Old 12-04-2004, 10:30 AM   #1
WrexFactor36
Member#: 63700
2002 PSM WRX 4EAT
Protuned Stage 2
Default cobb stage 2 plus headers
what headers are u guys running with ur cobb stage 2? are there headers that will keep or increase low end power while increasing top end? thanx guys
WrexFactor36 is offline   Reply With Quote
Old 12-04-2004, 10:47 AM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Borla
No such header exists. ALL headers reduce low end to one degree or another.
Old 12-04-2004, 10:50 AM   #3
WrexFactor36
Member#: 63700
2002 PSM WRX 4EAT
Protuned Stage 2
hey unabomber, do u have a faq for cobb stage 2 setups and what mods i can do to maximize the stage 2 program?
Old 12-04-2004, 10:55 AM   #4
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Add:
Lightweight pulley
Headers
Deadbolt P&P stock turbo
Lightweight flywheel
RA gears or other tranny option
Bigger TMIC
Bigger FMIC
Smaller diameter tires
4.444 final drive conversion
TGV deletes with phenolic spacers
Turbo inlet
Silicone MAF tube
Lightweight battery
Weight reduction
There's a whole buttload of stuff you can do really.
Old 12-04-2004, 11:00 AM   #5
WrexFactor36
Member#: 63700
2002 PSM WRX 4EAT
Protuned Stage 2
thanx man for the list
Old 12-04-2004, 11:58 AM   #6
Bankie
Member#: 37785
OT hates your car
No uppipe on that list?
Bankie is offline   Reply With Quote
Old 12-04-2004, 12:27 PM   #7
Red Rexx
Member#: 67187
2004 STi
Should already have one by Stage 2 along with your tbe....
Red Rexx is offline   Reply With Quote
Old 12-04-2004, 01:25 PM   #8
jjunior887
Member#: 16738
2015 WRX Limited
CWP
Not a requirement according to cobb to run the stage 2, but I agree at this point you should have that done anyway.
jjunior887 is offline   Reply With Quote
Old 12-04-2004, 06:49 PM   #9
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
Just be careful adding anything to an off the shelf flash that increases VE if you live at or near sea level. Such additional mods can cause a lean condition on a per case basis.
Anyway, have fun.
Dave
OppositeLock is offline   Reply With Quote
Old 12-04-2004, 06:52 PM   #10
AdamRX
Member#: 67601
'08 WRX Sdn
Slvr
wouldnt a bigger FMIC with a stock turbo be kinda worthless? It would really increase the lag, no???
AdamRX is offline   Reply With Quote
Old 12-04-2004, 07:19 PM   #11
WrexFactor36
Member#: 63700
2002 PSM WRX 4EAT
Protuned Stage 2
what's VE?
Old 12-04-2004, 07:22 PM   #12
WrexFactor36
Member#: 63700
2002 PSM WRX 4EAT
Protuned Stage 2
Anyway, have fun.
Dave
what's VE?
Old 12-04-2004, 07:27 PM   #13
banzai
Member#: 63926
Axis /RAW 2.2 Closed
deck EJ 20G stroker
what's VE?
Volumetric Effencency (sp) but you get the idea...
banzai is offline   Reply With Quote
Old 12-04-2004, 07:52 PM   #14
JalopySiR
Member#: 39378
2004 Carless
98' VFR800Fi/02' RC-51
Forgive my ignorance, but if you add anything to a car that adds HP/TQ, haven't you just increased the VE?
JalopySiR is offline   Reply With Quote
Old 12-05-2004, 08:23 AM   #15
OppositeLock
Member#: 54060
Anything that increases air in/out will change VE. Things such as upgraded ignition systems or pullies, which can give small increases in hp/tq do not affect VE. My only point was that adding parts to a flash that is not tuned for those parts, particularly near sea level may be dangerous.
Volumetric efficiency (VE) is used to describe the amount of fuel/air in the cylinder in relation to regular atmospheric air. If the cylinder is filled with fuel/air at atmospheric pressure, then the engine is said to have 100% volumetric efficiency. On the other hand, super chargers and turbo chargers increase the pressure entering the cylinder, giving the engine a volumetric efficiency greater than 100%. However, if the cylinder is pulling in a vacuum, then the engine has less than 100% volumetric efficiency. Normally aspirated engines typically run anywhere between 80% and 100% VE. So now, when you read that a certain manifold and cam combination tested out to have a 95% VE, you will know that the higher the number, the more power the engine can produce.
Dave
09 WRX Stage 2 plus headers Fine Line Imports Proven Power Bragging 40 09-24-2009 02:30 PM
06 STi stage 2 plus header Fine Line Imports Proven Power Bragging 6 07-29-2009 07:31 PM
downpipe only plus cobb stage 2 reflash showcasewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 08-09-2005 09:10 PM
perrin turbo inlet hose installed-cobb stage 2 with headers, uppipe, pulley garie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 03-01-2005 05:06 PM
Cobb Stage 2 plus stealthback BHawk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 02-14-2005 02:28 AM
