Old 12-04-2004, 12:25 AM   #1
turbo2
Member#: 55908
02 WRX
Default JDM WRX motor into US WRX?
Is the US harness and ECU plug and play? I know the AVCS system will be lock in the high lift cam but what about the fuel mapping for the JDM engine? I'm onlying getting the V8 JDM EJ20 engine without harness, ECU, turbo, intercooler. What are the HP figures on JDM WRX?
kou
turbo2 is offline   Reply With Quote
Old 12-04-2004, 12:59 AM   #2
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
I think you could get it to run, but the jdm V8 motor has different compression, injectors, and cams. I would say it would be foolish to spend $4000 on a motor and not tune it to be safe.
RS_to_WRX_swap is offline   Reply With Quote
Old 12-04-2004, 02:01 PM   #3
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
LOL the USDM WRX engine and the JDM are 2 different beast. If you could get it to run on the USDM ECU you wouldn't have the power or the reliability you would expect from it!!!
Get it tuned!!!!!!!!!!!
DuoMaxwell is offline   Reply With Quote
Old 12-04-2004, 09:47 PM   #4
turbo2
Member#: 55908
02 WRX
Could you guys give me some engine specs? Compression ratio, injector size, so on?
kou
Old 12-05-2004, 03:46 AM   #5
Mumbles
Member#: 248
Dude, have you attempted to do a search? There is alot of information on this board... all you have to do is find it.
Mumbles is offline   Reply With Quote
Old 12-05-2004, 03:56 AM   #6
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Thank you Mumbles!!! I hate saying do a search!!!
Old 12-05-2004, 03:59 AM   #7
Mumbles
Member#: 248
I never say do a search and i hate it when poeple say it, but man.... it's just getting stupid.
Old 12-05-2004, 04:26 AM   #8
Mumbles
Member#: 248
Old 12-05-2004, 12:03 PM   #9
turbo2
Member#: 55908
02 WRX
You do a search and see what you find cuase I'm not sure what I'm doing wrong. How the hell you suppose to search for "V8 jdm ej20". for one thing, you can't use two letter words and another, their is lots and lots of ej20 subjects floating around (not just v8 but all versions). If anything, there should of been a sticky at some point about engine specs. Its just common sense. So please reframe from that "do a seach dumb ass" *****.
Old 12-05-2004, 12:09 PM   #10
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
ROFLMFAO did you try just researching V8 EJ207???
Old 12-05-2004, 12:10 PM   #11
Mumbles
Member#: 248
Every single question you posted up there has been gone over and over again. Search in this forum only for specs you will find them. And i don't reframe, i'm a software engineer by trade.
Old 12-05-2004, 12:14 PM   #12
cronic
Member#: 9749
Its an ej205 btw..
cronic is offline   Reply With Quote
Old 12-05-2004, 06:46 PM   #13
turbo2
Member#: 55908
02 WRX
Ok, since its be covered over and over again, how come I don't see it? 8 pages of nothing but sti stuff and older ej20's. If you know where it is and easy for you to look it up why don't you link it to this post?
Old 12-05-2004, 06:48 PM   #14
Mumbles
Member#: 248
Because if i do that, then you don't learn to do better searches.
Old 12-05-2004, 07:03 PM   #15
turbo2
Member#: 55908
02 WRX
Why people post in here if they can't answer my quetion or give any helpful information? I don't know.
Old 12-05-2004, 08:32 PM   #16
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
Sorry man, it happens a lot here. Freaking annoying if you ask me. You're best bet is to find a JDM ecu, as I'm pretty sure if the WRX ecu makes it run, it won't run well.
Capt Crunch is offline   Reply With Quote
Old 12-05-2004, 09:51 PM   #17
d12agonxboi
Member#: 48347
1999 2.5rs
Silverthorn Metalic
here is a nice little link to describe the engine differences
http://www.spdusa.com/new_page_4.htm
d12agonxboi is offline   Reply With Quote
Old 12-05-2004, 10:15 PM   #18
moss
Member#: 10197
kou
So you're getting a JDM non-STi V8 WRX motor? And putting it into your WRX? I don't know if the V8 wiring harness is any different than the V7, but the V7 is a plug and play ordeal, so if they're the same, then its plug and play. If you want AVCS, you have to run 8 extra wires, or I think ECS has an AVCS kit.
Running the JDM engine off the US ecu? No... bad idea. enough said about that.
Where did you source the motor? I'm looking for a JDM non-STi WRX motor.
moss is offline   Reply With Quote
Old 12-05-2004, 10:57 PM   #19
jamesfacts
Member#: 51282
98 RS
black & blue from parking
You're absolutely right! You tried some incorrect search terms and got nothing... you had no choice.
There are already at least 210432174219832897543 threads pondering the possibility of swapping a JDM motor of some flavor into a WRX. Its not hard to find them. Believe it or not, not everyone can sit around and search for you. Even if the info isn't on NASIOC (which it probably is) there are always other web pages.
