Old 08-22-2012, 03:42 PM   #676
0BlueSTi4
Member#: 98955
2011 WRX Hatch
Anybody try this with a newer GR WRX? I am having hard time identifying grounding points as the engine looks different. Any images you might have will be of great help. Thanks!
0BlueSTi4 is offline   Reply With Quote
Old 08-26-2012, 10:57 AM   #677
maxim05
Member#: 97619
04 WRX Wagon
Just wanted to say thanks to Davenow and others that have contributed to the thread up to now. Did this yesterday on my wagon. Went ahead and built mine with 4 AWG OFC, since that is all I had and didn't want to wait another week for 8 AWG to show up and it seems like 8 AWG ring connectors are more difficult to find than 4 AWG connectors. I also did "The Big 3" as well. The positive wiring needs to be redone at the battery connector a little since I cut the 0 AWG intermediary wire a little long and ran out of room. Anyway, here are the pics.
maxim05 is offline   Reply With Quote
Old 08-26-2012, 02:51 PM   #678
WRXLTD
Member#: 136314
2014 Grand Cherokee
All you need is a ground from the engine to the negative post of the battery, and another one on the passenger side of the motor to the strut tower.
WRXLTD is offline   Reply With Quote
Old 08-26-2012, 05:10 PM   #679
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
no....no you dont
those dont really do anything
tried it....didnt do ****
and NEVER--EVER use the strut top mount studs for grounds....they are VERY bad grounds...like non-grounds, really
Old 08-27-2012, 07:32 AM   #680
WRXLTD
Member#: 136314
2014 Grand Cherokee
Originally Posted by Uncle Scotty View Post
no....no you dont
I beg to differ. After I did this mod the car was less "jerky" crawling in 1st & 2nd while in bumper to bumper traffic, and the idle just felt smoother.
And as for grounding at the strut tower, I did not use a top mount stud location...I used one of the side bracket nuts. My meter showed it was a good ground point.
I don't care what anyone says, I felt a difference with my grounding mod. Did I gain horse power or gas mileage...of course not. But my engine does seem to run smoother in the lower gears, and my set up cost me only about $10.
Old 08-27-2012, 01:33 PM   #681
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
i dont believe it...not on a new car....all in your head
maybe on an OLD car...but not a 2012
Old 08-27-2012, 10:35 PM   #682
omnynce
Member#: 314224
If I'm not mistaken the newer Subaru's engines are grounded out underneath from the valve cover to the chassis. I could be wrong but I believe I saw them on the Legacy's but I'm not dealership tech so I havent seen alot of them.
omnynce is offline   Reply With Quote
Old 08-28-2012, 07:11 AM   #683
WRXLTD
Member#: 136314
2014 Grand Cherokee
Have you actually seen the grounding points on newer Subarus?
Not only do the stock weak a$$ ground straps (wires actually) sit right on the painted surface...even the bolt hole threads are coated with either paint or primer.
Old 08-29-2012, 01:56 PM   #684
0BlueSTi4
Member#: 98955
2011 WRX Hatch
Sounds like the first order of business should be cleaning the stock grounds, which is something I still need to do.
Old 02-28-2013, 07:21 PM   #685
07RezaWagon
Member#: 291657
2007 2.5i Wagon
CGM
Back from the dead..
Anyone know if these are the oem grounding points on an 07 2.5i?
Driver side right below the torque box
On the firewall passenger side next to the engine mount
and on the passenger side intake manifold
If they are I figure I'd clean em up a bit and see if it helps any before doing any more.
Right now I just have some bucking when letting of the gas at low speeds thats really irritating in parking lots that would be nice to get rid of..
Thanks in advance
07RezaWagon is offline   Reply With Quote
DIY: Intercooler Screen Mod - The right way! efaroh Interior & Exterior Modification 54 04-25-2012 10:27 PM
Fog Lights on with Highs Mod for 2000 RS, the right way IowaRS Electrical & Lighting 12 12-03-2010 01:23 AM
Head light mods, the right way. Iggy76 Electrical & Lighting 12 01-11-2006 07:16 PM
just got the car, modding the right way? sheizen Factory 2.5L Turbo Powertrain 3 06-16-2005 12:05 AM
The right way to do fuel lines w-pics!!! O4STInger Factory 2.5L Turbo Powertrain 20 03-11-2005 11:39 AM
Message Board Statistics All times are GMT -4. The time now is 01:59 PM.
