Old 11-30-2004, 04:43 PM   #1
Davenow
Member#: 23676
Default Grounding mod FAQ the right way thread pics too!
Ok so I typed this all out in another post and though it would be good to make this its own post, with pics and all.
Here is a cut and past of my directtions
OK go to autozone, buy the spool of black (or whatever color you want) 10ga wire, the ones that come on the yellow card, I think its 15 feet maybe?
Buy at least 5 eyes (the things that go on the end of the wire to put a bolt through, for some reason the name escapes me right now)
You will need some sort of soldering device, and preferably a mini torch or lighter.
Buy some heat shrink or a roll of elec tape.
OK
Starting at the battery, neg terminal, use eye to attatch the wire to the bolt on the neg cable
Pull the cable out about 5 feet or so and cut., lay it across the engine towards the passenger side. Leave it there for now.
Looking down at your motor from in front of the car, on the right side head, front, you will see a bolt. You are going to look up at the wire you have running across the car now, Cut a piece of wire long enough to eye to that bolt, and run up to the main wire.
Strip back about an inch of the covering on the main wire, solder the line off the head to the main wire, heatshrink or wrap with elec tape, do the same thing again on the bolt on the back of the alternator, And again on the passenger side head, there is an open, threaded bolt hole in the front, a 10mm(iirc, could be 8mm) bolt goes right in.
Basically you want both heads, and the alternator ground wires attatched to the main wire. For a clean install, for the passenger side head, cut the main line short enough and put an eyelet on it and use it to ground the head.
I think I am going to write up a killer post with pics for this
I had a grounding mod before this, it did NOTHING. I thought long and hard about it, came up with this, installed it and guess what, it WORKED. The car ran noticeably smoother.
I ran nothing to the body. If you look right next to the neg terminal, there is alreasy an 8 gauge line running right from the battery to the chassis about 6 inches away.
You basically run the line from teh neg terminal to the passenger head front.
You branch lines off of it to the back of the alternator and to the drivers side head.
I DID forget running another off the main line to the standard bolt we all use on the intake. Once will do, just the drivers side.
Your goal here is getting better grounds for the coilpacks, the important sensors, (manifold) and the main electrical system (back of alternator)
The body is already grounded from the battery with a VERY short 8 gauge line right at the battery. You arent going to make a better ground than that. You may want to unbolt it from the fender and clean any paint out from under it to make better contact though.
PLEASE DO NOT ASK ME TO MAKE YOU A KIT AND SELL IT TO YOU. I WILL NOT UNDER ANY CIRCUMSTANCES BUILD YOU A KIT FOR ANY AMOUNT OF MONEY.
Old 11-30-2004, 04:43 PM   #2
Davenow
Member#: 23676
Old 11-30-2004, 04:45 PM   #3
Davenow
Member#: 23676
I should make a bunch of these up and sell them on ebay
Think anyone would buy them??? It would be a 5 min install if it was premade
Old 11-30-2004, 04:48 PM   #4
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
companies already do and charge $80+
nice write up
MikeWRX-NJ is offline   Reply With Quote
Old 11-30-2004, 04:54 PM   #5
kbarb03
Member#: 62440
2003 WRX
black
You should use heat shrink that is adhesive lined, or use adhesive with the normal heat shrink. This is what makes the heat shrink actually be weather proof.
kbarb03 is offline   Reply With Quote
Old 11-30-2004, 04:56 PM   #6
Davenow
Member#: 23676
That would be better yes, but as this is just a ground line, it wont really hurt it to get wet. But better is better. If you can get your hands on it, use it
Old 11-30-2004, 05:04 PM   #7
Rev1
Member#: 51240
08 Lexus IS350
I have one additional grounding point: bolt by the throttle body and the intake manifold (given that our TB's are electrically operated, could use a better ground there)
Rev1 is offline   Reply With Quote
Old 11-30-2004, 05:17 PM   #8
SLIGHTLY
Member#: 47909
2004 PSM WRX Wagon
awd+corner, WEEEEEE!
How come this is inportant? Seems like soemthing that should have been done at the factory..
SLIGHTLY is offline   Reply With Quote
Old 11-30-2004, 05:21 PM   #9
WRXVT
Member#: 17979
335i Blue
Yeah I’m curious as to why Subaru doesn’t do this already. It doesn’t seem like it would add much cost at all…
WRXVT is offline   Reply With Quote
Old 11-30-2004, 05:39 PM   #10
brianbot5000
Member#: 44000
2013 2013 WRX Hatch
1997 Toyota Tacoma
Some say it's questionable whether this does anything. Others will say it's worth it. Probably some where in between.
And if it came from the factory like this, then what we have to debate about??
brianbot5000 is offline   Reply With Quote
Old 11-30-2004, 05:44 PM   #11
Rev1
Member#: 51240
08 Lexus IS350
It effectively lowers the resistance of the grounding circuit.
Your butt dyno feels it as if the car is smoother, like Davenow says. I feel the same.
Some people say it doesn't do sheet, some people can feel the results. It's up to you.
I measured two grounding points with a voltmeter, and I saw 0.3 to 0.5 ohms lower resistance (average) with the grounding kit in place.
Old 11-30-2004, 06:04 PM   #12
snvin
Member#: 50578
2009 2.5i. Bleh.
