Old 12-03-2004, 01:55 PM   #1
snow111
Member#: 60153
2002 Impreza TS
Sold it.
Default Headlights coming on and off intermittently
I am having problems with my headlights. One bulb keeps turning on and off intermittently. I have checked the connectors and bulbs as well. Do you know what could cause this?
snow111 is offline   Reply With Quote
Old 12-03-2004, 02:00 PM   #2
hey1
Member#: 72106
2002 Impreza WRXagon
Platinum Silver Metallic
stock headlights?
hey1 is offline   Reply With Quote
Old 12-05-2004, 04:51 AM   #3
snow111
Member#: 60153
2002 Impreza TS
Sold it.
they are higher wattage bulbs, the ones with xenon gas. still using the stock headlights, not a projector type or anything like that.
Old 12-05-2004, 07:12 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The higher wattage bulbs have probably damaged your connectors and/or harnesses from the excess heat. Only stock wattage bulbs should be used to avoid this problem, the 9007 configuration cannot support the extra heat safely.
Examine your wiring carefully, if the connectors and/or harness ends have melted go to the parts store and get replacement 9007 connectors w/wire pigtails. Cut the damaged portion off and splice in the replacement using proper methods (preferably solder and heat shrink).
Get rid of the bulbs you have and replace them with stock wattage ones. Don't use cheap aftermarket bulbs (such as sold on Ebay) that are sold as "hyperwhite", "HID look", "superblue" etc. even if they are the stock wattage as some of these can still overheat and cause damage. For safely improved lighting with the proper wattage try a set of Sylvania Xtravisions.
Old 12-06-2004, 01:37 AM   #5
snow111
Member#: 60153
2002 Impreza TS
Sold it.
Thanks Mulder. What about Piaa superwhite, would you say those are safe?
Old 12-06-2004, 07:32 AM   #6
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I wouldn't bother with PIAA. They may be somewhat better than the really cheap bulbs, but might still run hotter and damage the harnesses. Also they are expensive and do not last all that long. Try a set of Xtravisions, they can be found at most parts stores and should have a similar life to OEM bulbs.
Old 12-14-2004, 01:38 AM   #7
snow111
Member#: 60153
2002 Impreza TS
Sold it.
Thanks Mulder. You are right, the connectors were melted and damaged. Successfully soldered replacement sockets and put in Sylvania bulbs this weekend.
BTW, say hi to Scully.
Brake light comes on and off but not low on brake fluid? IIdiceII Brakes, Steering & Suspension 5 09-13-2007 10:44 PM
ABS light come on and off. trinistyles Newbies & FAQs 1 11-02-2004 07:44 PM
"brake" light comes on and off at random OneArmedScissor Brakes, Steering & Suspension 5 08-13-2003 10:09 PM
e-brake light coming on and off... help? scaryfastskier Brakes, Steering & Suspension 9 06-26-2003 04:12 PM
Check engine light coming on and off, seemingly randomly GusS Legacy Forum 8 12-07-2001 01:50 PM
