Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Drivetrain
Closed Thread
Old 12-05-2004, 11:24 PM   #1
Gruppe-S
Vendor Sales Rating: (65)
Member#: 23216
2006 949-457-1234
949-457-1234
Default Sti V6 Ra Gearsets And Components Back In Stock!!!
Hey guys,
Finally received another big shipment of STI RA Gearsets and components. Here's what we have:
*STI V6 RA Gearsets Complete
-Thicker and stronger than stock gears
-Cryo treated for additional strength
-OEM material speedo gear - custom designed
-Includes gears 1-5, mainshaft, shift rod, all necessary washers, etc.
-Recommend for 275whp-350whp cars
$1349 Shipped!!
*Genuine Subaru 4pc Bearing Set (Recommended) $255 Shipped!!
*Basic Transmission Rebuild Package - with STI V6 RA Gearsets
-Basic transmission rebuild
-Includes V6 RA Gearsets
-1 month limited warranty
-Includes installation
-Does not include replacement for damaged or worn components (broken shifterforks, synchros, etc.)
$2450 INSTALLED OTD!!
*Full Transmission Rebuild Package - with STI V6 RA Gearsets
-Full Transmission Rebuild
-Includes V6 RA Gearsets, new synchros, new bearings
-Ready to go transmission, essentially good as new
$2599 SHIPPED, 48 STATES!!
Please contact us with any questions or ordering. Cryo treatment delay will be 1 week. Thanks,
ORDER HERE!!!!!!!!!!!!
Gary
www.gruppe-s.com
[email protected]
510-783-5300
510-783-4300 fax
Gruppe-S is offline
Old 12-05-2004, 11:25 PM   #2
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Gear Ratios:
First Gear 3.083
Second Gear 2.062
Third Gear 1.545
Fourth Gear 1.151
Fifth Gear 0.825
Gruppe-S is offline
Old 12-06-2004, 08:58 PM   #3
Silver '02 REX
Member Sales Rating: (14)
Member#: 27963
2013 Focus ST2
PB
Any Non RA sets?
Silver '02 REX is offline
Old 12-06-2004, 09:10 PM   #4
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Originally Posted by Silver '02 REX
Any Non RA sets?
Sorry, we don't offer that at the moment.
Thanks,
Preston
Gruppe-S is offline
Old 12-06-2004, 10:05 PM   #5
theicewall
Member Sales Rating: (3)
Member#: 70532
2004 WRX
Why only a one month warranty? That doesnt instill much confidence in your work.
Its a genuine subaru part and should be warrantied as such along with your work if something is done incorrectly. The only thing that shouldn't be covered is abuse such as someone misshifting and causing synchro problems, or dropping a clutch 10 times and blowing up 1st gear. Other than that, any other probelm that I can think of would be the part's fault or the installer's fault, and if it takes a month and a day for the problem to be exposed I'm out of luck after spending over $2,000 of my hard money. I dont know about that.
theicewall is offline
Old 12-06-2004, 10:57 PM   #6
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Default hi
Hi,
I definately understand your concerns about the warranty. The 1 month period warranty I believe is pretty much industry standard, especially with aftermarket builds, and is offered to us by the rebuilders (who have a tranny dyno). Generally speaking, if a transmission is built incorrectly, the user will notice within the first few hours of driving, whereas if a transmission is abused or placed in a high-power applications, failure will occur overtime. This is the same reason why many race engines only offer a start-up warranty. You can take as an extreme example several of the high horsepower Subaru's being drag-raced and making in excess of 500 ft/lbs torque. These cars often destroy a transmission every few runs.
Since the majority of our customers are using our transmissions in high powered applications, we feel that a 1 month warranty is both fair and reasonable. In regards to factory Subaru components, even the factory V6 STI's are not making in excess of 210whp, whereas many of our customers are in fact making much more.
That being said, we do have absolute confidence in our transmission rebuilds. If there is a question of rebuild error or improper rebuild, we will 100% warranty the transmission. However in our experience we often find transmissions are often being damaged due to reasons other than improper rebuilds.
Thanks,
Gary
Gruppe-S
Gruppe-S is offline
Old 12-07-2004, 10:22 AM   #7
rare_impression
Member Sales Rating: (1)
Member#: 50138
2004 Wrx
Final drive ratio?
rare_impression is offline
Old 12-07-2004, 06:35 PM   #8
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
We also have some Exedy Hyper Single Clutch/Flywheel Kit - 02+ WRX for $960.00 shipped !
Exedy Hyper Single Clutch Kit
5-speed
Clutch Type: Pull
Clamp Load: 2655lbs
Disc OD: 225mm
Give us a call to order as this price is not on our website.
Thanks
Preston
Gruppe-S is offline
Old 12-08-2004, 04:32 AM   #9
tribalwrx
Member Sales Rating: (4)
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
what could you guys do on a set of gears and bearings as well as a exedy organic clutch shipped to 99515, now heres my dumb ? of the day due you have to replace the bearing? and what about replaceing the syncros cause i believe my 4th gear syncro is on its last legs.
thanks for the help guys
mike
tribalwrx is offline
Old 12-08-2004, 02:24 PM   #10
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Hi Mike,
For the bearings, we generally recommend them being replaced for higher mileage transmissions (20K+) as often the bearing fatigue will cause the shaft play that contributes to broken gears. That being said many of our customers dont' replace the bearings due to cost and many of these transmissions turn out fine. We always recommend replacing synchros.