-=Forza Azzurri=-
Nice writeup Davenow.
I know the car is already grounded to the body via a stock ground, but is there any harm in grounding it to the body yourself? I have mine running to the passenger strut top, but I've heard that this is the worst place to ground something to the car's body.
snvin is offline   Reply With Quote
Old 11-30-2004, 06:13 PM   #13
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
Now, just ask a mod here to move this to the proper forum (Electrical) and we can link to it in the Threads of Note there.
Old 11-30-2004, 06:31 PM   #14
Davenow
Member#: 23676
I know that some people say this doesnt work. I KNOW I said the same, yet I also know that with this setup, I FELT A DIFFERENCE.
Here is the thing. If you are looking at spending $80 for an HKS kit that just may do NOTHING, then dont.
My setup will cost you at or under $10 and 20 min time. Is $10 worth a shot to make your car run better/smoother? Duh.
Even if I make these and start selling them, They will be like 25 shipped. If that. Do it yourself. Itss IRT cheap, and works EXACTLY the same as a $200 kit. (yes some manu's charge $200 for it, and even if it makes a difference, its not $200 worth of a difference.)
Old 11-30-2004, 08:41 PM   #15
mkalbarc
Member#: 59427
2005 Legacy GT ltd
Black as night
Davenow,
Great Post!!!
I now have a project for this weekend! Woo hoo! ... The only time I get 20 minutes to do anything.
Thanks!
mkalbarc is offline   Reply With Quote
Old 11-30-2004, 08:46 PM   #16
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Thanks Dave....looks like ya finally got it all figured out, without any extra bullspit
Keep some n00bs from wasting a lot of $$$ on nothing.
My car runs better after I did this mod.
Old 11-30-2004, 09:38 PM   #17
mno
Member#: 59322
2004 STi WRB,09 G8GT
08 G6, 06 CTS, 2010 Prius
Great write thanks for the info.
mno is offline   Reply With Quote
Old 11-30-2004, 09:52 PM   #18
mgc9876
Member#: 61026
02 WRX
Gotta try this myself.
mgc9876 is offline   Reply With Quote
Old 11-30-2004, 10:05 PM   #19
railguy
Member#: 53756
Great write up, does unabomber have competition?
railguy is online now   Reply With Quote
Old 11-30-2004, 10:10 PM   #20
5spdfrk
Member#: 46407
blew
Sweet! Thanks Davenow for some real useful info. I will do this soon!
5spdfrk is offline   Reply With Quote
Old 11-30-2004, 10:25 PM   #21
westphalia
Member#: 28008
04 Silver WRX
My kids are now 4 & 2
What about the possibility of grounding loops? Was there any consensus on that?
westphalia is offline   Reply With Quote
Old 12-01-2004, 12:38 AM   #22
Bishop
Member#: 59993
Ass, grass or cash
no one rides for free!!
i'll buy one from ya!!
no really. i would.
Bishop is offline   Reply With Quote
Old 12-01-2004, 02:05 AM   #23
rallyblues
Member#: 44912
2007 BMW 335i
"I FELT A DIFFERENCE." Ever heard of placebo effect? It's real, all the drug companies test their drugs against a placebo, b/c third or so of people improve on a sugar pill.
Is there any OBJECTIVE tests outhere that this actually makes difference in car perfromance - lowered resistance does not equate performance.
I'm not trying to be a dlck, it's that I've always wondered what this thing does. I always thought it was the bling... same as those red manifolds
rallyblues is offline   Reply With Quote
Old 12-01-2004, 03:59 AM   #24
MistaOctamopus
Member#: 53561
2004 WRX
Search Davenow's posts, and then decide if the $10 is worth it. The guy knows enough to make it worth your while to research, and $10 is a pretty cheap mod. He is very knowledgable about the car, and $10 isn't much even for the cheapest modder, so what's really to lose? However I applaud your method of researching and deciding for yourself. It's $10 just do it.
MistaOctamopus is offline   Reply With Quote
Old 12-01-2004, 07:24 AM   #25
NWWagon
Member#: 66769
05 Focus "ST"
'80 Honda CM400T
A good way to hide the pesky wires is to use a strut bar. I got a $20 eBay Sti clone bar so wasn't afraid to drill it out. Makes for a little cleaner of an install.
The pictures are a bit old I've since then added a wire to the back fire wall and to the bolt by the alternator as shown in the earlier pictures.
PLEASE NOTE that I disn't use the Passenger strut bolt as a grounding poit, only as a remote ground if I wanted to (and did) add wires to it. The strut bolts are not a ground and will not help.
NWWagon is offline   Reply With Quote
DIY: Intercooler Screen Mod - The right way! efaroh Interior & Exterior Modification 54 04-25-2012 10:27 PM
Fog Lights on with Highs Mod for 2000 RS, the right way IowaRS Electrical & Lighting 12 12-03-2010 01:23 AM
Head light mods, the right way. Iggy76 Electrical & Lighting 12 01-11-2006 07:16 PM
just got the car, modding the right way? sheizen Factory 2.5L Turbo Powertrain 3 06-16-2005 12:05 AM
The right way to do fuel lines w-pics!!! O4STInger Factory 2.5L Turbo Powertrain 20 03-11-2005 11:39 AM
Message Board Statistics All times are GMT -4. The time now is 07:33 PM.
