Old 03-27-2011, 06:09 PM   #5076
Project Barnie
Member#: 123697
2006 Miata
Galaxy Gray
How about some euro or cornering beams?
Project Barnie is offline   Reply With Quote
Old 03-28-2011, 12:12 PM   #5077
SportyMark
Member#: 167263
02 WRX Sedan
here is how mine sits now
SportyMark is offline   Reply With Quote
Old 03-28-2011, 12:18 PM   #5078
premier00000
Member#: 251060
2008 Impreza Outback
Damn... Looks awesome. What r those lights up top?
premier00000 is offline   Reply With Quote
Old 03-28-2011, 12:27 PM   #5079
Rapid_Roo
Member#: 31511
03 GD2 95 GM4
www.ITNRally.org
Rally Stuff
Looks AWESOME! What lights are you running?
keep up the great work
RR
www.ITNRally.org
Rapid_Roo is offline   Reply With Quote
Old 03-28-2011, 02:13 PM   #5080
SubLGT
Member#: 207528
2005 Legacy GT
Originally Posted by buyos1717 View Post
..............Even though different headlight bulbs might help I think something that can throw light further out (but not as much wide) would be more helpful on the freeway.
Buy a new Mercedes with intelligent adaptive front lighting.?
Several decades ago you could buy auxiliary "mid-beams" that enhanced the distance performance of OE low beams. IIRC, Cibie had the Passing Beam and Hella had the XL lamps. Nothing like that on the market now.
With your $100 budget, clean/polish the lamps, and get better bulbs, such as Philips Xtreme Power, and aim them.
If your budget was bigger, I would advise you to contact Daniel Stern for his advice. He has unique access to lighting products that you would not otherwise be able to purchase in the USA.
Other bulbs to consider are the Philips Xtreme Vision and the Osram Night Breaker Plus.
http://www.autoexpress.co.uk/product...ent_white.html
SubLGT is offline   Reply With Quote
Old 03-28-2011, 05:40 PM   #5081
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Looking good Mark.
Superorb is offline   Reply With Quote
Old 03-28-2011, 06:08 PM   #5082
SportyMark
Member#: 167263
02 WRX Sedan
Lets see
retrofitted Morette's with 4300k D2S (just waiting to wire up the height adjusters)
100 high beams
100 watt hella 500FF driving lights
55 watt hella 500 yellow fogs
LED 800 lumen floods on the top
then the turn signals pull double duty as LED white running lights that swap to amber when they flash.
All wired and relayed with a 110 amp alternator
Old 03-28-2011, 06:27 PM   #5083
premier00000
Member#: 251060
Lets see
100 high beams
No issues with the 100watts in the 500FF? i heard that they'd cause some issues (melting). How are the LED floods?
Old 03-28-2011, 06:58 PM   #5084
SportyMark
Member#: 167263
02 WRX Sedan
never a problem with the 100 watt bulbs, I have run them for a pretty good time I jsut make sure they have a good ground. no mentling yet and this is the second car I have had this set on.
As for the LED floods they are not bad, I am going to experiment with some different lenses, these are cheap chinese knockoffs, so I am just playing with them. If I were buying the more expensive nes I woudl have gone for the xvision solstace series
Old 03-28-2011, 11:22 PM   #5085
Skippy5883
Member#: 34730
Midnight Black Pearl
Hey Mark,
How did you wire the high beams to stay on with the lows?? I have checked around a little and have been wanting to do this to my JDM housings for a while now. I'm running a similar setup just with some more HID's.
Skippy5883 is offline   Reply With Quote
Old 03-29-2011, 09:00 AM   #5086
SportyMark
Member#: 167263
02 WRX Sedan
they are Relayed so the lows come on with the positive and then ground to a good chasis ground then the high beams get power from the battery and the relay triggers when the highbeam ground is triggered. only downside is the lows come on when when I flash-to-pass the highs.
Old 03-29-2011, 05:58 PM   #5087
Project Barnie
Member#: 123697
2006 Miata
Galaxy Gray
Sportymark, your car makes me want to convert back to a bug eye!
Old 03-30-2011, 11:54 AM   #5088
SportyMark
Member#: 167263
02 WRX Sedan
Thanks!
