Welcome to the North American Subaru Impreza Owners Club Thursday November 27, 2014
Old 07-02-2001, 12:19 AM   #1
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
Default ram-air intake pic
Tittle says it all!
adeck is offline   Reply With Quote
Old 07-02-2001, 12:20 AM   #2
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
Another pic
Old 07-02-2001, 12:24 AM   #3
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
one more
Old 07-02-2001, 12:45 AM   #4
King Ding187
Member#: 2598
2002 WRX Wagon
how does she feel?
King Ding187 is offline   Reply With Quote
Old 07-02-2001, 01:36 AM   #5
rpone605
Member#: 1669
2004 WRX Sport Wagon
so what about all the low end torque your loosing?
how about the velocity measurements??? did you consider those?
rpone605 is offline   Reply With Quote
Old 07-02-2001, 04:15 AM   #6
bratmantlz
Member#: 3231
88 626 Turbo
white
lets not forget water ingestion(sp?) and objects like birds moths grasshoppers etc.
Brat
bratmantlz is offline   Reply With Quote
Old 07-02-2001, 08:09 AM   #7
Peaty
Techno Sapien
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
I'm sure you are getting cooler air and that's a good thing. But in order for ram air to actually ram any air you have to be going around 140 mph and even then the pressures are very low. Pat has the same setup. It sounds wild at the auto-X
Peaty is offline   Reply With Quote
Old 07-02-2001, 08:47 AM   #8
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
There is no torque loss, none. Believe it or not the filter stays 100% dry, I have been in some pretty heavy downpours. I have had this setup for about 1 month now and I have not had to clean it out at all.
Old 07-02-2001, 09:49 AM   #9
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
So far with my S-AFC I have reached very low and zero intake maifold pressure. I didn't really open it up yet, today I will to see if I can reach positive pressure.
Old 07-02-2001, 10:12 AM   #10
Layman
Member#: 3717
2011 Swagger Wagon
bikes with pedals
Hey Peaty, that 140mph notion about Ram Air is a myth. A proper ram air setup can provide gains at normal highway speeds. Go to some of the F-Body boards and ask if their Ram Airs are useless below 140mph.
Granted, on an impreza there may be a different story, but not for ALL ram air setups.
Layman is offline   Reply With Quote
Old 07-02-2001, 11:47 AM   #11
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
When I was on the contour board there was a guy that was really a "Rocket Scientist" and he went through some math that explained the whole thing. I saved the post but can't seem to find it. I'm just going by what he said. The scoop would have go be huge
Old 07-02-2001, 11:53 AM   #12
Layman
Member#: 3717
2011 Swagger Wagon
bikes with pedals
Well, if you look on the RamAir firebirds, the scoops ARE huge.
Anyhow, I, too, doubt it works on an Impreza, but I've been told that ramair can work on other cars.
Old 07-02-2001, 12:41 PM   #13
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
I agree that it's not a true "Ram Air", but the hood scoop is open and the box behind guides the air from the hood scoop into the intake. I drove around for a ahwile with my homemade box installed and not, it makes a huge diference. without the box you can feel a low RPM loss but high RPM gain. With the box you can feel gains throughout all the RPM's.
Old 07-02-2001, 12:47 PM   #14
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
One other thing if the ram-air on a F body works so well than why wouldn't it in ours? If you think of our car in a wind tunnel the air travels up the hood and the scoop catches the air.
Old 07-02-2001, 12:56 PM   #15
Layman
Member#: 3717
2011 Swagger Wagon
bikes with pedals
Look at the difference between the hoods on an F-Body and ours. Their scoops are much more prominent (believe it or not ) and cut into the air more. Because the front end of an Impreza is as aerodynamic as a brick, I'd be suprised is too much air actually forced it's way into the hood scoop.
Maybe somebody has a way to measure the wind velocity from underneath the open hood scoop. That would be helpful.
BTW, I'm not bashing your intake at all. I'm sure it works pretty well, just not as well as an F-Body's similar setup.