These can be located with the assistence of many popular "search engines" such as www.google.com.
jamesfacts is offline   Reply With Quote
Old 12-05-2004, 11:07 PM   #20
jamesfacts
Member#: 51282
98 RS
Because your question has already been answered with helpful information.
The same questions get pretty old when they're asked ten times a week.
Old 12-06-2004, 12:02 AM   #21
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
I think he is talking about this motor.
JDM V8 Spec C Engines!!!
-Less than 1000KM!!
-2.0 Liter, High-Flow Spec C heads
-Long Block includes all pumps, sensors, intake manifold etc
$3995 Shipped
http://forums.nasioc.com/forums/showthread.php?t=674321
V8 JDM WRX EJ20 Engine
-Less than 1000KM!!
-2.0 Liter, AVCS, JDM Motor
-Higher compression than USDM motor
$1750 Shipped
Old 12-06-2004, 12:10 AM   #22
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
kou
The ecu is plug and play... the jdm wrx does not have a high lift cam. The fuel mapping and timeing are not ideal for us gas. Are you talking about a ej205 wrx motor or a ej207 motor? Because it would be a total waste for all this work just to have avcs.
Simply put jdm wrx motor in a US wrx with a US wrx ecu running it gets you a 227 hp US wrx that cost you way too much money.
Are you maybe talking about a ver 8 jdm STi motor? With hyper-cast pistons? Large port heads? Fancy forged crank? 280+hp out of a twinscroll turbo. Not that that would matter to you... because you wouldnt have the turbo anyway. Kind of pointless to ask about hp figures for a set up that you wont have, isnt it?
You get an F in searching and Looking At The Stickys 101 you also fail. http://forums.nasioc.com/forums/showthread.php?t=386462
This thread answers most of your questions and shows you the right key words to use in your search. "v8 jdm ej20" must get you a massive about of useless crap. Maybe you should try ver 8 or ver. 8 and you should spend at least some time reading all thoes other threads on ej20s. You may just learn something...
Old 12-06-2004, 12:19 AM   #23
turbo2
Member#: 55908
02 WRX
You the man
Old 12-06-2004, 01:01 AM   #24
turbo2
Member#: 55908
02 WRX
The deal is, my stock wrx engind mess up to the point of no return. so my options is to buy a US wrx engine for a low of 2,000 with over 30k miles or get a V8 JDM wrx motor without harness, intercooler, turbo, tranny with almost no miles at all for 1,700. The idea is to have my car running again, not major performace (although a SMT-6 will be used with a wideband 02 logger to tune the ecu mapping if really needed). The worries is of fuel mapping problems due to differences in the motor. Stock ECU will be used, stock harness will be used and maybe injectors too if they are the same (as the first person stated them being different).
And no you can't use ver 8 or ver. 8 because 8 is one character. Not allowed in the search engine nor v8 or any combination of that nature. And who refers different versions of engine by "ver" or "ver.", you will find that its most commonly stateds with a "V" and then the number. So what do you get doing this seach? the exact same thing!
And yes I've reading all those dam ej20 threads. Every single one of them. Didn't do jack ships for me. Sure I learn alot about ej22 and earlier ej20 motors swapped to GC8 chassis. I also learn a ship load about sti ej207 but thats does me no good to my swap.
And yes I also read the dam 101 stick but did it answer any of my questions? NO!.... All I wanted was engine specs of the JDM V8 ej20 and if it was compatable with US 2002 WRX.
So what I learn form those of you who did help me? I learn that the AVCS works with only the intake cam, the compression ratio of the jdm ej20 V8 is higher, the injectors are different (still questionable at the moment).
Thanks to those who did help me out.
Old 12-06-2004, 01:25 AM   #25
totoherbs
Member#: 7321
.... 122 IggPoints
The injectors are not different... they are both using the same ej205 top feeds. I dont remember the CCs...
The only differences between the two motors is the avcs, but subaru may have throw a few different things in there. They tend to do that, so you dont realy know if everything will connect right up untill you get it. More then likely it should...
How bad is your stock motor? Can it be rebuilt? Are both the heads and short block gone?
As for the search I use this. Not the forums search so I dont know about 2 word limits.
http://www.google.com/search?hl=en&l...22oil+smell%22
JDM motor into 02 WRX NLspiked02 Subaru Conversions 0 04-11-2007 10:33 PM
jdm motor into 02 wrx vic ferrari Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-28-2005 11:14 AM
Jdm Sti motor into a 02 Wrx Benchracer1320 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-30-2003 09:36 AM
Implant US 2.5RS tranny into US WRX B-Kerr Transmission (AT/MT) & Driveline 6 09-26-2002 08:17 PM
('93-'01) what's the diff b/w the jdm WRXs and the US WRXs? TypeR_FordEscort Impreza Forum 4 09-09-2001 05:38 PM