Old 04-05-2011, 12:27 PM   #5089
acurarsx
Member#: 145996
Hey can someone tell me if the hella Rallye 1000 Black Magic Series lights work on the rally innovations light bar? Thanks
acurarsx is offline   Reply With Quote
Old 04-05-2011, 01:05 PM   #5090
MFR Sweep
Member#: 103510
2006 rex
Aspen Brake Dust
I don't believe they will fit. But you don't want them down that low anyway. They are driving lights and should be mounted as high as possible (inline with the headlights).
MFR Sweep is offline   Reply With Quote
Old 04-05-2011, 01:18 PM   #5091
premier00000
Member#: 251060
Well, the lights could be mounted on the top part of the bar...
Old 04-05-2011, 01:47 PM   #5092
MFR Sweep
Member#: 103510
2006 rex
Aspen Brake Dust
There are no clearance issues on the top of the bar that would prompt that kind of fit question.
And yes, you could.
Old 04-05-2011, 05:06 PM   #5093
Spoonwacker
Member#: 125062
06 LGT Wagon (ABP)
Ford Escort Chumpcar
I have the RI bar for my Legacy with FF1000s in the top center locations - I was only able to get them to fit using the stamped steel brackets (http://www.rallylights.com/detail.aspx?ID=433) to move them away from the bumper. The center mounts on the RI bar are so close that the lights almost touch. Rallylights.com's info indicates that the Black Magics are not as deep as the FF1000s, but they are wider, so you might have to rig up a way of mounting them on the outside "bottom" brackets so that they are above the bar (for better projection).
Spoonwacker is offline   Reply With Quote
Old 04-05-2011, 05:19 PM   #5094
premier00000
Member#: 251060
Sucks those brackets aren't available anymore.
Old 04-05-2011, 05:25 PM   #5095
Spoonwacker
Member#: 125062
06 LGT Wagon (ABP)
Or the FF1000s for that matter...but I suppose the 3000/4000 compacts are about the same size, so if/when I replace the 1000s, those will go on. Looks like the 3000s have the mounting bracket placed closer to the rear of the lamp, so I wouldn't have to mess with them...
Old 04-06-2011, 12:51 AM   #5096
acurarsx
Member#: 145996
One more question regarding these hella 500 black magics. I want to mount them where my stock fogs are using the kartboy bracket. I know its a driving beam but I like the blacked out look so i dont really care about that. So the question is are these compatible with the kartboy mount. It seems like they are the exact same dimensions as the regular 500s so it should work right? The only difference I see is that the regular 500s say Pendant for mounting and the 500 black magics dont. Soooo.....will these work or no? THANKS!!!!
http://www.myhellalights.com/index.p...s-black-magic/
Old 04-06-2011, 01:06 AM   #5097
02boxer
Member#: 139853
2002 wrx....its tsxy
same mount and housing...I am 99.99999999999% certain
02boxer is offline   Reply With Quote
Old 04-06-2011, 11:30 AM   #5098
acurarsx
Member#: 145996
Anyone else that can chime in? The only thing that throws me off is that it doesn't say pendant for mounting.
Old 04-06-2011, 12:51 PM   #5099
MFR Sweep
Member#: 103510
2006 rex
Aspen Brake Dust
your first question was on the rallye 1000 black magic, now you are asking about the 500 black magic?
These are two different sized lamps.
The hella 500 and the 500 black magic are the same housing, mounting, ect. they only come with a blackened reflector and black cover.
Yes they will fit in your fog holes, but you would be far better off getting the Hella 500 FF fogs for that position (in a bugeye I assume?). They are less expensive, and you won't have to rewire to have them come on with your high beams.
They will also be far too low to actually do anything.
If you want the black look get this:
http://www.rallylights.com/detail.aspx?ID=4276 (fog version)
and
http://classicgarage.com/newhecoshprf.html
Old 04-06-2011, 12:58 PM   #5100
acurarsx
Member#: 145996
Yes I am asking about the 500s now for the stock loaction on a bugeye. I guess I will go for the 500s then and get the smoked shield. I actually prefer the look of the regular 500s to the ffs.
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs Yesitsdrew5310 Electrical & Lighting 601 07-30-2016 07:59 PM
The Ultimate DIY Water/Alc Injection Thread hippy Water/Methanol Injection, Nitrous & Intercooler Cooling 33 03-08-2008 03:11 AM
My new Hella FF200 Driving Lights and mounts wrxinfx Electrical & Lighting 14 04-17-2005 12:24 PM
WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. Yamaha600Biker Private 'Wanted' Classifieds 2 06-08-2004 03:37 PM
