Old 12-03-2004, 07:24 PM   #1
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow New tires, which tire pressure to go by, tire or car?
Just got Pzero's and wonder which tire pressure to go by? The one that is listed on tirerack for the Pirelli tires or do I use what the inside of the driver's door states for recommended tire presssure. Any pros or cons to using either or? I just don't want a blown tire and end up getting killed.
Thanks a bunch :-)
-Nigel
NewShockerGuy is offline   Reply With Quote
Old 12-03-2004, 07:44 PM   #2
Skeete
Member#: 52569
2004 STi
i have mine at ~40psi upfront and ~36psi in the rear and it's riding well for me.
Skeete is offline   Reply With Quote
Old 12-03-2004, 08:14 PM   #3
Got Groceries?
Member#: 25323
2003 WRX Wagon
Always check the side of the tire for the max pressure of the tire, and stay under that. I'm running no more than 40 on my stock sized Continentals.
Got Groceries? is offline   Reply With Quote
Old 12-03-2004, 09:58 PM   #4
NewShockerGuy
Member#: 40736
2005 WRX STI
Arrow
Is there a reason to have more psi in the front than the rear... I always thought they had to be uniform for all four?
I'm gonna check now on the tire and see what max PSI is.
Thanks,
-Nigel
Old 12-03-2004, 10:13 PM   #5
RankFrank
Member#: 60682
2006 WRX
Thanks,
-Nigel
My understanding is that they should approximate weight balance. My MR2 is 28 in the front and 32 in back. Of course, it's also 2/3rds the weight of your car.
RankFrank is offline   Reply With Quote
Old 12-03-2004, 10:45 PM   #6
Got Groceries?
Member#: 25323
2003 WRX Wagon
Weight distribution is the reason, you're right RankFrank. About 4lbs higher in front seems to be the average 'round these parts. Helps kill the understeer, more grip for the fronts.
Old 12-04-2004, 01:05 PM   #7
Skeete
Member#: 52569
2004 STi
Old 12-04-2004, 02:33 PM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
1-the pressures listed on your car only work for the OEM tires or a similar one.
2-I use the rule of ~80% of max inflation as listed on the tire for normal use. Thus if it has a max of 51psi, I use ~41psi. This is a good starting point and adjust from there.
I also use a ~4psi spread front to rear for removal of understeer.
Which intake to go with for my car? Poll txl146 Newbies & FAQs 7 05-14-2008 06:22 PM
which dealer to go in Sacramento or bayarea? yuen_kevin Dealership Reviews 0 08-24-2006 12:56 PM
Which turbo to go with; SZ55 or Garrett GT35R? Ozer Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 46 10-15-2005 12:21 AM
What pressure to run my tires at??? 2003YlwSubaruWRX Newbies & FAQs 11 02-25-2003 06:04 AM
New tires, need alignment. Where to go? chyisan Texas Impreza Club Forum -- TXIC 10 01-31-2002 12:49 AM
