Old 07-02-2001, 02:50 PM   #1
Hyudra
Member#: 7559
2002 Impreza 2.5RS
Midnight Black Pearl
Default What are the cheapest and best mods for a 2002 impreza 2.5RS?
I don't know if this has been asked recently, but I want to get some mods for my car, but cheap and good ones.
I'm more interested in mods that won't void my warrenty, since some or most of you must have contacted subaru about mods at one point or another.
My friends said I can add a intake and exhaust, and that won't void my warrenty, and would probably be the best upgrade I could get.
Hyudra is offline   Reply With Quote
Old 07-02-2001, 03:14 PM   #2
Poseidon
Member#: 4864
2004 WRX
A mod can't really void your warranty, unless it actually causes the problem you are trying to have fixed. If you make major modifications to the inner workings of the engine (like adding a turbo, increasing the stroke or bore, changing the heads, etc), however, all bets are off. That said, an intake is a good mod. Most people (including myself) will recommend the GanzFlow cold air intake at www.imprezars.com. I have one on my '02 RS. Better tires are a good idea. Replace the rear sway bar with a larger diameter bar, 18 or 20mm. I bought mine (20mm) from a WRX owner that upgraded, but you can use one that was made for an older RS. Exhaust is always a good idea. I'm pretty sure that any exhaust made for older RS's will fit, but I haven't gotten there yet. I don't know what the story is yet on strut tower braces. Some people have been developing them for the WRX, and those should fit the new RS as well.
Jordan
Poseidon is offline   Reply With Quote
Old 07-02-2001, 03:18 PM   #3
Hyudra
Member#: 7559
2002 Impreza 2.5RS
How much faster will I feel with these mods?
Will I ever be able to feel like I'm in a jet or roller coaster, like you sorta feel in a WRX?
Old 07-02-2001, 03:25 PM   #4
Poseidon
Member#: 4864
2004 WRX
None of this will turn your car into a "jet." Realistically, I think you can probably expect somewhere around a 10-15 peak horsepower increase with a new intake and exhaust. To make a really significant increase in power, you have to muck with the engine, and as I mentioned, you are then treading on dangerous ground in terms of your warranty.
Oh, I thought of one more. You could put in a short-throw shifter. That will reduce your shift times and might help your acceleration somewhat.
Jordan
Old 07-02-2001, 03:42 PM   #5
go go go
Member#: 2784
take off the intake silencer in the fender, it makes little difference and it's FREE
go go go is offline   Reply With Quote
Old 07-02-2001, 03:44 PM   #6
Clegg
Member#: 7761
2008 VW R32 #3858
****, I rode in a WRX, drove a WRX, and personally the 2.5RS has a much more "jet like" take off. the WRX has some nice lag when you hammer it, the 2.5RS has a ton of torque right there and right away. the WRX does accelerate quite nicely once you get it past midway in 2nd gear.
In all honesty the 2.5RS is more of a jet then most people give it credit. also how long have you had yours? give it 2000 miles to come to life, mine tool around 2000 or 2500 to start to loosen up and start to rock.
Clegg is offline   Reply With Quote
Old 07-02-2001, 03:47 PM   #7
Hyudra
Member#: 7559
2002 Impreza 2.5RS
Oh 2000 miles huh, alrighty , I'll be waiting, I'm already at 800 in 2weeks !!! WTH! Or was it 3, but whatever.
I can feel a bit when I punch it, but it's not really like the WRX, and yea the lag I can feel in the WRX. My friends 2nd gen integra feels so fast for some reason.
Old 07-02-2001, 03:58 PM   #8
Dirt Man
Member#: 176
2011 Subaru Forester
If you want to make the biggest improvement to your new RS, *****-can the crappy RE-92's and get some better tires! The Kumho Ecsta 712's, The Bridgestone RE-730, Pirelli P7000's, any of these tires and many more will vastly improve the handling of your RS and increase the "Fun Factor"!
Dirt Man is offline   Reply With Quote
Old 07-02-2001, 04:03 PM   #9
b_tapper
Member#: 5291
'08 Scion xB
Nautical Blue Metallic
the 20mm rear sway bar made a huge improvement
Brian
b_tapper is offline   Reply With Quote
Old 07-02-2001, 04:25 PM   #10
ylexot
Member#: 6878
2002 MBP 2.5RS
1994 GMC Sonoma
I also have a 02 2.5RS (Midnight Black Pearl) and here's what I'm doing (in chronological order):
Cobb Intake (Ganz is more bang for the buck, but Cobb has more bang)
Whiteline adjustable sway bar, end links, and brackets
Short Shifter
Morrette headlights
Cat-back exhaust (not sure which)
Headers
STi replica wing
Tires when I need them (no point in throwing away good tires IMO)
Be careful with the sway bar. The ones from the older RS will fit, but I have been told that the new ones give more clearance for the exhaust and are better if you are going to upgrade the exhaust.
