Old 07-01-2001, 11:01 AM   #1
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
Exclamation S-AFC Wiring
Ok I'm almost done installing this damn thing. There is one problem....
the Air flow signal(B136 #5) I see where it starts but where does it go? I cannot find it once you pass all the clamps and plastic tapes! I opened the end up on the ecu and see that it ends up being taped up and then seems to connect to something else.
If anyone has info on this help is much appreciated.
WRC 555 is offline   Reply With Quote
Old 07-01-2001, 11:24 AM   #2
JGard
pooptastic
Member#: 1904
2013 Tundra
'02 BMW R1100S
your best bet is to take off that tape. it'll make things much easier for you.
JGard is offline   Reply With Quote
Old 07-01-2001, 11:58 AM   #3
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
Ok I got it working now. I initialized it and turned off the car and turned it back on and now the problem is that my throttle position sensor is reading at 5.115 at all positions. Whenever I press the gas pedal is remains constant.
Did I do something wrong?
Thanks
Old 07-01-2001, 04:12 PM   #4
Avenger
Member#: 1234
Double check your wire for the TPS, you might have tapped into something else.
Avenger is offline   Reply With Quote
Old 07-01-2001, 09:31 PM   #5
WRC 555
Member#: 94
1999 2.5 RS-T RBP
EJ257 Hybrid Link'd
Yeah it works now. I had it spliced into the right wire but I guess they were not making good contact so I changed the location and everything is good...no engine light either.
I borrowed a G-Tech from a friend so I'm gonna try to "tune" it that way. Any one have a better way instead of paying ~$200 on a dyno? I figured the G-Tech can do horsepower rating so I'll find a strip of road and keep testing on that same strip and pull the car the exact same way.
Does anyone know some descent number to put in for a MY99 2.5 RS with only a ScoobySport exhaust? I know every car is different but I just wanna know do you start to rich the car out starting at likr 4K RPM and higher till like 6K? I'm probably gonna need to get a A/F ratio gauge.
Anyways thanks for help!
Old 07-01-2001, 09:33 PM   #6
JGard
pooptastic
Member#: 1904
2013 Tundra
'02 BMW R1100S
you'll be better off with an A/F gauge. trying to tune with a G-tech is basically worthless. it won't tell you anything about how your engine is running, which is what you need.
S-afc wiring diagram from Lagging.com tmat3 General Forum Archive 0 02-28-2001 01:15 PM
Kartboy S-AFC Wiring??? Xscreamer Normally Aspirated Powertrain 5 02-22-2001 12:09 AM
I need an AFC Wiring Diagram BongMan Bay Area Impreza Club Forum -- BAIC 0 12-05-2000 12:49 AM
S AFC wiring diagram for MY00?? Momo North West Impreza Club Forum -- NWIC 1 08-29-2000 12:03 AM
Message Board Statistics All times are GMT -4. The time now is 10:56 PM.
