Old 05-28-2011, 08:51 AM   #5176
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Here's my new setup. How it works is the bottom part stays on the car and the top part with the lights is held to the bottom part with two bolts so it's easy to remove. I still have to stop at Terminal Supply and pick up a big 4 pin connector for all the lights. The lights don't shake at all on paved roads or on ordinary dirt roads. While hauling ass down rutted trails they shake a bit, but the output is still plenty useful. I wanted something solid, good looking, and easy to remove since I don't always need lights. This bar definitely fills those criteria so I'm happy.
For those who don't know my previous setups, this goes between the bumper beam and the license plate holes. It adds a ton of rigidity and I can stand on it.
573 is offline   Reply With Quote
Old 05-28-2011, 02:53 PM   #5177
ag04
Member#: 182051
2006 WRX Sedan
SGM
Do you have any measurements for that last piece? That was going to be my next addition, as soon as I can get the time to weld one up. Why does it look angled down in the picture? It could just be the photo angle. Looks sturdy otherwise
ag04 is offline   Reply With Quote
Old 05-28-2011, 04:03 PM   #5178
2point5RS_Dan
Member#: 237205
2002 Impreza
BRP
Originally Posted by Superorb View Post
2pt5RSdan
^^ Looks good, have any pics of the mounting and without the lamps mounted?
I made these brackets to hold two lights with the thought that I'd throw a crossbar on and add two more eventually. The brackets are 1/4 inch steel flat stock that just bent and drilled. Not the lightest in the world, but they don't wobble at all.
When I got the second set of lights, I just got an angle bar, cut to length, drilled 6 holes (four for lights, two for mounts). Two bolts hold the bar to the brackets, and I wired the lights in using a 4 plug trailer wiring harness, the the whole bar is quick disconnect with just two 17mm wrenches, which I like for when I park in the city or do long highway trips and don't want the attention.
I'll try and get some pics of the setup up close, but my phone camera sucks and it's pretty easy to remake with just what I described above.
Originally Posted by tommyson01 View Post
Originally Posted by 2point5RS_Dan View Post
Which lights did you pick up and do you have any down range shots?
Inners are 500FFs and outers are older 500s. I got the lights for dirt cheap locally. It's an okay setup, good enough for what I do.
2point5RS_Dan is offline   Reply With Quote
Old 05-30-2011, 07:15 PM   #5179
subiidude
Member#: 141472
2008 shagg wgn STI
OG FP20g+e85 corn booze
Originally Posted by premier00000 View Post
Just noticed my Rally Innovations light bar is starting to rust pretty bad where the welds are... Any one have any ideas on what I can do?
Thought about covering the whole bar in undercoat, or bedliner. Just wondering what other options I'd have.
(And I've only had it since mid august.)
ive had mine for a few months now and it's staring to rust on the inside, where they didn't cap off they bar like they should have so water could collect if left outside.... for $260 you think they would have
and a little whoring
subiidude is offline   Reply With Quote
Old 05-30-2011, 07:25 PM   #5180
premier00000
Member#: 251060
2008 Impreza Outback
My thoughts exactly, should have had a local speed shop make me a better bar that is more secure, and better quality for less than half the price.
I'm gonna hit the entire bar with a heat gun to make sure there's no moisture in it and then spray the inside with foam, and outside with primer and undercoat... Or have it re-engineered altogether.
premier00000 is offline   Reply With Quote
Old 05-30-2011, 07:30 PM   #5181
Adventure Dave
Member#: 280061
2006 WRX
Dang. That looks pretty clean subiidude. Maybe you should have gone with the oswald bumper beam $240 shipped and you get to save a bunch of weight.
Anyway. Some people were asking about what the light throw really looked like on the Hella 500's. (plus I got a flat tire on a drive and time to take pictures. Sorry for the craptastic phone camera)
Low beams
Lows highs and 500's pointed to the sides of the highs as fill
Lows and 500's (no highs, for reference)
Lows, highs and 500's pointed straight
Adventure Dave is offline   Reply With Quote
Old 05-30-2011, 07:54 PM   #5182
flimflamman
Member#: 147328
2007 WRX
FlimFlamRacing
Mine is rusting in spots as well. With it being up front taking on road debris coupled with harsh salty mid-west winters, I knew it was just a matter of time. I'll probably sand it down and put some Rust Bullet on it. I'm not sure what I'll cover that with though.
flimflamman is offline   Reply With Quote
Old 06-01-2011, 05:42 PM   #5183
DUSTIN 217 WRX
Member#: 243062
2007 Impreza WRX
Grey
Default Sweet
I Like the rides guys!
DUSTIN 217 WRX is offline   Reply With Quote
Old 06-01-2011, 07:36 PM   #5184
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
Disregard the 3" measure and cut that to 2.5". I had to hack about half an inch out of it to make the bumper fit properly.
It angled down a bit. That's likely due to me cutting out that half inch of material with a plasma cutter without measuring or making anything. Next time I have it off, I might fix that.
Old 06-01-2011, 09:37 PM   #5185
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Care to fab up another one?
Superorb is offline   Reply With Quote
Old 06-01-2011, 09:44 PM   #5186
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
If I had a band saw, welder, and material on hand, I would. Unfortunately, I don't have any of that. I cut this one with a hack saw and had my friend weld it.
