Old 12-03-2004, 04:48 PM   #1
KnightWRXRider_
Member#: 30496
2004 STi
Default Recommended tire pressure?
What is the recommended tire pressure for an STi from subaru? What do you guys recommend? Thanks.
KnightWRXRider_ is offline   Reply With Quote
Old 12-03-2004, 07:27 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Set all your tires to XXPSI. Drive. Change to XX+2 PSI. Drive. Change to XX+4 PSI. Find what works for YOU and stick to it. No one here can tell you what you will like anymore than anyone can tell you which shoes will fit your feet the best.
Old 12-04-2004, 08:57 AM   #3
boxered
Member#: 61884
The stock tire pressures (36F/30R) promote understeer and we really don't want more understeer, do we? Most experienced STi drivers are running equal pressure to bring the rear into play a bit more. Bump the rears up to 36psi and see how that grabs you.
boxered is offline   Reply With Quote
Old 12-04-2004, 12:18 PM   #4
yergi
Member#: 65303
nope nope
"dooby specialist"
ya know this pressure info is posted in the door jam, right?
yergi is offline   Reply With Quote
Recommended Tire Pressure for 225/R16 on a 02 WRX Wagon DamonL Tire & Wheel 8 02-26-2004 06:40 PM
Luke: recommended tire pressure for SP5000's Racerx5410 Tire & Wheel 6 11-20-2003 07:55 PM
Rallycrossing on RE-92s - Recommended tire pressure? WHTWRX Brakes, Steering & Suspension 4 09-12-2002 06:06 PM
What are the recommended tire pressures for GTs? dvancleve Legacy Forum 1 06-13-2001 10:22 PM
Recommended Tire Pressures tulit Technical Forum Archive 17 07-31-2000 02:37 PM
