Old 07-02-2001, 10:20 AM   #1
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default Thermal wrap protection! GOOD OR BAD
I was wondering, I just purchased and received my Borla header and would like to know it wrapping it with thermal material would be a good thing...vice versa the intake tubing too!!!
CRAZY KEN
CRAZY KEN is offline   Reply With Quote
Old 07-02-2001, 10:28 AM   #2
Julian
Member#: 1182
MY00 RS
BRP
You'll want to hit the ol' 'search' function. This has been discussed before, though each side held to it's own opinions in the end.
The wrap will hold in heat, as it is designed to, but the effect it has on the metal of the header can be very dramatic. Less so with the stainless, but it still really isn't recommended. Basically, the retained heat changes the composition of the metal in the header, breaking it down over time. Contact Borla and ask their opinion.
FWIW, buying enough wrap to do the header is probably nearing the same price to get the manifold ceramic-coated. Ceramic coating is inside and out, so the heat (on the inside) doesn't get a chance to sink into the metal. I plan to go this route if my MRT system ever arrives.
Julian
Julian is offline   Reply With Quote
Old 07-02-2001, 02:39 PM   #3
gavin
Member#: 3198
2005 GT LTD Wagon
Garnet Red
The wrap will also hold in moisture. Your header's won't last long, wrapped. Ceramic coating is the way to go, if EGT is an issue for you.
gavin is offline   Reply With Quote
Old 07-02-2001, 07:32 PM   #4
scooby5
Member#: 1998
1999 Impreza STi v5
Silver Mica
There's a Good article about the misuses of exhaust wrap
Mind you, there is some truth to it, but the explanation as to why misusing wrap causes those nightmares makes sense.
I've put some wrap on my exhaust header and painted it for protection, I don't expect cracks or moisture to ruin it anytime soon.
It's all in the installation process.
scooby5 is offline   Reply With Quote
Old 07-03-2001, 10:20 AM   #5
mikemo
Member#: 7627
93 L Wagon
Blue (ish)
Header wrap WILL hold mositure and WILL make your header rust. Been there, done that. Get it ceramic coated if you want to keep the underhood temps down.
Regards,
Mike M.
mikemo is offline   Reply With Quote
Heat wrap downpipe good or bad? armysti24 Newbies & FAQs 4 09-30-2008 08:31 AM
DOUBLE Wrapping Turbo Cover Good or Bad? wrxtool Southern California Impreza Club Forum -- SCIC 7 04-04-2008 09:07 PM
Turbo Wrap...Double Wrap GOOD or BAD? wrxtool Newbies & FAQs 12 03-28-2008 07:54 PM
Header Wrap Good or Bad? koblerone Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-02-2006 11:50 PM
Wrapping uppipe heatsheild good or bad idea? MachinesWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-10-2006 12:44 AM
