Welcome to the North American Subaru Impreza Owners Club Wednesday July 1, 2015
Old 07-02-2001, 12:07 PM   #1
adam@stonehill.edu
Member#: 6655
2000 Impreza 2.5RS
Dirty White
Default Help!: Autometer A/F Gauge Install
Hello,
Just wanted to know if anyone here has installed an Autometer Air Fuel Ratio gauge in their RS. I have the ECU diagram for a 2000 2.5RS but don't know which ECU wire to tie into. I'm guessing that I want the signal from the front O2 sensor but there are 4 of em?
Anyone know which of the 4 I should use? The pins are:
Front O2 signal 1: B136 Pin 19
Front O2 signal 2: B136 Pin 6
Front O2 signal 3: B136 Pin 7
Front O2 signal 4: B136 Pin 20
Thanks for all of yer help!
- Adam
adam@stonehill.edu is offline   Reply With Quote
Old 07-02-2001, 01:11 PM   #2
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
I just put one it yesterday in my01 rs. b136 #18
adeck is offline   Reply With Quote
Old 07-02-2001, 01:19 PM   #3
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
Old 07-02-2001, 01:35 PM   #4
inpreza kid
Member#: 3334
the MY00 uses a wide band o2 sensor for the front one so you have to hook it to the rear sensor. you hook it up to connector b136 wire 18. and i think its a white wire but not sure.
inpreza kid is offline   Reply With Quote
Old 07-02-2001, 01:43 PM   #5
Safir
Member#: 3873
. Paradise is
like Disney with hookers
ditto. rear o2 sensor b136 wire 18 'tis white... forced4.com has the pinout for people who are lacking in that area.
Safir is offline   Reply With Quote
Old 07-02-2001, 01:58 PM   #6
MBX Motorsports
Member#: 3726
2001 2.5RS
Blue Ridge Pearl
OK, I'm about to do the same thing here, so let me get this straight. The MY00 you have to use the second O2 sensor, but for MY01 (mine) I can use the first O2 sensor?
MBX Motorsports is offline   Reply With Quote
Old 07-02-2001, 02:11 PM   #7
adeck
Member#: 6840
2001 2.5RS
Blue Ridge Pearl
MY01 you have to use the second also.
Old 07-02-2001, 02:19 PM   #8
jeffg
Member#: 2958
2001 WRX (GC8)
someone posted that on the MAF based cars both O2 sensors are narrow band, so that is where you may have gotten the info about the front O2 sensor.
jeffg is offline   Reply With Quote
Old 07-02-2001, 02:32 PM   #9
JGard
pooptastic
Member#: 1904
2011 BMW X5 35D
01 Miata red
the only thing I don't get is...
on the MY00-01 wiring diagram. it says that the voltage range of the fron O2 sensor is 0-1.0 V, which is what the A/F gauge reads. So why couldn't that be the correct one?
JGard is offline   Reply With Quote
Old 07-02-2001, 04:05 PM   #10
MBX Motorsports
Member#: 3726
2001 2.5RS
Blue Ridge Pearl
Ok .. so how accurate can the second O2 be? I mean it's after the cat, so what good is it?
Old 07-02-2001, 04:09 PM   #11
inpreza kid
Member#: 3334
the rear o2 is about +/-10% off. this is just a guess. it reads leaner than it really is. you can't really do any tuning with it. it just gives you a idea.
Old 07-02-2001, 04:53 PM   #12
jeffg
Member#: 2958
2001 WRX (GC8)
Jgard,
which MY00-MY01 wiring diagram are you looking at? The signal voltage for the front O2 sensor is 0.2-4.9 volts.
Jeff
Old 07-02-2001, 06:12 PM   #13
JGard
pooptastic
Member#: 1904
2011 BMW X5 35D
01 Miata red
B134. Front oxygen sensor heater... hmm, guess that's wrong, eh?
Autometer oil pressure gauge install question sethb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 02-08-2005 07:59 PM
Autometer Oil temp gauge install ? wonny Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 09-20-2004 03:44 PM
Autometer oil temp gauge install help. charliek Electrical & Lighting 1 04-23-2004 02:28 PM
Autometer Air Fuel Gauge Install finger123 STi Forum Archive 0 08-31-2003 05:25 PM
Autometer 3301 boost gauge install -=C=- Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-10-2002 08:18 PM
