Welcome to the North American Subaru Impreza Owners Club Tuesday June 2, 2015
Old 12-03-2004, 05:47 PM   #1
swrtwagon
Member#: 72572
2004 wrx wagon stg 1
world rally blue
Subaru Stars what is the best "FIRST" mod for stock wrx
what is the best "first" mod for a stock 04 wrx?(e.i. exhaust etc...) my wrx wagon is stock and i want to know what is most practical and what makes a big difference. please list mod and what the mod does for the car, and if you got it done, how much it cost you. thank you.
swrtwagon is offline   Reply With Quote
Old 12-03-2004, 08:52 PM   #2
WRXWuLf
Member#: 49716
02 WRX
do you want more power?
Better handling?
I tend to try and work on where I personally feel deficiencies for my driving style. I started with the handling first since initially I loved the power. If you narrow it down I would love to give you my humble opinion.
WRXWuLf
WRXWuLf is offline   Reply With Quote
Old 12-03-2004, 09:03 PM   #3
DRIVER1
Member#: 30946
Tires
Rear sway and endlinks
Springs
Brakes
Reflash or engine mgmt
in that order
Currently you have more power than tires.
Tires will help that but then your suspension will show it's weak underbelly.
Once you've addressed that you'll need better brakes since you'll be carrying more speed.
And finally a nice reflash "Say Cobb stage 2" to get the power at a nice usuable level.
DRIVER1 is offline   Reply With Quote
Old 12-03-2004, 09:38 PM   #4
swrtwagon
Member#: 72572
world rally blue
Better handling?
WRXWuLf
i definitely would like more power. where would i start on the car? after power, what needs to be done for better handling? handling would have to improve to be able to handle the power.
Old 12-03-2004, 09:41 PM   #5
swrtwagon
Member#: 72572
world rally blue
Originally Posted by DRIVER1
Tires
Springs
Brakes
in that order
thanks for the info. much appreciated. could you explain more on what "cobb stage 2" is? i hear alot of subaru owners talking about it but don't really have a clue.
Old 12-06-2004, 11:33 PM   #6
mch
Member#: 30039
2002 wrx wagon
dirt slvr
driving school
mch is offline   Reply With Quote
Old 12-07-2004, 01:53 AM   #7
garie
Member#: 26607
2002 wrx wagon
for the cobb relashes check out www.cobbtuning.com for all the info you need.
i would get tires first, but if you want to wear down ur stockers first then i would get either get an uppipe or gut your stock one, and cobb stage 1 for some additional power right away.
Or if you are patient and wait for a while longer you can get a turboback exhaust first w/ uppipe and then get cobb stage 2 reflash. and get alot more power.
either way get both a relfash and a turboback exhaust eventually for 280ish hp/285 lbs. makes driving the car more fun, less turbo lag, more power.
-gary
garie is offline   Reply With Quote
Old 12-07-2004, 08:30 AM   #8
b0dh1
Member#: 35269
2011 WRX
uppipe
b0dh1 is offline   Reply With Quote
Old 12-07-2004, 09:31 AM   #9
my t rex
Member#: 51965
2002 WRX wagon
Bitchen Blue
I think tires, but if you just bought your car and you want to keep them for a few thousand miles deffinetly check out the accessport. Do some searching there is so much info on this forum its sick.
my t rex is offline   Reply With Quote
Old 12-07-2004, 02:20 PM   #10
saint_foo
Member#: 64364
Buy new tires (at least one set). Sell the stock RE92s...they suck. If you want good all-seasons, I picked up the Nokian WR from Tirefactory.com. Ask for Ryan and tell him you heard about it through NASIOC.
Cobb Accessport is a plug-n-play thing...costs about $600. Great for hp. Easy to use. Look it up. You basically upload fuel maps that are conservatively tuned (so you shouldn't blow up your motor) yet can free up HP and smooth out acceleration.
You may consider getting a catless DP (downpipe) in conjunction w/ the Accessport. You'll see nice power!
Also if you have a wagon, here's the first mods I did w/ suspension:
Rear sway bar (RSB) - cheap way is to buy an 02/03 sedan RSB which is 20mm. The wagon is 17mm (dunno about 2005 wagons). It should cost b/w free and $50 or so. I got mine for $35 for local pickup. If you can, spend a bit and get a good RSB and good endlinks.
STi lower arm bar (about $195) - tightened up the handling. It no longer felt like a wagon. http://www.subaruwrxparts.com/04wrx-suspension.html
saint_foo is offline   Reply With Quote
Old 12-07-2004, 04:05 PM   #11
JewPac42
Member#: 23260
Patr ick Willis
for Rookie of the year
Tires, springs ot TBE.
JewPac42 is offline   Reply With Quote
Old 12-07-2004, 08:28 PM   #12
WRXFan420
Member#: 72643
2005 Impreza WRX
WR Blue Pearl
Exhaust, uppipe and downpipe, completely changes the car. Best starting point if you want more power.
WRXFan420 is offline   Reply With Quote
Old 12-10-2004, 09:24 PM   #13
r-wrx-04
Member#: 59961
2004 WRX, 05 Outback
SRR, Obsidian
I would have to disagree with the uppipe and/or even stage 1. You will feel almost NO differance with just an uppipe/stage 1. Sure the #'s will be a little higher from stock, but barely if even noticable in the seat. You will however notice a huge differance with an uppipe and turboback, and even greater with a stage 2 reflash.
r-wrx-04 is offline   Reply With Quote
Old 12-13-2004, 05:17 PM   #14
LilRedWagon
Member#: 76065
2005 Saab 9-2x Aero
Brilliant Red
Since no one else has said it I'm gonna say:
disable DRL's
Purchase short throw shifter.
Ok so that was two mods. But one was free so it doesn't count!
