Old 06-18-2013, 10:54 AM   #6151
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Has anyone played with these?
http://www.superbrightleds.com/morei...rk-light/1508/
Output wise they seem very similar to the SR-M2, though surely leave some build quality to be desired over the Rigid's. I'll probably pick a couple up to mess with.
mechatricity is offline   Reply With Quote
Old 06-18-2013, 05:48 PM   #6152
02boxer
Member#: 139853
2002 wrx....its tsxy
not those...but I do hase a 2" 10w lamp....it's solid as fffff and nice and bright. Wiring from the body out is great too. It's basically a visionX lamp minus the logo...has the same expandability too.
Having said that I am sure it's not bad, but likely will lack useful reach. It'd probably be a good supplementary lamp, for hitting the sides of the roads or cornering.
02boxer is offline   Reply With Quote
Old 06-18-2013, 08:13 PM   #6153
mechatricity
Member#: 290592
15 Outback,
15 WRX 6MT CWP
Thanks for the info!
Old 06-23-2013, 12:08 AM   #6154
Twrexx2
Member#: 250077
2003 Stage2 bug
96 L Stage rally prepped
mounted my hella 500ffs the other day. I'm pretty pleased with the look, not sure about the output yet tho. I'm still toying with it
Twrexx2 is offline   Reply With Quote
Old 06-28-2013, 04:43 AM   #6155
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
man...I got that rigid 6" and I don't think its enough...and for $208??
imma git me a one of these 6" oval in spot and throw it on with the rigid and see what's up with that I think......for $44 shipped after finding a 5% off coupon...meh...if it sucks I can use it as a back up light
Old 07-13-2013, 07:58 PM   #6156
scoobywagon02
Member#: 317757
2002 Impreza 2.5TS
Savanna Green
Moar lights
scoobywagon02 is offline   Reply With Quote
Old 07-17-2013, 11:14 PM   #6157
RavensFan7
Member#: 346388
2001 Ej205 Impreza L
SRP
Installed 2 dually flood pattern lights today. Might end up moving them somewhere else though...
They're so light and small I just mounted them straight to the bumper with a big washer underneath, and wedged under the bumper beam. No shake, and they're pretty damn bright.
Pics are bad and don't do them justice, but I'm happy with them.....think I still want more lighting though.
First one is just the high beams, second is high beams + the dually's.
The Hellas aren't even on in these pics because at this point they don't do much lol.
RavensFan7 is offline   Reply With Quote
Old 07-17-2013, 11:26 PM   #6158
02boxer
Member#: 139853
yeah...duallys aren't bad....but not enough....and since I switched to led bars...I'll only want halogens for looks
Old 07-17-2013, 11:33 PM   #6159
RavensFan7
Member#: 346388
SRP
ill only want halogens for looks
That's literally the only reason I'm keeping the Hellas....they just get overpowered by the headlights and LED's now.
I think eventually ill replace the Hellas with 2 of these:
Skip to 55 sec.
Edit 2: ....or maybe 2, 6" sr-series bars.
Old 07-18-2013, 07:58 AM   #6160
RavensFan7
Member#: 346388
SRP
Ok, got a few questions about the dually's:
1. It came with a 15 amp fuse and I accidentally blew it lol.....touched the hot wire to the ground terminal on the switch.
Can I use a 5 amp fuse instead?
....per lamp, they use 1.45 amps, so 5 amp fuse should be plenty right?
2. The connector (grey and black) from the lights to the rest of the harness.....is it waterproof??
It has that orange rubber stuff which makes it seem watertight.
Old 07-18-2013, 08:53 AM   #6161
evilspoons
Member#: 321311
2012 STi 5-door
World Rally Blue
Yes, that connector is waterproof.
And you should be able to use a 5 amp assuming they don't immediately blow it on startup (inrush current). Worst that'll happen is you pop the 5 amp fuse and need a 10 or 15.
evilspoons is offline   Reply With Quote
Old 07-18-2013, 10:36 AM   #6162
RavensFan7
Member#: 346388
SRP
Well I put in the 5 amp and the inrush didn't blow it, so I guess it works. My multimeter doesn't work for DC amperage so I can't check the exact draw.
I'll probably throw in a 10 amp when I get home.....just as soon as I find the bag of fuses I had laying around.
I also just moved the switch this morning. I had it above the change holder/fuse box, next to my switch for the Hellas.....but since the Dually's are so bright I need to be able to switch them off quickly, so I don't blind people.
Didn't have much room for it here, any more to the right and I would start hitting stuff under the center console, and the wires would be more crammed.
Doesn't look the best, but these lights are for pure function at night, so looks don't matter.
Old 07-18-2013, 12:12 PM   #6163
RavensFan7
Member#: 346388
SRP
Ok, I got another question, this time about my hella lighting circuit.
They are wired completely independent, and to their own switch.....but they ONLY work if atleast the parking lights are turned on (switching to headlights keeps them on also).
If the parking lights are off and I flip the switch for the Hellas, they don't come on.
Why do the parking lights need to be on?
I actually like this way better, so i can't accidentally leave them on. I'm just trying to understand how and why they work like this.
I have power coming right from the battery, and the ground is taken from the screw/bolt holding down the fuse box.
