Old 11-30-2004, 03:36 AM   #1
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
Default 04 2.0ltr STI 11.93 @ 119mph
hey lads just give u some info on wot i did this previous wednsday nite at quit motoplex. Cars got unbelievable topend just cant get it off the line cleanly so its still bogging down.
2004 STI (aussie spec)
Engine:
2.0ltr with AVCS
Fp green turbo 7cm internally gated
Ecutek type 3
Perrin FMIC
Perrin silicon Intake
X-force titanium exhaust
Race Torque split dump pipe with modified wastegate housing
X-force equal length headers
Walbro 500lph in tank fuel pump.
Power 254kw atw in 5th done dyno dynamics in shoot out mode.
Tuned on 98 RON plus octane booster.
1/4 times:
E.T 12.128 @ 118.11mph 60' 1.943
E.T 12.093 @ 118.73mph 60' 1.958
E.T 12.023 @ 118.42mph 60' 1.915
E.T 11.934 @ 119.04mph 60' 1.932
Heres a link to the 11.93 slip
http://www.dotdxf.com/perthwrx/phoru...4224&start=480
regards
tino is offline   Reply With Quote
Old 11-30-2004, 03:43 AM   #2
supermarkus
Member#: 6971
2008 WRX STi
SSM
congrats! Shame about that 60'. Keep up the good work.
supermarkus is offline   Reply With Quote
Old 11-30-2004, 11:04 AM   #3
wrex03
Member#: 29963
04 sti
Nice times... With a little better 60 ft a 11.50 would be possible.
wrex03 is offline   Reply With Quote
Old 11-30-2004, 01:09 PM   #4
slickvic
Member#: 29727
2003 Impreza WRX
nice car mate.
slickvic is offline   Reply With Quote
Old 11-30-2004, 01:58 PM   #5
HD-sw20
Gone But Not Forgotten
Member#: 37056
Very Nice Setup. Good Luck at the track again and Nail those 60's.
HD-sw20 is offline   Reply With Quote
Old 11-30-2004, 03:00 PM   #6
IWRXIT
Member#: 48697
I GOT HELLO KITTY
SKILLS...
damn. thats some nice work.
IWRXIT is offline   Reply With Quote
Old 11-30-2004, 03:11 PM   #7
SpamMansXe
Member#: 15920
1999 White Mock 22B
2014 Plasma Blue GR STi
hot runs...wish i could have the turbo in and put some numbers like that up.
SpamMansXe is offline   Reply With Quote
Old 11-30-2004, 09:58 PM   #8
tino
Top Scoob 019
Member#: 43630
thats guys for your responses. My 60' times suck big time, the problem i was facing was gettin off the line cleanly. i think tyre pressures is a big problem and will raise them around 35psi to get sum wheel spin off the line.
im also goin to put in a kartboy short shifter and hopefully this will reduce the amount of throw having to change 6 gears
Old 12-01-2004, 01:40 AM   #9
CalcVictim
Member#: 57056
2006 Miata
Copper Red
awesome times, couldn't get to the clip because the site requires a login
CalcVictim is offline   Reply With Quote
Old 12-01-2004, 02:25 AM   #10
tino
Top Scoob 019
Member#: 43630
ill post it up if someone wouldnt mind hosting it for me
Old 12-01-2004, 02:43 AM   #11
OZGT
Member#: 33188
2004 OZ spec STI
WRC Blue
Very nice times tino.
How are you launching?I ran mine at the strip about a month ago and was getting around the 1.8-1.7 on most runs.I found that if i dump the clutch at 6k it gets a bit of wheel spin then grips, over 6k and it spins more but dosnt help with the 60ft time.Under 6 it will just bog.This was with std tyre pressure and a greasy surface(it was spitting a bit).
This is also with the std vf35 with around 200kw on AVO's dyno.
OZGT is offline   Reply With Quote
Old 12-01-2004, 04:04 AM   #12
tino
Top Scoob 019
Member#: 43630
hey OZ. doin very hard launches round 7000rpm plus then slipping the clutch a lil to get wheelspin. found the revs drop out of the useable band very easy thus stuffing the 60' times. But as they say practive makes perfect. hopefully.
Old 12-01-2004, 04:59 AM   #13
OZGT
Member#: 33188
2004 OZ spec STI
WRC Blue
Yep it takes alot of practice.The other factor with the 6spd i find is the 4th-5th change towards the end.I think you lose a bit of time with this as its not only a extra change but its also easy to miss a gear.
Old 12-01-2004, 04:44 PM   #14
GeorgeRex
Member#: 51695
2004 STi
Thumbs up
For the kilowatt challenged, 254 kW= 345 hp ( in this case, 345 whp)
Nice going for a 2.0 (or even a 2.5) !
GeorgeRex is offline   Reply With Quote
Old 12-01-2004, 11:57 PM   #15
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
if you can get the 60' down you will see some good improvement at the end of the track
Old 12-02-2004, 12:08 AM   #16
tino
Top Scoob 019
Member#: 43630
i hope so. What do you guys think i can do to improve my 60'. As i said previously im leaving the line at 7000rpm plus, but wot else in my technique is needed to be changed?
Old 12-02-2004, 10:18 AM   #17
Homemade WRX
Member#: 33782
96 bastard child
are you bogging the car at all when you launch?...
Old 12-02-2004, 10:54 AM   #18
avispon
Member#: 39011
Great times.
How much boost on the FP Green ??
avispon is offline   Reply With Quote
Old 12-02-2004, 11:08 AM   #19
Noize
Member#: 18123
2013 Evolution X GSR
EJ207 > *.*
Awesome engine and times; congrats!
Noize is offline   Reply With Quote
Old 12-02-2004, 01:19 PM   #20
bryan carbon
Member#: 34060
I'd be pissed.
bryan carbon is offline   Reply With Quote
Old 12-02-2004, 01:29 PM   #21
codean
Member#: 10186
what injectors are you running and what max duty cycle are your seeing?
codean is offline   Reply With Quote
Old 12-03-2004, 01:15 AM   #22
tino
Top Scoob 019
Member#: 43630
running around 1.75 bar of boost (alot i know). but i normally run around 1.5 bar.
The car seems to be bogging down off the launch, this might have to do with tyre pressures and the fact that this turbo needs around 5000rpm to get moving.
Im not sure of IDCs cos i dont tune the car, but my tuner thinks that there still at the safe limits (ill find out exactly wot they are). Im running standard pink 550s injectors. Im also using 98 RON plus octane booster.
Old 12-03-2004, 01:26 AM   #23
codean
Member#: 10186
pinks? you have some balls man........
Old 12-03-2004, 01:36 AM   #24
tino
Top Scoob 019
Member#: 43630
i thought so also mate but speaking to him many times he thinks that the setup is fine, hes also really conservative (i.e wont set it up to blow)
Old 12-03-2004, 08:03 AM   #25
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Im going to have to say that you are out of injector. Your car making 120 mph will put you in at high 300s low 400s for HP. I have maxed out 550s at stock fuel pressure at 370... on race gas wich tends to give you a little more room with smaller injectors than pump gas would.
Junior2JZ is offline   Reply With Quote
