Welcome to the North American Subaru Impreza Owners Club Sunday May 3, 2015
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 11-30-2004, 04:49 PM   #1
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
Lightbulb BAJA Subwoofer
Here is my latest project. I've had problems with the factory sub and the dealer doesn't understand how it works so I scrapped it. I decided to install an aftermarket sub. The only problem is where to fit it. Since there is not much space in the Baja I decided to go with an 8" sub, it only requires a 0.35 f^3 volume for a sealed box. A 9in. x 15in. x 6in. box should fit this. But where can we stash a box that size where it won't get in the way of the pass-thru? My answer, remove that plastic waste of a space between the back seats. None of the stores around stock a good 8" sub so I picked up a generic one at the flee market while my order from Crutchfield is being shipped. This let me get the measurement correct and test fit before the sub arrives. I also orded a polk momo 8" cover to match the sub. Here are pictures without the cover and final sub.
And with the seat up:
No loss of the switchback. Just don't play loud with it like this!
You can't really tell from the pictures but the sub is angled slightly toward the back seat. The box is covered with marine grade black vinal to match the leather seats since they feel like vinal and I couldn't find leather locally.
braveit1 is offline   Reply With Quote
Old 12-01-2004, 06:04 AM   #2
Chris N
Member#: 5322
07im +07Leg+00Forest
Scooby wrench turner
Thumbs up
Very good idea! It will look even sharper with the cover on the sub. 2 bananas for you
Chris N is offline   Reply With Quote
Old 12-01-2004, 11:33 AM   #3
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
Thanks. I think it matches. Not I have to charge admission for the women to sit in the back seat! Because the inside of the BAJA is so small, it does fill the cabin.
Old 12-05-2004, 05:26 PM   #4
mcsvt
Member#: 56289
2003 Baja
I think it looks great. If I end up keeping the Baja longer I think I will have to try something like that. Were do you have the amp mounted?
mcsvt is offline   Reply With Quote
Old 12-06-2004, 09:20 AM   #5
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
The amp fits under the drivers seat without any problems. It is the 6-way power seat as well.
Old 12-10-2004, 12:45 AM   #6
DOH_minion
Member#: 65068
05 Baja Turbo
OMG..U got Beat by a BAJA
shveeeet!
DOH_minion is offline   Reply With Quote
Old 12-13-2004, 12:19 PM   #7
DOH_minion
Member#: 65068
05 Baja Turbo
how did you get that plastic tray out of the seat?
Old 12-14-2004, 08:30 AM   #8
braveit1
Member#: 44810
2003 Baja w/Snuglid
Black & Silver
There are screws with caps over them. One in each cup holder and two in the compartment. Just use a small screwdriver to lift the caps off and then unscrew. Very easy.
Old 12-15-2004, 11:45 AM   #9
DOH_minion
Member#: 65068
05 Baja Turbo
thnx braveit1,
muahhaahahah... im gonna try and reclaim that wasted space by adding a cushion and seatbelts.
Old 12-15-2004, 11:46 PM   #10
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
You could get a rear seat bottom for a Legacy or Outback and have it recovered,just a thought.
ajabobrut is offline   Reply With Quote
Old 12-17-2004, 01:09 PM   #11
DOH_minion
Member#: 65068
05 Baja Turbo
thought about going that route... but then i wouldnt be able to install a woofer in it now would i ?
hehe... i like this woofer install idea.. if i could make a quick disconnect on a modular base i could swap out a seat cushion for the center peice if i got to hual some company around.. and then swap in the woofer to pump out some bass afterwards, now id i could just figure out his whole space/time continuum thingy
Old 12-17-2004, 06:29 PM   #12
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
Now your thinkin.
Old 12-18-2004, 12:23 AM   #13
DOH_minion
Member#: 65068
05 Baja Turbo
hehe
Old 01-18-2015, 10:16 PM   #14
uteopia
Member#: 379700
2005 Baja
Garnet Red Pearl
Like this? Fairly simple mod and now I can seat 5. 95-99 outback seatbelts will work with the stock shoulder belts. So you just need the center mounts. I have a write-up on ST with more pics:
http://www.scoobytruck.com/bb/viewtopic.php?f=2&t=2804
uteopia is offline   Reply With Quote
Old 01-20-2015, 09:33 AM   #15
sfeather11
Member#: 220466
2003 Baja
Silverstone
Very nice sub idea. And good execution too! What did you use for the enclosure. Looks like a plastic store bought box or did you make it? Either way it looks good and like it fits perfectly...
Peace!
sfeather11 is offline   Reply With Quote
Old 01-20-2015, 12:02 PM   #16
krypto
Member#: 405946
well that will solve my bass withdrawl issue since i got in the baja... and wow i never knew the seats come forward like that. thanks alot
krypto is offline   Reply With Quote
Old 02-14-2015, 12:12 PM   #17
gothamz_hero
Member#: 45293
2005 Baja
Obsidian Black
I saw a kicker compact amp/sub module thingy that looked like it might be an upgrade over the factory installed sub. Theoretically it could fit under the seat.
Kicker 11HS8, it might not be great, but I'm willing to bet it's better than stock.
If I get around making a cardboard mock up, I'll let you know how it fits.
Oh, and beautiful seat conversion uteopia!
Sent from my SHIELD Tablet using NASIOC mobile app
gothamz_hero is offline   Reply With Quote
Old 02-17-2015, 05:51 AM   #18
sfeather11
Member#: 220466
2003 Baja
Silverstone
The box man! What did you use for the speaker box?? I would love to do this conversion but need more info!
FS : Custom Subwoofer Box for Impreza rossivt Interior/Dressup/Audio & Security 0 06-02-2010 01:20 PM
JL Audio 6.5-in Subwoofer System with Custom Small Box Baja Truck! baja ex Interior/Dressup/Audio & Security 1 04-25-2009 07:06 PM
Subwoofer options for a Baja Audiosavvy Car Audio, Video & Security 33 04-17-2009 10:26 PM
Room for Subwoofers in Baja? Bob O Baja Forum 3 02-26-2005 10:00 PM
Subwoofer in Baja sbharamareddi Baja Forum 30 11-15-2004 01:30 PM