Old 06-01-2011, 10:22 PM   #5187
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Ahh..
Old 06-02-2011, 01:47 PM   #5188
KangaRu99
Member#: 276688
99 prezzy wagon
Sedona Red
just found some Hella 550s in my garage. obviously gonna attempt to install them on my subby. but, i got a couple of questions.
1. how many auxiliary lights can the battery support? i assume the two 550s should be fine.
2. did y'all just use the Hella switch that comes with the lights...
3. OR did you get your hands on a factory switch?
i have more questions but can't think of them right now. thanks in advance.
KangaRu99 is offline   Reply With Quote
Old 06-02-2011, 01:57 PM   #5189
premier00000
Member#: 251060
The lights and all other electrical components get their power from the alternator when you're driving. Pretty much all the battery does is start the car, and makes voltage spikes less harsh.
I used the Hella switch, I mounted it on the fuse panel cover.
Old 06-02-2011, 04:02 PM   #5190
KangaRu99
Member#: 276688
99 prezzy wagon
Sedona Red
So two 550s will work fine?
Old 06-02-2011, 04:08 PM   #5191
premier00000
Member#: 251060
I'm sure 4 or 6 are fine.
Old 06-02-2011, 04:21 PM   #5192
KangaRu99
Member#: 276688
99 prezzy wagon
Sedona Red
thats what i assumed. my alternators rated for like 75amp. i dont know how much the two 550s are pulling, but i think even with nighttime driving systems, i feel like it'll be fine
Old 06-02-2011, 04:47 PM   #5193
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Four is pushing it, especially when you consider you're likely using high beams along with four lamps. That's 25A for the 6 lamps alone, not to mention any other systems that require power.Also keep in mind that the alternator may be rated for 75A, but those 75A are not delivered at idle, usually around 3000rpm+. Six lamps + high beams is roughly 33A, and if your car also runs the low beams when the highs are on that's another 8A draw.
Old 06-27-2011, 02:10 PM   #5194
arpke
Member#: 211182
2006 STI
CGM
My $25 light bar. The actual lights were the expensive part.
Ignore the wiring, I still needed to buy some longer zip ties at that point.
arpke is offline   Reply With Quote
Old 06-27-2011, 04:22 PM   #5195
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
^^ Did you fab that up yourself?
Old 06-27-2011, 06:17 PM   #5196
02boxer
Member#: 139853
2002 wrx....its tsxy
yeah, he took his sweet time on it too
02boxer is offline   Reply With Quote
Old 06-27-2011, 09:45 PM   #5197
arpke
Member#: 211182
2006 STI
CGM
'Tis true. I started it last year with the hopes of having it finished before LSPR (mid-October). When I realized that wasn't going to happen I just let it sit for the winter and dusted if off in the spring.
Basically it's a display of "what you can do with a harbor freight welder and tube bender." I think it's pretty obvious the inspiration of the overall design was inspired by the rally innovations bar, but with a few tweaks. I bumped the tube OD and wall thickness up from the RI's 1.25" and 0.050" to 1.5" and 0.065". I thought the larger tube looked a little more proportionate on the car. Secondly, the main mount is a receiver-style on the two top tubes you see going into the lower grill area (going to a couple brackets I made that attached to the bumper beam at three points). There are also two arms on the bottom that attach underneath.
The thing is absolutely rock solid. Now I just need to get out on some back roads to enjoy the simulated sunlight those 4000's put out!
Old 06-28-2011, 03:48 AM   #5198
fastwrx25
Member#: 126441
03 bugeye
Originally Posted by Adventure Dave View Post
My turn!
I didn't want the slightly heavier/ more expensive Rally Innovations light bar. But I did want the Oswald performance bumper beam. Why not combine the two?
Added extra "tow hook" bosses
Simple barstock bracket.
/he hella's wire to come on with the fog light switch which was silly
Wired to come on with the high beams, MUCH better.
brilliant idea.....killing two birds with one stone.
fastwrx25 is offline   Reply With Quote
Old 07-02-2011, 05:39 PM   #5199
KangaRu99
Member#: 276688
99 prezzy wagon
Sedona Red
finally mounted up my 550s.
piece of pipe in my garage = $0
legs from an old lamp beat into shape = $0
can of paint i already had = $0
various nuts/bolts = $0
Not the cleanest or perfectly level light bar, but it's rigid and will do its job wonderfully. I'd say I'm happy with zero dollars spent and about two hours of work.
IMG-20110702-00434 by Fnavazio, on Flickr
IMG-20110702-00431 by Fnavazio, on Flickr
(the two legs are mounted under the grill into the bumper, then the pipe was welded to the legs to form 1 piece. the lights are then mounted thru the pipe)
Old 07-02-2011, 10:46 PM   #5200
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
simple and effective is the name of the game!
aerosaaber is offline   Reply With Quote
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs Yesitsdrew5310 Electrical & Lighting 599 05-15-2016 12:28 AM
The Ultimate DIY Water/Alc Injection Thread hippy Water/Methanol Injection, Nitrous & Intercooler Cooling 33 03-08-2008 03:11 AM
My new Hella FF200 Driving Lights and mounts wrxinfx Electrical & Lighting 14 04-17-2005 12:24 PM
WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. Yamaha600Biker Private 'Wanted' Classifieds 2 06-08-2004 03:37 PM