Old 07-02-2001, 01:12 PM   #16
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
I've got 3 of these I use at work:
http://www.mesalabs.com/datatrace/pressure.htm
The base is a little bigger than a quarter to give some perspective. The pic is kind of big.
I'd be happy to put one in the intake and one beside it for a control to see if there is indeed some pressure. I can't send them out though I'd have to do it here as they cost around 3K each. These can be programmed to record at 1 sec intervals for up to 1000 readings. They also get temp. at the same time.
I did something similar with temp that I have to redo now that my scoop and vents are open. that info is here:
http://www.scoobymods.com/mods/impreza/thermal.php
Peaty
Old 07-02-2001, 01:16 PM   #17
Layman
Member#: 3717
2011 Swagger Wagon
bikes with pedals
Peaty, that would be great, though I was thinking that mounting one inside the hoodscoop itself would give the greatest insight as to whether there is any real ramair effect.
Old 07-02-2001, 01:30 PM   #18
Safir
Member#: 3873
. Paradise is
like Disney with hookers
hey guys... if the scoop did not bring in a noticable amount of air, y do we put our intercoolers under it? don't those require air to be useful? and unlike the ram air intake shown above, they do not have anyhting pulling air into the scoop.
that brings me to points 2: you would still need to be moving fast enough to scoop more air than the engine is pulling, wich would require a lot of math that i dont understand to figure out.
and point 3: our engine has half the displacement of your "standard" big V8 engine... hence only uses half the air per revolution, hence only needs half the scoop "area" to get teh same effect, this is of course not taking into effect scoop placement in the airstream and many other factors of course.
so IMHO i think that there would be some gain in air pressure to be had by using hte hood scoop... wether it will make a real difference? only a lot of R&D $$ and a dyno will tell for sure. I am still a believer that short of a turbo or super, COBB has the best intake for the RS
Safir is offline   Reply With Quote
Old 07-02-2001, 01:48 PM   #19
dRu18
Member#: 4034
2005 Infiniti G35c
Ivory Pearl
Default "ram" air
i believe to get MORE gains from your "ram air" set up, it would be wise to turn your hood scoop backwards creating a sort of "pressure buildup pocket" between your scoop and windshield. i've learned this in automechanics taht you have less pressure buildup when the air is smashing into your scoop. one example would be the lancer style hood, it's built like that for a reason
dRu18 is offline   Reply With Quote
Old 07-02-2001, 01:51 PM   #20
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
In an ideal situation three datatrac units would be used. One on the dirty side of the air filter, another on the clean side to see the drop in pressure across the filter itself, but care must be taken to secure the datatrace, I don't think it will fit past the butterfly valve in the TB but I wouldn't want to find out the hard way. The last one should be secured under the hood somewhere by, but out of the airstream of the scoop for a baseline control. Maybe I can do this with Pat's intake (KC_TopDog) someday since his is very similar.
Peaty
Old 07-02-2001, 01:56 PM   #21
JC
Member#: 692
2006 Pontiac GTO M6
Triumph Street Triple R
Hey Peaty find that post by the Rocket Scientist. I'm studying to be one and I have a 40+ page packet laying around on scoops from when I was on the aerodynamics group for the UofM formula team. I'd like to see his math.
JC is offline   Reply With Quote
Old 07-02-2001, 02:04 PM   #22
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
Is a S-afc an accurate meter for reading intake pressure, because it was reading at zero when I bleeped the throttle going through town today. I can almost guarantee that it will read positive pressure, when I open it up after work.
ram air intake vs cold air intake Shaji Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 62 07-21-2002 10:05 PM
Should i block off the factory ram air intake after installing cold air? keystone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 12-07-2001 04:23 PM
Cold-air/Ram-air intake from hood vent (not scoop)? Fred Fredburger Normally Aspirated Powertrain 31 03-21-2001 12:13 PM
Ram Air Intake Pics! ImprezedRS Normally Aspirated Powertrain 18 03-17-2001 01:34 AM