LilRedWagon is offline   Reply With Quote
Old 12-14-2004, 12:50 AM   #15
BlackRex20
Member#: 73603
2004 WRX Java
Black Pearl Cobb Stage 2
Default Best Bang for Buck
The best way to mod a stock rex (engine-related) is definitely Cobb's Accessport ECU (either Stage 1 or 2 depending on how much power you want to make...260hp vs. 280hp). I would recommend this product not only for it's power and reliability, but also because there have been a lot of problems with the factory 04's and 05's due to their ECU programming. The EPA has pressured Subaru to make their cars more emission friendly, so what they have done is mapped the ECU so that the car runs very lean until around 4-5k RPM, then dumps a bunch of fuel in during the last couple hundred RPM's. I think the fuel flow in % is from around 60% up to 4-5k RPM, then up to 90x% after that. The A/F ratios are also way too lean for how much boost the stock turbo puts out (13.5psi). This results in knock or detonation and can eventually lead to engine damage/failure if not corrected. I have an 04 wrx with a TBE and a GFB BOV, so it's hard to hear if the engine is knocking or not (and even if I can't hear it, it might still be knocking), but I've noticed some of the symptoms that are characteristic to this problem which are:
1) A surging or onset of power at or close to 5k.
2) A bucking at 5k.
3) High EGT's (loosely defined as 1600 degrees or above measured at the up-pipe or down pipe).
4) Detonation anywhere in the RPM range.
5) Feels down on power or lethargic.
I have recently ordered the Cobb Accessport Stage 2 and am installing it in the next month. The re-mapping of the A/F ratio, timing and boost should be fixed so that this problem is non-existent after the re-flash. So if you're looking for more engine performance for not a lot of money, go with Cobb.
If anyone wants more information about this, check out Cobb's forums, then click on "Technical discussions about the WRX" thread, then scroll down and you'll see the "04 and 05 WRX Detonation, Call to Arms" topic.
Sorry for the long post but I find this situation inexcusable by Subaru. If you buy a high performance car like a wrx, the car should come stock without any defects. (especially one as serious as a bad ECU map)
BlackRex20 is offline   Reply With Quote
Old 12-15-2004, 02:42 PM   #16
klrwrx
Member#: 71788
Originally Posted by mch
driving school
Agreed.
That or my first install was a short throw shifter.
klrwrx is offline   Reply With Quote
Old 12-16-2004, 03:52 PM   #17
EnforcerPSU
Member#: 76849
2011 WRX
Rally Blue
This cobb tuning option seems like great investment. I am gonna check it out.
EnforcerPSU is offline   Reply With Quote
Old 12-16-2004, 04:02 PM   #18
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
Driving school gets my vote.
Most people don't know how to drive a turbo effectively anyway...
Huffer is offline   Reply With Quote
Old 12-17-2004, 09:55 AM   #19
Silverboost
Member#: 42387
2002 wrx
tbe, upipe and utec
Silverboost is offline   Reply With Quote
Old 12-17-2004, 10:26 AM   #20
Sperm
Member#: 25038
2002 PSM WRX sedan
TIRES, TIRES, TIRES.
Then I'd say an uppipe.
If you wanna be proper about things, you should do it in this order:
Brakes
Suspension
Power
Of course, I couldn't resist doing some power stuff first so I doubt you will be able to either.
Sperm is offline   Reply With Quote
Old 12-28-2004, 04:39 PM   #21
Jonnyfilmboy
Member#: 68902
2011 WRX - WRBM
1988 Fiero GT - black
You are all wrong. The best first mod should be a new shift knob. It's something you use every day, something that will improve the looks of your interior, and it will help the transmission shift more smartly. I just replaced mine with a MOMO and the whole car just drives different. The old stock shift knob has a weak plastic interface with the shift lever which makes shifting sloppy. Get a direct metal to metal connection and you will be good to go. This is also a cheap mod, cheaper than tires, brakes and everything else that was mentioned. And it is something you can install yourself. I think if you dive right in with replacing your exhaust or brakes and you have a bad experience with the installers, it might taint the rest of your experience with your car and you will end up sad and alone living in a van down by the river.
You asked for the best FIRST mod, to me, that's it. All those other things can be done second.
Jonnyfilmboy is offline   Reply With Quote
Old 12-28-2004, 05:08 PM   #22
Malfrag
Member#: 14288
DRINKING CHEAP RYE
I'd say getting a set of 17" wheels and decent rubber would be a start. Improve the looks and handling in one fell swoop.
Malfrag is offline   Reply With Quote
Old 01-09-2005, 12:22 PM   #23
jeffildy
Member#: 48565
2002 WRX Wagon
Gold on Silver
driving school
2nd that
jeffildy is offline   Reply With Quote
Old 01-09-2005, 12:28 PM   #24
TheWicked
Member#: 78258
3rd that. you can have the fastest car in the owrld at your disposal, but if you cant drive it properly (and there is a difference between driving and commuting) it will be a weapon you can never use. sorta like a gun with no bullets.
TheWicked is offline   Reply With Quote
Old 01-17-2005, 05:19 PM   #25
da n00b
Member#: 65951
02' e46 ///M3
Imola Red
Suspension mods?
da n00b is offline   Reply With Quote
What is the best suspension combo for the WRX? Jay04WRX Brakes, Steering & Suspension 4 07-08-2003 02:00 PM
Recommendation needed: What is the best brakepads upgrade for stock wrx rotors S-WRX Brakes, Steering & Suspension 11 08-12-2002 11:53 AM
What is the best aftermarket setup for the wrx wagon? Whitey Brakes, Steering & Suspension 15 07-16-2001 08:28 PM
('93-'01) what is the best power mod to do first for a MY99 RS? aarneson Impreza Forum 2 05-21-2001 07:37 PM
