Old 12-02-2004, 11:35 AM   #1
RUN
Member#: 68048
1998 Impreza Outback
white with dents
Default Wheel bore: is bigger ok
The bolt pattern and offset are ok but the wheels bore is 2mm bigger than the cars original wheels. WOuld it be ok to use these rims or does this put bad shearing stress on the lugs?
thanks !
RUN is offline   Reply With Quote
Old 12-02-2004, 12:29 PM   #2
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
If you're car is hubcentric, a larger bore will mean all of the stress will be on the studs. .......not a good decision in my opinion unless a ring is used to compensate.
btw, by "wheel bore" I'm assuming you mean the center bore on the inside of the wheel (as in this picture):
Kean is offline   Reply With Quote
Old 12-03-2004, 02:28 PM   #3
RUN
Member#: 68048
white with dents
yup, thats the bore.thanks !
Old 12-03-2004, 03:47 PM   #4
khail19
Member#: 14489
2005 FXT 5 spd
Cayenne Red
It's fine to use them, but try to find some hub centric rings for them if you can.
khail19 is offline   Reply With Quote
OK... why is it that our OT is bigger than ANY other car forum I have ever been on?? eightballrj Off-Topic 60 01-23-2013 12:02 AM
is it ok to paint wheels brown3 Newbies & FAQs 28 03-19-2009 04:47 PM
i'm looking for a single or pair(2) 1998 2.5 rs gold wheels Rash is ok sime Private 'Wanted' Classifieds 1 04-27-2005 07:41 PM
Ok I think this wheel bearing is bad dwx Brakes, Steering & Suspension 4 06-19-2003 02:36 PM
Custom wheels with no centercaps. Is it ok? Lightsped Brakes, Steering & Suspension 4 07-29-2002 04:37 AM
