Old 12-05-2004, 07:56 AM   #1
mikaust
Member#: 7468
2008 Outback Limited
Default speedo gear problem
I have broken two speedo gears in less than 500 miles and I am quite tired of pulling the trans. The first gear was a factory nylon type, the second was the steel RA type ( $170 ouch!) from Rallispec. They both lasted about 300 miles. When this happens my car goes into limp mode,radiator fans run all the time and can't rev past 4500 until I pass into the UTEC. I also put the kmph to mph conversion in so I will check that connection. Can anyone offer any insight?
mikaust is offline   Reply With Quote
Old 12-05-2004, 09:54 AM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Does the trans have lube in it? If it is low, you will burn up gears as well as the trans.
Maybe you need to pull the trans and split the cases to see what is going on.
Old 12-05-2004, 06:43 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
to put the speedo gear in he had to split the case. Have you checked to see how the gear meshes with the shaft. They may be too tightly meshing together and causing premature failure.
Legacy777 is offline   Reply With Quote
05' LGT trans swap - Speedo Gear Problem morrocco88 Transmission (AT/MT) & Driveline 45 02-13-2013 12:01 PM
STI RA Gearsets - $1349 with OEM quality Speedo Gear Gruppe-S Drivetrain 34 01-08-2005 09:48 AM
RA speedo gear O Stylee Transmission (AT/MT) & Driveline 6 07-25-2004 09:46 PM
Speedo quit, CEL: bad speed sensor or speedo gear? superg Transmission (AT/MT) & Driveline 4 06-20-2004 03:49 PM
Broken Speedo gear boysetsfire Transmission (AT/MT) & Driveline 0 04-12-2003 02:50 PM
