes a big concern - proper usage becomes a requirement. I don't know what your traffic patterns are like, at the hours that you drive, but that would be my biggest concern.
What does everyone here think about a set of auxiliary low-beams, for buyos?
I still don't think that it'll give him the absolute reach he's looking for, but it should help somewhat, with overall visibility, no?
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs Yesitsdrew5310 Electrical & Lighting 601 07-30-2016 07:59 PM
The Ultimate DIY Water/Alc Injection Thread hippy Water/Methanol Injection, Nitrous & Intercooler Cooling 33 03-08-2008 03:11 AM
My new Hella FF200 Driving Lights and mounts wrxinfx Electrical & Lighting 14 04-17-2005 12:24 PM
WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. Yamaha600Biker Private 'Wanted' Classifieds 2 06-08-2004 03:37 PM
