Old 11-30-2004, 08:31 AM   #1
04Blackscubby
Member#: 74963
2004 STI
JAVA Black
Question What is the best tire size?
I am thinking about putting a set of 18 inch wheels on my 04 sti. What do you guys recommend for a tire size? I dont want to put a tire that is to small, but then again i dont want to put at tire on there that looks to fat. It will either be a 18x7.5 or 18x8 wheel. Thanks for any responses
04Blackscubby is offline   Reply With Quote
Old 11-30-2004, 09:26 AM   #2
Got Pink?
Member#: 72609
2005 STi
World Rally Blue
Well the best tire size is subjective especially considering what kind of tires you are getting and what the intended use is. For all seasons to be used in the winter i would stick with 225/40/18 as wider is not better in the snow. Also clearance is an issue with 18s and any decently wide tire. The 225/40/18s should fit fine as long as the your wheels are the proper offset. Some people run 235/40/18 and 245/40/18 to get more tire at the expense of a taller than stock setup. I know its not what you want to hear but the best size to get is probably 245/40/17 so you will be able to run a decently wide tire and easily clear the fenders even with lowering springs or coilovers. Plus 17s will be lighter than 18s for a given wheel choice and there are light 18s but not for cheap. Keep in mind that with a taller than stock tire and stock suspension your ride height will increase.
Nate
Got Pink? is offline   Reply With Quote
Old 11-30-2004, 11:07 AM   #3
04Blackscubby
Member#: 74963
2004 STI
JAVA Black
I should also ad that my car is lowered with the TEIN basics. so i need to have that play in with the tire size.
Old 12-01-2004, 03:28 PM   #4
Tire Rack Moderator
Member#: 1215
ext. 4362
225/40-18 is pretty popular
what is the stock tire size? for 02-05 wrx 16" rims? Scooby_Wong Southern California Impreza Club Forum -- SCIC 4 12-17-2007 06:10 PM
which is the best tire size 03bluwrx Tire & Wheel 5 06-07-2007 03:13 PM
What is the best tire for 16" dlight Tire & Wheel 16 01-11-2005 10:55 PM
what is the best gap size for spark plugs? Homemade WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-13-2003 08:06 PM
what is the best tire size and brand for stock rim? nav Brakes, Steering & Suspension 2 03-21-2001 08:33 PM
