Old 12-05-2004, 01:00 PM   #1
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
Default 18g oil line question. small emergency.
how do you route the oil line going into the top of the turbo? under the bracket, over the bracket, through the bracket? i'm worried that if i bend it too many more times that it may just kink.
kharris4 is offline   Reply With Quote
Old 12-05-2004, 01:26 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
You should not have to move the oil feed line that far at all, just enough to remove/reinstall the turbo. Do not try and bend it more than 10 to 15* at any point or it will kink.
cdvma is offline   Reply With Quote
Old 12-05-2004, 01:41 PM   #3
kharris4
Member#: 46018
2003 wrx
the fp18g has a big bracket holding the actuator on and it sorta makes it so that you have to decide whether you have to go under it , over it or maybe even through it.
Old 02-18-2005, 10:19 PM   #4
Lowball
Member#: 24198
02 WRX Sport Wag
Black to reality.
I'm sure you figured it out by now but just incase...I routed mine under and then back around to the top. The 1st time I rested the line on the uppipe and it burned a hole in the inner liner and got a leak while I was on the track. So, had to order another line and then routed it the same but tied it off to the tranny dip stick tube so it wouldn't hit the uppipe. All is good now...$70 bucks for a new line kinda sucked though...
Lowball is offline   Reply With Quote
UP/DP and oil line questions [email protected] Normally Aspirated with bolt-on Forced Induction Powertrain 22 11-15-2007 05:15 PM
Turbo oil line question ninjaboy76 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-04-2006 03:41 AM
turbo oil line question SQC120 General Community 2 04-21-2005 07:43 PM
ludespeed oil line question garretwp Normally Aspirated with bolt-on Forced Induction Powertrain 6 01-22-2004 05:17 PM
yet another oil line question.... kid22 Technical Forum Archive 1 07-16-2000 08:51 PM
