Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 02-22-2001, 06:34 PM   #1
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Exclamation A public service announcement
Remember to reset your ECU every so often.
I did it tonight and my scooby turned from an anemnic whimp that couldnt get out of its own way, to a tire chirping champion!
Midwayman is offline   Reply With Quote
Old 02-22-2001, 06:37 PM   #2
ChosenWon
Member#: 2236
2000 Audi S4
silver/rally dirt brown
Post
"anemnic whimp " lol! Ha I love it. you funny guy.
ChosenWon is offline   Reply With Quote
Old 02-22-2001, 06:50 PM   #3
98mpreziveRS
Member#: 972
Post
LOL! good one..and nice tip.
98mpreziveRS is offline   Reply With Quote
Old 02-22-2001, 11:41 PM   #4
01 Black RS
Member#: 2770
Post
thats true, I reset my computer, and what a difference!
01 Black RS is offline   Reply With Quote
Old 02-23-2001, 04:47 AM   #5
mykrrrr
Member#: 733
'13 Focus ST
Post
What's the proper "re-setting" process???
Isn't it pulling a fuse???
-myk
mykrrrr is offline   Reply With Quote
Old 02-23-2001, 05:04 AM   #6
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
Post
To resett the ECU,
1) disconnect the battery
2) let the car sit for 1/2 hr - 45 min
3) re-connect the battery (if you have an alarm, hit the disarm button as soon as tye battery is re-connected, or else you'll get an ear full)
4) start the car and let it idle / warm up for 10 minutes. Do not touch the accelerator pedal during this phase.
5) shut the engine down, re-start and drive the way you want. The ECU will start re-learning.
Ta dah!!!
done..
JoeT is offline   Reply With Quote
Old 02-23-2001, 07:28 AM   #7
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I think there is a fuse you can pull. I refuse to reset my ECU because of all my radio stations and radio settings though. Through all my different intakes and everything, I have never reset my ECU.
Old 02-23-2001, 07:34 AM   #8
dada21
Member#: 383
2001 Outback Sport
Post
i was just about to make that comment 8...
i want to reset my ecu (haven't done it in 85,000 miles haha) but i don't want to lose all my settings. with my wacked out digital head unit, there are about 600 settings for radio, crossover, sub settings, etc etc etc. if i reset it, i'm going to lose it all.
any idea if the fuse will keep my radio settings? i looked in the manual and didn't find the fuse for the 97 obs...
dada21 is offline   Reply With Quote
Old 02-23-2001, 08:00 AM   #9
hacman
Member#: 3603
Post
I'm in the process now. I only have Q101 programmed, so that'll be easy to replace. Hell, when ya have the MP3 player, ya don't worry bout the radio!
hacman is offline   Reply With Quote
Old 02-23-2001, 08:14 AM   #10
ChosenWon
Member#: 2236
2000 Audi S4
Post
There IS a fuse that you can pull. I found it while trouble shooting my burnt out radio. I'm not sure if it keeps or loses the radio stuff though.
Besides, as 8 has demonstrated, you don't really have to resect the ECU, it will, over time learn the new settings. but by reseting it manually it just does it instantly.
Old 02-23-2001, 10:30 AM   #11
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
Well, my problem is that over time the power got worse and worse.... may have a marginal O2 sensor? Who knows. I hadnt made any changes on the car, but it did alot for me.
Resetting though... supposedly there are some connecters under the dash that if you hook up it will reset the ecu without doing anything else. supposedly this is how the dealers do it. You'll have to search for that one though, I just do the battery reset... only 3-4 stations to preset, oh and the clocks.
Old 02-23-2001, 10:38 AM   #12
RacerinLSL
Member#: 1174
2011 Subaru WRX
Post
I have had multiple auotmotive technicians(Subaru, Mitsubishi, and a European Touring Car tech) and others tell me that reseting your ECU does nothing for your car. You get just as much of a performance gain out of washing it, or putting that Greddy sticker across the windshield. Unless you are having a sensor malfunction, which means there is a larger problem, resetting the ECU is a mind game.
RacerinLSL is offline   Reply With Quote
Old 02-23-2001, 10:57 AM   #13
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Post
Well, you're sorta right...
Assuming that you havent changed anything, and the car is working properly, there is no reason it would help. However, there is no doubt that it make the modifications register quicker, and in my case, allow a possible bad sensor to be reset to factory defaults.
Old 02-23-2001, 11:46 AM   #14
01 Black RS
Member#: 2770
Post
well Midwayman, my performance was dropping as well as my gas mileage. Turned out to be my 02 sensor went out, replaced it and reset the ecu. Runs way better and got the gas mileage back to normal.
Old 02-23-2001, 10:50 PM   #15
subatek
Member#: 4211
Post
Midwayman is partially correct, "resetting"your ECU can improve driveability if the ECU has been corrupted from, say a bad O2 sensor or Temp sensor among other components. I have performed many "clear memory" ops when there were no codes to correct the "learning curve". As far as procedure, we have a select monitor that clears the ECU in about 10 seconds.
Kevin
subatek is offline   Reply With Quote
Old 02-25-2001, 06:34 AM   #16
Revision
Member#: 242
MY05 PSM GGA !STOCK
MY99 RS-RIP / MY95 MX-5
Post
What Kevin said, plus the ECU also learns to retard the ignition timing for when it hears knock as well as learns to lean out the engine to the near lambda o2 values.
So far, everytime I've reset the ECU, I get about 14mpg which eventually gets better after about the 2nd tank or so.
Also if you are extremely anal or paranoid, you may want to check your ignition coil and spark plug wires every other oil change. I posted in the power forum the problem I've had with rust on the ignition coil terminals. Which may have been caused by a bad wire in combination with water coming under the open hood scoop. The misfire is now gone with new wires and a clean terminal and the car runs much more smoothly.
The terminals on the ignition coil should be a shiny brass in color. The spark plug wires should measure 5.12-12.34K ohms.
[This message has been edited by Revision (edited February 25, 2001).]
Revision is offline   Reply With Quote
NWIC Public Service Announcement Ferg North West Impreza Club Forum -- NWIC 2 02-22-2003 02:23 AM
public service announcement #2 -LD Off-Topic 41 10-15-2002 06:18 PM
public service announcement #3 -LD Off-Topic 24 10-15-2002 05:42 PM
SVX Public Service Announcement CRZ_MSL SVX Forum Archive 2 11-22-2000 11:24 AM
Public service announcement (AKA: Tony eats crow) Tony General Forum Archive 3 10-18-2000 06:12 AM