This screw:
Does it have something to do with the ground being where it is?
I want to move my ground for the Rigid's to the same place to have the same effect.....currently I just followed their instructions and connected both hot and ground to the battery, and I have a feeling ill forget to turn them off one night.....
Old 07-18-2013, 12:43 PM   #6164
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
They work perfectly fine but I just don't understand why at least the parking lights have to be on?
using that screw as a ground has zero things to do with the lights turning off when the parking lights are off...
For the switch you used, you probably pulled the power from something that uses the parking lights.
Zefy is offline   Reply With Quote
Old 07-18-2013, 01:21 PM   #6165
RavensFan7
Member#: 346388
SRP
Edit:
Nevermind I'm dumb....forgot where the other switch wire went. It went behind a blank switch cover and connects to something that gets power when the parking lights are on, and is only visible if I take both the switch out and the correct blank cover out.
Forgetting about the 3rd switch wire really confused me. I was making my own head explode trying to imagine the circuit with only 2 wires on the switch.
I'm good with AC circuits but DC.....no so much lolol.
Now I just need a wire from my Rigid switch to the same place my Hella switch goes and all will be good.
Old 07-19-2013, 12:50 AM   #6166
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
My bro just ordered this for my birthday!
http://www.ebay.com/itm/321154519972...S:3160&vxp=mtr
Planning to fit this to my lower grille area
KartRacer3 is offline   Reply With Quote
Old 07-19-2013, 10:27 PM   #6167
gregroot198521
Member#: 280844
2006 STi
Invisilink!!!
gregroot198521 is offline   Reply With Quote
Old 07-20-2013, 12:25 AM   #6168
KartRacer3
Member#: 268328
2011 2.5i prem pckg
SSM
Originally Posted by gregroot198521 View Post
Invisilink!!!
http://www.ebay.com/itm/321142423288?redirect=mobile
For some reason the mobile app doesn't like eBay links :/
Old 07-21-2013, 06:57 PM   #6169
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
Hella 1000 black magic
Hyper is online now   Reply With Quote
Old 07-21-2013, 07:41 PM   #6170
TheBOOSTisLOOSE
Member#: 343493
Platinum Silver Metallic
Default My Projector HID retrofit outcome.
Just recently retrofitted my Bugeye with projectors and HIDS. I went with the painted black trim and gatling shrouds. heres what it looks like:
Before:
After:
TheBOOSTisLOOSE is offline   Reply With Quote
Old 07-29-2013, 03:55 PM   #6171
fawcetteng
Member#: 340212
2004 WRX
Default 2004 home made bar
Here is my go at it - home made bar to hold a pair of Hella 500's with 100 watt bulbs. Its a cosmetic only bumper guard, as in wouldnt protect anything in an accident, but is plenty sturdy for the lights. I found the original bulbs under impressive so have some cheap 100W ones in. Much better. Put a 3-way rocker switch in the dead spot next to the cruise control power. One direction allows these to turn on when the brights come on, killing the normal lights to be legal in states that allow only 4 front lights on. The other way turns them on all the time.
fawcetteng is offline   Reply With Quote
Old 07-29-2013, 05:42 PM   #6172
evilspoons
Member#: 321311
2012 STi 5-door
World Rally Blue
...do you have lumber tied to your spoiler??
EDIT: found one of your other posts, I see you have some sort of rack on there. Interesting!
Old 07-29-2013, 11:48 PM   #6173
KenSekiguchi
Member#: 175331
2002 WRX STi - WRB
JDM V7 EJ207/13' Felt Z85
I have a question for all the Auxiliary Lighting aficionados in this thread. I own a MY02 WRX and am considering upgrading my OEM Fog Lights for something with a larger housing that will offer a higher light output with a wider and longer light spread than what the OEM Fog Lights offer. I would prefer that they fit inside the recessed area in the front bumper, but I could fabricate a bracket so that they would sit in front of said recessed area. I know that the go to upgrade are the Hella 500FF's, but I'm wondering if there are any other alternatives that offer a higher light output with a wider and longer light spread. Any help or recommendations will be greatly appreciated. Thanks in advance.
Ken Sekiguchi
KenSekiguchi is offline   Reply With Quote
Old 07-30-2013, 12:26 AM   #6174
CanadianSTiEh
Member#: 363584
13' STi
my old setup
CanadianSTiEh is offline   Reply With Quote
Old 07-30-2013, 12:35 AM   #6175
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
Ken Sekiguchi
hella used to make a bracket that would allow you to put a ff1000 in the stock fog light location. The driving beam on those is pretty awesome. Of course those are hard to find these days. Can't get them for cheap from rallylights.com anymore.
Do you want a fog or driving pattern?
aerosaaber is offline   Reply With Quote
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs Yesitsdrew5310 Electrical & Lighting 598 04-09-2016 08:25 PM
The Ultimate DIY Water/Alc Injection Thread hippy Water/Methanol Injection, Nitrous & Intercooler Cooling 33 03-08-2008 03:11 AM
My new Hella FF200 Driving Lights and mounts wrxinfx Electrical & Lighting 14 04-17-2005 12:24 PM
WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. Yamaha600Biker Private 'Wanted' Classifieds 2 06-08-2004 03:37 PM