Thanks,
Gary
Gruppe-S
Gruppe-S is offline
Old 12-08-2004, 03:52 PM   #11
tribalwrx
Member#: 32993
vf39 Best trap 110
from your web site you carry the syncros , so lets say i for go the bearings and get the syncros in stead, what kind of package cost woould i be looking at and i may have to get the bearings anyway my tranny has 34k on it and not all of them were easy miles, but its still holding strong so far all but that 4th gear syncro. thanks for the intel.
mike
Old 12-08-2004, 05:34 PM   #12
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
mike
Mike,
So, you would like the synchros instead of the bearings? The package deal would be the same price.
Thanks
Preston
Gruppe-S is offline
Old 12-09-2004, 06:27 PM   #13
SilverWorxs
Member#: 57388
Gary Could you make package price For the gear set, syncros, and bushings. shipped to me at 53090. Thanks.
SilverWorxs is offline
Old 12-09-2004, 06:34 PM   #14
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
PM sent
Thanks
Preston
Gruppe-S is offline
Old 12-11-2004, 01:00 AM   #15
tribalwrx
Member#: 32993
vf39 Best trap 110
just a bit over 2k or so with the shipping cost
mike
Old 12-17-2004, 01:33 PM   #16
obrut
Member Sales Rating: (19)
Member#: 47872
04 STI JBP
HTA3586 5XX WHP 93oct
Still have gears instock?
obrut is offline
Old 12-17-2004, 02:17 PM   #17
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Yes, give us a call to order.
Thanks,
Preston
Gruppe-S
Phone: (510) 783-5300
Gruppe-S is offline
Old 12-19-2004, 09:10 PM   #18
obrut
Member#: 47872
04 STI JBP
ordered it online today.
obrut is offline
Old 12-21-2004, 03:39 PM   #19
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Thanks. Enjoy it once it's installed
Regards
Preston
Gruppe-S is offline
Old 12-22-2004, 01:40 PM   #20
mpaone
Member Sales Rating: (30)
Member#: 3
2012 Geeteeeye
and 71' VW Gulf Beetle
Question
I'm not clear on what is included on the 3rd option... is that essentially a full 5 spd tranny shipped in the lower 48?
-Mike.
mpaone is offline
Old 12-22-2004, 02:04 PM   #21
marios03wrx
Member Sales Rating: (17)
Member#: 33593
2002 WrX-ShAgNwAgOn
No motor No Trans :-(
i was wondering what kind of aggreement you all could have with a guy in hawaii on either me try to find another trans and then shipping it to you guys so i can have the RA set installed + seals or charge me extra then refund so that i don't try to keep an extra trans. Also what do you think shipping to 96860 would be like?
marios03wrx is offline
Old 12-22-2004, 02:04 PM   #22
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
-Mike.
Yes, it is a full 5 spd tranny that we can ship to the lower 48 states.
Thanks
Preston
Gruppe-S is offline
Old 12-22-2004, 02:14 PM   #23
mpaone
Member#: 3
2012 Geeteeeye
Thumbs up
Thanks
Preston
WOW, I wish I had the cash right now... you'll definitely get a call from me early in the new year.
OH, one more Q: What else will I need to install in my car? I currently have a MY04 WRX engine and a MY00 RS transmission. Final drive is currently 4.11
I'm guessing a different clutch (pull vs. pull) but what else?
I'll probably have you put together an entire package for me... come on, taxes!
Thanks!
-Mike.
mpaone is offline
Old 12-22-2004, 02:37 PM   #24
Gruppe-S
Member#: 23216
2006 949-457-1234
949-457-1234
Shipping would be roughly $700-750.
Thanks
Preston
Gruppe-S
Gruppe-S is offline
Old 12-22-2004, 02:50 PM   #25
marios03wrx
Member#: 33593
2002 WrX-ShAgNwAgOn
So would 700-750 account for a trans round trip or one way?
Closed Thread
Question regarding STi V6 RA gearset/synchros forced4 Transmission (AT/MT) & Driveline 1 11-11-2009 03:20 AM
07 SPEC-C 6SPD/STI V6 RA Gearsets/ACT STI 6-pk Clutch Kits $679/Cusco LSDs/Tranny Mnt Gruppe-S Drivetrain 30 02-23-2007 08:22 PM
STI V6 RA Gearsets ARE BACK/ACT STI 6-puc Clutch Kits $679/Cusco LSDs/Tranny Mnts Gruppe-S Drivetrain 15 01-29-2007 03:19 PM
STi V6 RA Gearsets, Cusco Motor Mounts, ACT and Exedy Clutches and Flywheels Z1 Performance Drivetrain 13 10-10-2005 06:15 PM
STi V6 Ra Gearsets And Components Back In Stock!!! Gruppe-S Drivetrain 1 03-10-2005 04:35 PM
