Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 11-30-2004, 05:32 PM   #1
Matrix 1193
Member#: 68286
2006 WRX STI
Pearl White
Default funny idle oscillations on Hydra
The car is a 02 WRX with Helix Up/Dp Espelir Catback
Runnin the hydra+ UEGO
I am having some issues with the ISC, sometimes it idles right on the mark at just under 1k but then sometimes and I can't tell what causes it to wander periodically from 1200 to 800, it kind of just goes back and forth rhythmically. I read the manual so I already know how the hydra interprets PID. I am just looking for what people run for these values, i just have nothing to compare my experience to.
P 115
I 115
D 40
thanks
Matrix 1193 is offline   Reply With Quote
Old 12-01-2004, 09:54 AM   #2
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
Read this section on "Idle Control" if you haven't already http://elementtuning.com/technical/e...ningguide1.htm
Your proportional looks to low which will result in less active closed loop idle control. Set it to 175 for now.
If this doesn't help, your fueling needs adjustment as the ecu extrapolates between fuel cells. The best way to adjust this is with "Closed Loop" turned off. Simply adjust the idle cell and 4 surrounding cells so they are very close in AFR. Don't tune it to 14.7:1 but instead 14:1 and let the closed loop system adjust the fuel from there.
Good luck,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Funny Idle with a/c on ajshades Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-03-2008 12:52 PM
Question about high idle on Hydra RemlapaN Other Engine Management 10 06-01-2007 10:32 AM
funny idle??? impreza2002 Normally Aspirated Powertrain 5 12-14-2002 06:50 PM
funny idle??? impreza2002 Engine Management & Tuning 0 12-13-2002 10:23 PM
