Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 12-04-2004, 10:18 PM   #1
mistaboosta
Member#: 68722
Default AEM EMS AND HYDRA Users check this thread..
I am planning to sell my UTEC and go with a standalone ECU like AEM EMS or Hydra.
They both have auto tune features but i'm not sure if it really works.
Can someone explain a few things about this auto tune ???
BTW which standalone do you recommend?
mistaboosta is offline   Reply With Quote
Old 12-04-2004, 11:05 PM   #2
Hitokiri
Member#: 2604
1999 2.5RSt
RBP
they are both very similar in that they both work primarily off of large PWM for fueling, both have extensive sontrol maps down even to individual cylinder fuel corrections.
I am not as familiar with AEM but it has much better tuning software. It is much much easier to tune just by its ability to organize and look at logged data. AEM also adds individual cyl. timing correction. I am sure there are more differences, but they are very similar in their approach to control.
Todd
Hitokiri is offline   Reply With Quote
Old 12-06-2004, 02:54 PM   #3
bboy
Member#: 56468
04 Improved STI
Dirty White
I agree with Hitokori, functionally very similar, software makes the difference.
Now more importantly, how much "set up" and basic tuning are you willing to do. There are AEM users on the Board. The Element Hydra has been worked on, calibrated, and tuned by Phil Grabow, such that he basically hands you a functioning standalone for the WRX or STi on par with a EcuTek re-flash. That is worth the price of about three ECU's to me, and all for the price of one.
For the ultimate in features and software, go Motec. You are on your own for getting it to run your car. Very few folks are willing to plunk down that $green$, so there is very little expertise outside of a handful of custom racing shops. If I were wealthy and retired, I'd give it a shot just for the challenge (but I'd drive around with an Element Hydra while I worked on the Motec).
Old 12-06-2004, 03:35 PM   #4
Scooby-Doode
Member#: 28976
2007 Twin Turbo
Spoolin'
Correct me if I am wrong, I thought that the Hydra doesn't support DBW (drive by wire). When this EM first came out it caught my eye, I haven't really read up on it since (maybe I should ).
Old 12-06-2004, 07:34 PM   #5
0db
Member#: 33879
2003 WRX Sporkwagon
I have the AEM system; ran it on my previous car (turbo Integra GSR) and am just getting it worked into my WRX. It's a VERY powerful system, and I think the software IS superior to the Hydra's.
That said... the fact that the hydra ships with a REAL base map is worth A LOT. AEM's base maps on the WRX are BAD. The MAF-based map is unusable. The MAP-based map runs relatively smooth, but needs serious tweaking before you even THINK of trying to put your foot to the floor. Oh, and the way it's setup on the BASE map, the wastegate solenoid is set to 100% duty cycle ALL THE TIME. That's right, it'll boost up to 19 psi on the base map if you floor it!
GREAT system
GREAT software
POOR base maps
If you understand that you MUST tune it immediately before driving, it's a great package. From what I'm hearing about the hydra, it's a totally different experience.
0db is offline   Reply With Quote
Old 12-08-2004, 01:47 AM   #6
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
The auto tune on most EMS is for fuel only. You plug in what you want your AFR to be at X-rpm and Y-boost and it will hit it. Go through the whole table plugging in your desired AFR, hook up your wideband, put in conservitive timing and take it for a spin. The auto tune takes care of the rest of your fuel tuning. Boost and timing still have to be taken care of.
eastcoastbumps is offline   Reply With Quote
Built motor not starting bad crank/cam signal with AEM EMS and kelford 272s? lester Engine Management & Tuning 10 08-19-2013 12:26 PM
Accessports, utecs, aem ems and all sorts of goodies inside! IMPORTIMAGE Engine Management 435 08-25-2011 07:04 PM
Clean 02 IS300, getrag 6 speed, GTE internals, AEM EMS and more!!! 9sec95autoTT Private Vehicle 'For Sale' Classifieds 10 06-16-2009 10:39 PM
Zex/Nitrous users check this out! AndyM Normally Aspirated Powertrain 6 11-26-2002 06:20 PM
Nice Find (ICQ users check this out) Impeza Rider General Forum Archive 0 08-28-2000 07:07 PM
