Old 08-30-2011, 10:43 PM   #5226
premier00000
Member#: 251060
2008 Impreza Outback
Originally Posted by aerosaaber
that's a lot of water, did it get into the interior?
The wiring inside definitely isn't as protected as other stuff.
If it's working fine now that's probably a good sign, but I'd probably still get it on a lift and inspect connectors inside and out just to be sure.
Nope. No water inside. Last time i had water inside was when i accidentally left the windows down for a weekend a couple months ago, and it POURED. But was dry within a few hours.
I replaced the door seals last year when I bought it. Checked the oil and tranny fluid and both are fine also.
premier00000 is offline   Reply With Quote
Old 09-02-2011, 09:37 PM   #5227
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
then you are one lucky son of a gun
aerosaaber is offline   Reply With Quote
Old 09-02-2011, 10:02 PM   #5228
premier00000
Member#: 251060
That's what my GF said... Haha... BTW replaced the bulbs in the OEM fogs with modified 9005 bulbs, and haven't had any issue and they perform much better than stock.
Old 09-04-2011, 11:51 PM   #5229
timpone
Member#: 245676
09 STI
SSM
Originally Posted by SemperGumby View Post
I like the simplicity of this mount. How'd you throw those puppies on?
Thanks!
i just took a piece of flat stock and bolted them to the bumper beam since i have a fmic it was easy enough. i gotta take my bumper off to fix some things up soon so ill take some pics if i remember lol
timpone is offline   Reply With Quote
Old 09-06-2011, 08:26 PM   #5230
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
removed the "tab" inside the connector on the bulb?
I did that in any car that used the 9006 as a low beam, always made a nice improvement.
Old 09-06-2011, 08:39 PM   #5231
premier00000
Member#: 251060
That and took off a part on the top tab. I've done it on every car also.
Old 09-19-2011, 02:32 PM   #5232
mstinger
Member#: 161390
05 STI
06 Tribeca
Default Piaa lights
I finally got my bar made and the lights mounted.
mstinger is offline   Reply With Quote
Old 09-19-2011, 10:03 PM   #5233
carl s.
Top Scoob 026
Member#: 119034
96 Open Class STI
carl s. is offline   Reply With Quote
Old 09-19-2011, 10:19 PM   #5234
02boxer
Member#: 139853
2002 wrx....its tsxy
^^^^^^^NIIIIIIIIIIICE!!!!!!!!
I'll have 10" of hotness working this week....led hotness
02boxer is offline   Reply With Quote
Old 09-19-2011, 11:53 PM   #5235
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Looks good. Do you have any pics of mounting points?
Superorb is offline   Reply With Quote
Old 09-20-2011, 12:29 AM   #5236
mstinger
Member#: 161390
05 STI
06 Tribeca
I don't at the moment but it is mounted to the licence plate holes and the radiator support. I didn't drill any new holes.
Old 09-21-2011, 09:26 AM   #5237
cubb
Member#: 184586
Thinking about adding two hella 500ff fogs to my 08 2.5i sport. So logically they would be mounted down low. I live in southern ontario where we get a lot of snow, just wondering how these lights will hold up to winter, driving through snow drifts and such. Thanks
cubb is offline   Reply With Quote
Old 09-21-2011, 12:00 PM   #5238
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
It's not the snow that kills them, it's rocks kicked up from other vehicles that will kill them.
Old 09-21-2011, 12:02 PM   #5239
MFR Sweep
Member#: 103510
2006 rex
Aspen Brake Dust
to this point, get the clear polycarbonate covers for them and you should be fine.
MFR Sweep is offline   Reply With Quote
Old 09-21-2011, 12:33 PM   #5240
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
I used to have low mounted Hella 500's. I lost one to a rock chip and two to snow banks. The plastic housings break very easily in the event of an impact--even small ones. If you ice race or compete in winter rally-x events, you should consider something else.
573 is offline   Reply With Quote
Old 09-21-2011, 01:53 PM   #5241
cubb
Member#: 184586
Well i'm not going to be doing any racing at all, this is more for long back road drives up to blue mountain for the winter. Right now i have a stock fog light that is broke due to an impact with a rock. If i were to get the 500ff i would get the clear plastic covers. Just wanted to hear from someone that used these light down low in the winter.
Old 09-21-2011, 03:21 PM   #5242
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I have the clear plastic covers for my 500FF fogs in the stock location in my bugeye. Last winter I made several trips to the ski resorts, and two times were through heavy snow storms. They still work and look fine.
Old 09-21-2011, 03:51 PM   #5243
cubb
Member#: 184586
Ya i figure the plastic covers would be good for taking the snow and rocks. just don't know how plowing through snow drifts is going to go over?? living in the country can be fun lol. Just want to make sure they would stand up to that sort of abuse?
Old 09-21-2011, 06:32 PM   #5244
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
There's only so much abuse that you can reasonably expect any lamp to survive. And if you kill the lamps hitting something, there's a chance other things will also not survive the encounter.
Old 09-21-2011, 07:07 PM   #5245
cubb
Member#: 184586
You are very right. I think they will be fine. Now i need to figure out how i want to mount them. I like the look of the Ri light bar, but i don't like the price. Was thinking of two tabs that exit though the lower grill to mount the lights on. I think the Ri light bar would be a better mount as far as vibrations go. Any thoughts?
Old 09-22-2011, 11:18 AM   #5246
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Have you hunted around this thread for ideas? There are literally hundreds.
Old 09-22-2011, 11:50 AM   #5247
Twrexx2
Member#: 250077
2003 Stage2 bug
96 L Stage rally prepped
for the people with the Hellas on the roof rack: How does the light spread over the road? and does it distract you at all? Im looking to do this in the next week or so and I still dont know how Im going to mount them either. Any help is apreciated
Twrexx2 is offline   Reply With Quote
Old 09-22-2011, 02:12 PM   #5248
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
You don't plan to use them while on public roads do you?
Old 09-22-2011, 06:13 PM   #5249
Xcelr8to1320
Member#: 131272
2003 WRX Wagon
They're great, but as its brought up above, no lights while there's traffic.
But I did like mine:
Xcelr8to1320 is offline   Reply With Quote
Old 09-22-2011, 08:41 PM   #5250
wumfpirate
Member#: 179656
2010 WRX hatch
nice setup mstinger
What size lights are those on the side?
wumfpirate is offline   Reply With Quote
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs Yesitsdrew5310 Electrical & Lighting 602 09-06-2016 01:43 PM
The Ultimate DIY Water/Alc Injection Thread hippy Water/Methanol Injection, Nitrous & Intercooler Cooling 33 03-08-2008 03:11 AM
My new Hella FF200 Driving Lights and mounts wrxinfx Electrical & Lighting 14 04-17-2005 12:24 PM
WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. Yamaha600Biker Private 'Wanted' Classifieds 2 06-08-2004 03:37 PM
