Old 12-05-2004, 12:48 PM   #1
scott93subarulegacy
Member#: 76669
1993 Legacy Turbo
Black, with red flakes
Default Saab 900 ic
I have a saab ic that i want to install on my subaru. Could i put an after market bov on it and if i do what would i do with the tube that connects to the box right before the air filter that goes to the stock bov.
scott93subarulegacy is offline   Reply With Quote
Old 12-06-2004, 02:13 AM   #2
ncarn8
Member#: 71419
the old hose before the air filter? or after the afm? if its after the afm
block the old hose unless you want to plumb the new bov back.
ncarn8 is offline   Reply With Quote
Old 12-06-2004, 11:04 AM   #3
BrysImpreza
Member#: 3102
2012 Sport Limited
Ice Silver
I used a Mazda RX-7 Stock one when I used my Saab 900 IC, it's an in-line bypass valve made by Denso.
Another option since the lines going to the IC are plastic, take a short, straight section of piping from the turbo to IC inlet and make a bracket for any BOV that will fit in place.
I'll dig up a pic of the BOV I used this afternoon.
BrysImpreza is offline   Reply With Quote
Old 12-06-2004, 05:14 PM   #4
scott93subarulegacy
Member#: 76669
1993 Legacy Turbo
ok thanks.
Old 12-08-2004, 01:09 PM   #5
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
I used a blowoff valve from a 1st-generation DSM, with the pipe that it fits on. That pipe has a neat little bend at the end that works very well for the stock Legacy Turbo setup. An upper radiator hose from a 92 Civic fits pretty well between the BOV's outlet and the stock return bung; it just fits on the outside instead of the inside of the return bung:
http://www.graphics.cornell.edu/~v/p...aru_legacy.jpg
vrg3 is offline   Reply With Quote
Old 12-08-2004, 10:20 PM   #6
scott93subarulegacy
Member#: 76669
1993 Legacy Turbo
does that bov end up hitting the hood?
Old 12-08-2004, 10:29 PM   #7
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
It's pretty close, but it doesn't touch the hood. Actually, it sits directly under the hood scoop. You can see it through the scoop when the hood is closed.
The stock manifold pressure line reaches it neatly too.
Old 12-08-2004, 10:34 PM   #8
scott93subarulegacy
Member#: 76669
1993 Legacy Turbo
Thanks how much pressure can you run with the intercooler?
Old 12-08-2004, 10:57 PM   #9
scott93subarulegacy
Member#: 76669
1993 Legacy Turbo
also what size is the connecting tubes that go from the intercooler to the pipe?
Old 12-08-2004, 11:08 PM   #10
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
What I've got in that picture is a near-perfect fit. The compressor connects to the pipe with a short piece of 1-3/4" radiator hose. The pipe connects to the intercooler with a 1-3/4"-to-2-1/4" coupler. The intercooler connects to the throttle body with a 2-3/8"-to-2-3/4" coupler.
Those sizes match almost perfectly, but you can get away with using simpler/cheaper stuff if you keep an eye on it and keep spares handy. For a while I was using a cheap AutoZone 2-1/2"-to-3"coupler to connect to the throttle body and a 2" pipe sewer drain coupler from the hardware store to connect the pipe to the intercooler; they both required the clamps to be cinched down pretty tight, but they worked. The sewer coupler isn't rated for pressure, heat, or oil, though, so it gave up after a couple thousand miles and maybe a dozen runs down the drag strip. I wish I'd kept a spare handy that race day.
OT Saab experts: '97 Saab 900 F & R brake job instructions Janq Off-Topic 20 10-02-2005 01:38 AM
For Sale: Saab 900 Intercooler and NGK Plugs imprezey Bay Area Impreza Club Forum -- BAIC 2 12-21-2002 10:43 PM
FS: 98 Saab 900 SE conv. I am b Southern California Impreza Club Forum -- SCIC 0 10-01-2002 12:54 PM
Saab 900 IC and STi Strut Brace fitment STi-Nismo Dood Normally Aspirated with bolt-on Forced Induction Powertrain 3 04-28-2002 02:56 PM
I got a turbo off SAAB 900. eicbal18 Factory 2.0L Turbo Powertrain 3 05-13-2001 01:18 PM
Message Board Statistics All times are GMT -4. The time now is 04:59 AM.