Micah
ylexot is offline   Reply With Quote
Old 07-02-2001, 06:00 PM   #11
Silver2000RS
Member#: 857
Lightbulb
Protect your sheet metal with a set of Hella air horns or Supertones. The stock horn is too whimpy. I'm getting a a set of Supertones soon. A cheap but effective mod.
Silver2000RS is offline   Reply With Quote
Old 07-02-2001, 06:36 PM   #12
Clegg
Member#: 7761
2008 VW R32 #3858
Yes a BIG horn for the bastards in the world is a MUST
also it will make the security system more fun
Also the STi wing is not what I would consider a performance option.. since all it does at the speeds these cars go ( 120Mph is top for most people) is create more drag, get the factory stock wing and it will be less drag while keeping the sporty look of the car.
Old 07-03-2001, 12:41 AM   #13
Hyudra
Member#: 7559
2002 Impreza 2.5RS
BTW how much does a aftermarket rear sway bar cost.
What's the difference between 18mm and 20mm?
And how much does the offical/real WRX rear sway bar go for?
Old 07-03-2001, 04:02 AM   #14
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
1970 Subaru FF-1 Coupe
The offical "rear" sway bar the WRX has is $80 at www.subaruparts.com
Check out www.cobbtuning.com for some more parts, as well as www.autocaresubaru.com and check the WRX/New Impreza sections.
Heres my list of mods ive collected for the 02 RS that I want to get if I get my 02 RS (im sure some can be found with better prices though):
20mm OEM Rear sway bar ($80)
STi Front sway bar w/ bushings ($110, part of the optional STi kit)
Anti-lift Kit ($159)
Rear Strut Bar ($155; V-brace attachment is $150)
STi Springs ($415) or Whiteline Springs ($279) or Optional STi Strut/Spring kit ($1000)
Stromung Muffler catback exhaust ($355)
Stromung intermediate-pipe ($125)
Borla headers ($550... Probably cheaper)
Cobb Intake ($269) or K+N intake filter ($40)
Old 07-03-2001, 01:24 PM   #15
Hyudra
Member#: 7559
2002 Impreza 2.5RS
Alright I'm probably going to go w/ the OEM WRX rear sway bar, can someone give me the product # on it?
Also I'm thinking of going w/ the cobb intake as well, and how much better is the cobb intake than the GanzFlow?
Also wheels which will be 1 of my first 3 changes, so help me out here.
Old 07-03-2001, 03:51 PM   #16
Hyudra
Member#: 7559
2002 Impreza 2.5RS
Oh yea, also do better pullys help?...
Old 07-03-2001, 03:59 PM   #17
b_tapper
Member#: 5291
'08 Scion xB
Just don't expect giant horsepower/torque gains from them. That's why I am going the suspension route first. I like handling over straightline speed anyways. I just can't believe how much faster I can drive my RS through the twisties compared to my old jetta.
Brian
Old 07-04-2001, 03:47 AM   #18
Kostamojen
Member#: 2272
95 L AWD LIFTED!!!
Heres the link to the WRX rear sway bar (3rd one down, the 20mm one): https://ssl.autocenter.net/webparts/...ience_625.html
And lighter pullies will help alot in some areas, less in others... probably better to spend that money on an exhaust or rims/tires first...
And the Cobb is probably the best intake you can find for the Impreza, and is worth every penny (Some intakes actually decrease low end torque, the cobb intake prevents that from happening)
Old 07-04-2001, 04:20 AM   #19
2Point5RS
Member#: 3639
what good does great aftermarket power give you if your handling is stock...
sure, drag strip and straight lines...but in the real world, you have to turn sometime. or is that what the awd is for... :P
Matt
NSG Racing
2Point5RS is offline   Reply With Quote
2002 Impreza 2.5rs... modded, $9,000!!! Stover954rr Private Vehicle 'For Sale' Classifieds 25 11-12-2006 10:17 AM
2002 Impreza 2.5RS - For Sale - Milwaukee scoobynewbie Private Vehicle 'For Sale' Classifieds 0 07-30-2004 07:04 PM
2002 Impreza 2.5RS for sale (w/pics & links) balajc Tri-State Area Forum 1 07-23-2003 03:38 PM
Measurements for 2002 Impreza 2.5RS ASAP! fukamoto Interior & Exterior Modification 2 07-11-2002 12:46 AM
quick! need wheel off-set and lug config for a 2000 impreza 2.5rs wnut Bay Area Impreza Club Forum -- BAIC 3 05-14-2001 11:42 AM
Message Board Statistics All times are GMT -4. The time now is 03:35 PM.
