Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 07-01-2001, 06:23 PM   #1
Member#: 6964
2001 impreza
pearl ridge blue
Default piston
i am planning to intall piston heads, valves, valves springs
camshalfs in my01
i want to go n/a then turbo
i want to prepare my engine for what the turbo is going to do to my engine
i going to put a nos kit in too
so what i am get to is that , if i develop such a hig compression ratio , i can 't go turbo, right?
anyone with advice or suggestions
takumi is offline   Reply With Quote
Old 07-01-2001, 09:11 PM   #2
Subie Blues
Member#: 6438
01 RS
That's right,, big compression a no-no with forced induction. On production cars adding turbos/SC, the limit is about 8-10psi safely with lots of control on ignition. Forced induction effectively raises the compression ratio. The big drag motors run 30-40 psi with CR's of 6 or 7. Since you are going into the motor, lower the CR to about 7 or 8 and you should get plenty of room for about 20 psi. Look for a knowledgeable shop to do the work and they will keep it straight. If on your own then find a book or two to calculate the effective ratio. Wish I had the money to go at it right now.
Subie Blues is offline   Reply With Quote
Old 07-01-2001, 09:30 PM   #3
Worst Mod Ever
Member#: 369
12 Vagon
I wouldn't go as low as 7:1 on compression ratio if the car is street driven. It would be very slow when not in boost. I am switching to 8.5:1 which should allow for pretty high boost pressures street driven on pump gas. I would guess a well managed 12-15psi wouldn't be impossible on pump gas with an 8.5:1 compression ratio.
When I finally get my internals and the car running again I can let you know how much off boost response is lowered by switching from 10:1 to 8.5:1
AaronB is offline   Reply With Quote
Old 07-01-2001, 10:14 PM   #4
Member#: 6935
1999 Impreza 2.5RS
Rally Blue
8.5 or 8.6 to one is supposed to be the ideal compression ratio for a supergharged or turboed motor.
imprezadan is offline   Reply With Quote
Old 07-02-2001, 09:38 AM   #5
Dirty Underwear Gang
An 8.5:1 compression ratio running 15psi on a 2.5L engine would get you somewhere close to 300hp & a broken tranny... Be careful.
FS VA: **NEW**2010 STi OEM pistons, rings, pins, and clips**$120 Shipped** moorebl Engine/Power/Exhaust 17 07-01-2010 09:01 AM
Ej251 Longblock, many many parts. EJ22t, Wiseco Pistons, STI Coils hustleshark206 NWIC Private Classifieds 7 06-14-2010 04:55 PM
STI 4 piston, Perrin 4 piston, or Wilwood 4 piston nos Brakes, Steering & Suspension 18 12-15-2004 10:45 AM
Piston slap after I changed pistons to Arias forged pistons tomoking Service & Maintenance 9 11-06-2003 08:48 AM
6 piston caliper has less clamping force then 4 piston ones on WRX - any truth? HM3SC Brakes, Steering & Suspension 12 06-27-2001 05:54 PM
