Old 07-06-2011, 10:00 AM   #5201
rvines19
Member#: 287469
2007 Impreza Wagon
Urban Gray
Default looking to add fog lights to 2007 2.5 wagon
First time posting, I have a 2007 2.5 wagon with NO fog lights. I wanted to add fog lights to the factory location, but don't want to use the factory light kits. How can I mount fogs in the factory location and which lights (i prefer round) will work the best? What size?
Thanks and if i posted this in the wrong forum, I will try to improve for future posts.
rvines19 is offline   Reply With Quote
Old 07-12-2011, 05:17 PM   #5202
edberg
Member#: 258229
2006 WRXWagon6MT*RIP
>2007 FXT 4EAT
edberg is offline   Reply With Quote
Old 07-25-2011, 09:26 PM   #5203
banman
Member#: 12408
2006 Legacy GT
So, this is actually about lights on my Hilux, but lights are lights, right?
I just replaced the driving lights that the previous owner had installed, which should have been as simple as just swapping the old connectors for new ones. However, I encountered a strange problem. I wired up the first light and tested it; it worked fine. However, when I connected the second light, the fuse promptly blew. Initially, I thought I might have swapped the polarities on the second light, but I didn't. The fuse is the correct rating for the lights (20A; the lights are 2x100W).
If I turn the aux light switch on, I'm getting 12V to the wires, so the relay is switching correctly. However, when I connect a bulb, the bulb doesn't light up (and I know the bulb is good).
The old lights used to work - could it be a bad relay? Either that, or there's something weird with the way the old ones are wired that I'm not aware of.
banman is online now   Reply With Quote
Old 07-26-2011, 10:20 AM   #5204
m_tee
Member#: 161289
2005 Impreza 2.5RS
RI bar + 2 hella 500's
m_tee is offline   Reply With Quote
Old 07-26-2011, 11:55 AM   #5205
RichardM
Member#: 39915
2007 Legacy GT
The fuse is almost too small for two lights. Yes, it can handle the lights once they are on but it will have trouble with the inrush. The lamps have a very high current when first turned on.
The next problem is most likely due to the ground. The old lights may have grounded through the light body while the new ones need a ground wire connected. Or vice versa and the mounting bracket is not grounded.
RichardM is offline   Reply With Quote
Old 07-26-2011, 08:22 PM   #5206
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
I would also suggest looking at the ground, or just redoing it with a fresh connection.
aerosaaber is offline   Reply With Quote
Old 07-26-2011, 10:08 PM   #5207
DSRX2005
Member#: 271681
2013 WRB Subaru WRX
AJW Performance
Uploaded with ImageShack.us
DSRX2005 is offline   Reply With Quote
Old 07-29-2011, 06:55 PM   #5208
The1SloR/T
Member#: 251879
1998 Neon R/T 178whp
2010 Wrx Sedan WRB
I gotta figure out something to do with a 2010..
I want it so I can remove it by just a few bolts and you'll never know it's there.
It's not something I wanna run around with all the time. but when I got on trips or decide to go out on some back country roads a little more lighting wont hurt.
The1SloR/T is offline   Reply With Quote
Old 08-01-2011, 12:47 PM   #5209
timpone
Member#: 245676
09 STI
SSM
just got done with this last night 2 hella 500FF
timpone is offline   Reply With Quote
Old 08-09-2011, 12:52 PM   #5210
go1d1e
RIP 2/21/14
Member#: 91263
02 WRX Wagon
Got my lights mounted on a bar finally.. Not wired up yet, but they are on!
go1d1e is offline   Reply With Quote
Old 08-10-2011, 12:14 AM   #5211
Mike Costin
Member#: 131787
06 STI,OB,OME XJs
Merkur Junkyard
Riveting!
Mike Costin is offline   Reply With Quote
Old 08-27-2011, 12:58 AM   #5212
FLHRSI
Member#: 284321
I mounted some PIAA reverse lights.
FLHRSI is offline   Reply With Quote
Old 08-27-2011, 01:01 AM   #5213
FLHRSI
Member#: 284321
And some Hellas up front.
Old 08-27-2011, 01:42 AM   #5214
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
So covet anything from Hella starting in "Rallye"
Old 08-27-2011, 02:16 PM   #5215
Xcelr8to1320
Member#: 131272
2003 WRX Wagon
Xcelr8to1320 is offline   Reply With Quote
Old 08-27-2011, 02:40 PM   #5216
Scooby207
Member#: 255687
11 WRX DGM
^ very nice mounting job. Any more info or pics?
Scooby207 is offline   Reply With Quote
Old 08-28-2011, 01:06 PM   #5217
premier00000
Member#: 251060
2008 Impreza Outback
whats the best way to get water outta the Hella 500FFs and the factory fogs on an '08? Irene decided to flood the parking lots here, and i have a bunch of water in my fogs.
premier00000 is offline   Reply With Quote
Old 08-29-2011, 07:04 PM   #5218
SemperGumby
Member#: 292894
2009 Impreza WRX
Double post. Removed.
SemperGumby is offline   Reply With Quote
Old 08-29-2011, 07:07 PM   #5219
SemperGumby
Member#: 292894
2009 Impreza WRX
I like the simplicity of this mount. How'd you throw those puppies on?
Thanks!
Old 08-29-2011, 07:34 PM   #5220
MFR Sweep
Member#: 103510
2006 rex
Aspen Brake Dust
the factory fogs are pooched. they corrode in no time
and the 500's are probably as well. but if they have the plastic reflector, you can probably wash them out by disassembling them and filling it with clean water from the bulb hole. get a few bottles of rubbing alcohol and rinse with that and let air dry (bulb hole down) after pouring out the alcohol (absorbs the remainder of the water).
MFR Sweep is offline   Reply With Quote
Old 08-29-2011, 07:39 PM   #5221
premier00000
Member#: 251060
Actually took the 500ff's out and filled them with clean water and dumped them out, and then dried them with a hair drier, Also the factory fogs r cracked but now empty, and replaced the bulbs and all seems well with everything.
Old 08-29-2011, 09:16 PM   #5222
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
how deep was the water?
might want to contact insurance, wiring harnesses and stuff may or may not be truly water proof when in standing water.
Old 08-29-2011, 09:29 PM   #5223
premier00000
Member#: 251060
It was probably 18-20 inches deep, but I ended up driving thru it and everything seems fine today, drove around for about an hour or 2... And everything seems fine including the electronics.
Old 08-30-2011, 01:00 PM   #5224
Teryn It Up
Member#: 225919
2000 2.5rs
Psh... F Kartboy brackets
Teryn It Up is offline   Reply With Quote
Old 08-30-2011, 08:42 PM   #5225
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
that's a lot of water, did it get into the interior?
The wiring inside definitely isn't as protected as other stuff.
If it's working fine now that's probably a good sign, but I'd probably still get it on a lift and inspect connectors inside and out just to be sure.
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs Yesitsdrew5310 Electrical & Lighting 599 05-15-2016 12:28 AM
The Ultimate DIY Water/Alc Injection Thread hippy Water/Methanol Injection, Nitrous & Intercooler Cooling 33 03-08-2008 03:11 AM
My new Hella FF200 Driving Lights and mounts wrxinfx Electrical & Lighting 14 04-17-2005 12:24 PM
WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. Yamaha600Biker Private 'Wanted' Classifieds 2 06-08-2004 03:37 PM
