Welcome to the North American Subaru Impreza Owners Club Friday December 19, 2014
Old 12-01-2004, 09:29 PM   #1
Infest
Member#: 76053
Question Need Wiring help!
Ok, i have 2 10'' 1200w, Precision Audio Explosions, 4ohms(id: XS-L1090X), and a Legacy 2000w(id: LA1080), 2/4 channel, 2 ohms(bridgeable to 4ohms).
Question 1: I believe i know how to bridge them, but can anyone refresh my memory?
This is what the connections on my amp look like...
The first + - are Ch1, 2nd are channel 2, etc.
How would i hook the subs up for 4ohm 1000w to each?( the amp is 1000w x 2 Bridged Output)...so how do i bridge them
Question 2: this should work...right?
thx!
Infest is offline   Reply With Quote
Old 12-02-2004, 11:00 AM   #2
Infest
Member#: 76053
Have a Nice Day?
anyone?
Old 12-02-2004, 11:08 AM   #3
Boost-Free Subee
Member#: 61052
1999 2.5 RS
so...the legacy is a 4 channel amp? to bridge an amp, you simply have to use the positive of one channel, and the negative of the other channel to hook up to your speaker. it won't be 1000w to each speaker, as the 1000w rating is @ 2 ohms, so it would be 500w @ 4ohms. and since it's probably a peak rating, it should be more like 250w RMS@ 4 ohms, to each sub.
Boost-Free Subee is offline   Reply With Quote
Old 12-02-2004, 11:13 AM   #4
tcs007
Member#: 4103
2003 WRX Wagon
Reddish
That is not true. It depends on the amp. Some amps want you to use both positives. Some want you to use a positive and a negative.
I would check on the amp manufacturers website for the correct way.
tcs007 is offline   Reply With Quote
Old 12-02-2004, 04:52 PM   #5
Infest
Member#: 76053
well, on the box, it says exaclty this "1000w x 2 Bridged Output" and then a little further down, it says "Bridgeable to 4 ohms" so, if i bridged them, it should, i say should, because im not sure, be 1000w x 2 ouputs @ 4ohms...but i guess thats my question
Old 12-02-2004, 08:01 PM   #6
Infest
Member#: 76053
bump
Old 12-03-2004, 10:53 AM   #7
Infest
Member#: 76053
Question
can anyone answer this question?
Old 12-03-2004, 12:46 PM   #8
Infest
Member#: 76053
please help!
Old 12-03-2004, 01:27 PM   #9
Infest
Member#: 76053
Need wiring help - installing exh. fan ursmother Off-Topic 10 10-18-2005 01:48 PM
greddy gauges - need wiring help hybrid gti 2 Electrical & Lighting 7 09-13-2005 06:27 AM
Need wiring help with '05 Outback/Legacy smosh Car Audio, Video & Security 0 04-23-2005 10:34 AM
Need wiring help, ASAP Greg Sharpe General Forum Archive 0 02-17-2001 08:25 AM
Field SFC, need wiring help - someone w/ owners manual Tony Technical Forum Archive 2 08-02-2000 04:06 PM
