Old 07-01-2001, 08:42 PM   #1
STiTuner
Member#: 5778
09 135i
Jet Black
Default more 2.5 RS-T conversion questions.. need help ASAP
Got a few more question for you RS-t guys
first of all will the turbo piping (uppipe, downpipe, charged intake pipe) from a 98 fit an 01? I understand there might be some small probelms with clearence but for the most part I mean? if not what would it need to make it fit, or should I just get new damn piping?
Second of all where did you guys tap for your oil send? I know that you can tap the pump for water send and return, but what about oil send? I was recommend to a place near the oil pressure sensor but you have to have it fitted exactally right.
Please I need help kinda fast...
thanks in advance
Brad
STiTuner is offline   Reply With Quote
Old 07-01-2001, 10:01 PM   #2
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Check Larry Ganz's install instructions - it describes where to tap the oil line.
Up, down, turbo-IC should not be any different fitment-wise b/t 98 and 01.
blaster88 is offline   Reply With Quote
Old 07-02-2001, 06:45 AM   #3
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Pain in Tushy
I have an MY98 and I can tell you that the up and down pipes will fit fine. As to the oil send line the Larry directions is what I used and I can tell you it's a living hell taping the oil where Larry did if you doing it on an MY98. Our intake manifold is differant and we have an air control valve in the way. MY99 and above got a redesigned intake manifold and got rid of the air control valve all together. So just prepair for some fustration.
Joshua
Subaru Salesman
yebokmj is offline   Reply With Quote
2.5 rs Bumper conversion question. AFBeefcake Subaru Conversions 5 03-03-2008 04:55 PM
'00 2.5 RS speaker fitment questions - Plz help getek20 Car Audio, Video & Security 0 01-31-2004 08:59 PM
flywheel question, need help asap!! Qaveboy Transmission (AT/MT) & Driveline 1 09-03-2003 05:39 PM
Really quick question need help asap please willguidry Interior & Exterior Modification 5 12-09-2002 03:05 PM
No more 2.5 RS Impreza? Subies General Forum Archive 17 10-06-2000 09:58 AM
