Old 07-02-2001, 02:08 PM   #1
malelee21
Guest
Member#:
Default MY00 Honda EX problem!!
Hello, I am a current owner of 2002 WRX but owned 95 Honda Civic EX coupe (AUTO). My friend's 00 Honda Civic EX (AUTO) has a little problem. When I floor the car, it feels sluggish and don't have that VTEC power that I felt on my 95 civic. Current mod he has is K&N intake, and aftermarket muffler + muffler shop mid-pipe. On my 95 Civic, even with stock parts, when floored, it lauched nicely (much better than 00 Civic) with that VTEC noise. Can you suggest anything that I should check on his car???
Thanks
Tim
Old 07-02-2001, 02:13 PM   #2
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
Should this be moved to off-topic?
wcbjr is offline   Reply With Quote
Old 07-02-2001, 02:15 PM   #3
Texas25RS
Member#: 3148
2012 Mazdaspeed 3
Crystal White Pearl Mica
Default What is this?
First of all... go to club Si for a problem with a Civic, but to me it sounds like either fouled plugs or a bad O2 sensor. One of my friends had an Accord that was really slugish and even when it got going to car would slowly cut the fuel mixture until the car died because the O2 sensor was going out.
But I never had a problem like that in either of my Integras, my Prelude or even my Accord :-)
Texas25RS is offline   Reply With Quote
Old 07-02-2001, 04:58 PM   #4
dRu18
Member#: 4034
2005 Infiniti G35c
Ivory Pearl
Default civic ex
lemmie see... i drove my friend ex 00 that was like your friends.. and there's a KICK wehn you floor it?? but i think it might be his setup has too large piping and not enough backpressure for the car to get a good "go"
andrew
dRu18 is offline   Reply With Quote
Old 07-02-2001, 06:20 PM   #5
Blindeye_03
Member#: 4418
2016 Focus ST
go to www.superhonda.org
All of your questions will be answered .
Blindeye_03 is offline   Reply With Quote
Old 07-02-2001, 06:57 PM   #6
chuckles
Member#: 2955
02 Chuck Wagon
Oh yea its white
the Honda problem that your friend is having is that he bought a honda!
chuckles is offline   Reply With Quote
Old 07-02-2001, 06:59 PM   #7
imprezadan
Member#: 6935
1999 Impreza 2.5RS
Rally Blue
Is the v-tec solenoid not engaging the secondary arms?
imprezadan is offline   Reply With Quote
Old 07-03-2001, 01:34 AM   #8
malelee21
Guest
Member#:
I changed the spark plugs to split fire platinum ones and reprogrammed ECU. I feel that VTEC power now
Old 07-03-2001, 03:18 AM   #9
DoomEquation
Member#: 6974
1984 GM6
BRP
the only problem you should ever post on a subaru board about an EX is the unlikely event that you lost a race to one. In which case i would say, its either engine swapped or turboed to ****. the problem you have is that you are going to the wrong place with the wrong problem. someone said club si?
DoomEquation is offline   Reply With Quote
Old 07-03-2001, 08:15 AM   #10
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
I used to own a 98 Civic EX (same engine as 00 EX).
When I changed the intake and exhaust on the Civic, I lost a lot of low-end torque that it wasn't even funny. But, it gave me a nice push once VTEC engaged. So, my idea about your buddy's Civic is that because of added diameter in the exhaust, his car lost low-end torque. Thus sluggish before the VTEC engages at 4500RPM-ish.
tmat3 is offline   Reply With Quote
wrx to Honda ex-l v6 coupe hotsauce61488 Off-Topic 24 02-25-2010 04:57 PM
FS: 1992 honda EX BrianH MWSOC Private Classifieds 22 08-12-2006 07:09 PM
MY00 BE Electrical Problems... Acejam2k Legacy Forum 10 06-08-2004 05:25 PM
MY00 map/boost problem Keiho Normally Aspirated Powertrain 20 01-01-2001 07:31 PM
Any MY00 air sensor problems. Geb Firneisz Technical Forum Archive 6 05-24-2000 12:25 AM
