Old 11-29-2004, 08:59 PM   #1
bouncingsoul23
Member#: 71186
Default car won't start! 02 wrx
02 wrx won't start! drove down my block last monday, battery light and brake light came on. drove around the block and came home. turned off car and tried to restart it and nothing. no turning over, no cranking, no power! horn works and caution lights that's it. no interior light, no ignition, no radio, seriously nothing! tried jumping the battery didn't work. tried a new battery that didn't work either. checked about every fuse and they all look good. any help would be greatly apreciated. thank you.....
02 wrx tein suspension hks downpipe tanabe full exhaust perrin boost controller injen cold air intake strut bars
thank you again
bouncingsoul23 is offline   Reply With Quote
Old 11-29-2004, 09:24 PM   #2
dropmech
Member#: 41477
2006 Tahoe that
will pull your bumper off
If you have and know how to use a multi-meter, a good place to start may be your ignition system. Seeing as how everything else works, it's got to be something with that. Just my .02
dropmech is offline   Reply With Quote
Old 11-29-2004, 10:17 PM   #3
WRC51
Member#: 16373
Agreed. I think it's safe to say that your problem is electrical in nature. Just start at the battery & work your way back. I would think because your horn & hazzards are working you can rule out the actual battery....but check your fuses & grounds all the way back.
WRC51 is offline   Reply With Quote
Old 11-29-2004, 10:37 PM   #4
wrxturbo20
Member#: 68055
2002 wrx stage 2
WorldOne on back window
Try removing the steering wheel column cover, the lower one, and check power at your key switch. off position and on position. Maybe a bad connection in there?
wrxturbo20 is offline   Reply With Quote
Old 11-29-2004, 10:57 PM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Check the large main fuses in the underhood fuse box, they are the rectangular ones that don't look like regular fuses. Might have blown one of those.
Old 11-29-2004, 10:57 PM   #6
bouncingsoul23
Member#: 71186
Default i'll try tomorrow
thanks for the suggestions. i'll give them a try tomorrow. much appreciated.
Old 11-29-2004, 11:06 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
If you did blow a fuse there must be a reason, those fuses will not blow normally. If you find one blown some electrical troubleshooting is in order to find the cause and correct it.
Old 12-02-2004, 02:09 PM   #8
Drews_WRX
Member#: 20354
2005 SRT-4
POS Mopar stage 2
i kind of have the same problem...except my car doesnt do anything, no starter clicking, slight crank, nothing. But, the lights work, radio, windows, etc...the car never had a warning light flash.
This happens every now and then, one time it starts no prob, then nothing the next time. I thought it was a cold start issue.....well, went to the mountatins, the car sat for 10 hrs (sub 30 degrees), started...at my house last week it sat for 6-8hrs in mid 30s...didnt start, had to pop the clutch. This morning it sat for ~10 hrs in mid-upper 30s, started right up.
I wish subaru gave you a loaner, no questions asked.......but that would be too hard.
Drews_WRX is offline   Reply With Quote
Old 12-02-2004, 05:43 PM   #9
bouncingsoul23
Member#: 71186
Default Fixed!!
hooray! it's fixed. it was the fusable link...subaru replaced it under warranty and everything is great now. thanks for everyone's help, much appreciated.
Car won't start. All I get is a click. Ptero Electrical & Lighting 33 11-08-2010 10:16 PM
car wont start 02 wrx joe_black Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-12-2010 06:24 PM
Fuel pump won't start, blown fuse SBF 2, car won't start ClassicGC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-29-2008 10:18 PM
Car won't start - cranks but won't start dave_88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-12-2007 11:29 PM
Help! Car won't start after 02 sensor changed! twlai Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 11-27-2006 06:46 PM
