#1 |
Member#: 169
Vehicle:98 black OBS move bi*ch get out da way |
Im finally going to do this and was wondering if there are any online instalation guides? (azscooby, lagging etc?)
i also have 2 other questiond concerning the instal: 1.do i need any other guages to get the most out of the s-afc tuning ( o2 sensor, FPR etc?) im only running an intake and exaust on a 98 OBS 2.once it is installed, can it be set at zero untill i get a good set on numbers and a big chunk of time to test it out so i dont blow up my car? thanks in advance! ![]() //
#2 |
Member#: 6840
Vehicle:2001 2.5RS Blue Ridge Pearl |
Yeah it's fine to leave the corrections set at zero. I have a A/F gauge, a EGT gauge is helpfull too.
#3 |
pooptastic
Member#: 1904
BAIC
Vehicle:2013 Tundra '02 BMW R1100S |
there have been two other threads recently about this very thing. within the past two days anyway. Lots of technical info.
also, check out www.scoobymods.com |
#4 |
Member#: 2817
Vehicle:2001 Impreza 2.5RS BRP |
Try my site :
www.geocities.com/matsut_rpi00/safc.html I gave my SAFC page to www.scoobymods.com , so they have the same exact thing on their site. |
#5 |
Member#: 169
tmat3 - thanks for chiming in...you gave me that address at the albany meet earlier this year and i lost it, but i remember it being real; good. thanks!
can someone fill me in as to what the EGT And the A/F gage do? thanks! // |
#6 |
Member#: 2817
No problem dude.
EGT checks the exhaust gas temperature. On our engines, 1400F is the good temp. Anything less means the engine is running rich. Anything higher (around 1600F), the engine is running lean and that's bad. A/F checks the air fuel ratio of the engine. I have one that attaches to the rear O2 sensor, so it's not so accurate. But, you would somewhat see the general idea of how the engine is running. EGT is the best way to go to adjust SAFC. It will cost $100 for the gauge, another $100-ish for the temperature probe, and another $100-150 for the installation. Most A/F meter is a narow band (0-1volt) and not accurate and slow. If you get a wide band (0-5volts), then it would be more accurate, but it's expensive. |
#7 |
Member#: 169
so basically, without the a/f gage or the EGT, tuning the s-afc corectly is close to imposible? just be able to take other peoples numbers and go from ther i suppose? that dosent seem good. doh! more money...thanks for filling me in on those gages though.
#8 |
Member#: 930
Vehicle:99 Impreza 2.5RS Aspen White |
approx. $100 for the probe!?!?!
I just purchased the gauge and now have to spend additional $$ for the probe! I should've gotten the Apexi. A friend of mine purchased the Apexi, granted a little more $$, but it came with ALL the parts...... including the probe. |
#9 |
Member#: 169
where can i read up on/purchace the apexi EGT? thanks!
| Thread Tools | |
| Display Modes | |
| Knock Sensor & Gary's electirc fix. (yes I did a search). | omahasubaru | Normally Aspirated Powertrain | 37 | 06-27-2008 06:04 PM |
| Attn: TEIN HA owners (I did a search) | Andrew | Brakes, Steering & Suspension | 5 | 03-03-2001 10:24 AM |
| (Yes I did a search) Coolant Questions | HomerJay | General Forum Archive | 2 | 01-05-2001 05:15 AM |
| Front sway bar Question (I did a search) | Impreza Rider | Technical Forum Archive | 2 | 09-18-2000 07:41 AM |
| best site for MY00 SAFC install info (already did a search) | Keirik | Technical Forum Archive | 19 | 07-20-2000 07:38 AM |
