Old 12-06-2004, 03:04 AM   #1
calib17a
Member#: 64150
Default STI Utec Stage II map, check out my data log
Is this dangerous? Should I lower the boost on the boost map on stage II?
Only mod on Stage II map was -3 throughout ignition map due to previous knock events on unmodified STIstageIIolf , running 91 octane here in cali .
As you can see UTEC shows no knock but I think anything over 18 psi is kind of high. See how it spikes to 24 psi.
I'm running Invidia catless dp, Blitz Nur spec touring, Apexi short intake, Turbo XS fmic with HKS ssbov, Walbro 255lph fuel pump, and stock injectors.
3542 025 -11.0 10 +18.0 00000
3930 029 -8.9 10 +18.0 00000
4016 046 -5.9 10 +18.0 00000
4145 059 -1.4 20 +17.3 00000
4374 072 +3.9 50 +17.2 00000
4585 075 +9.0 80 +15.9 00000
4810 076 +13.5 90 +16.6 00000
5144 076 +16.4 100 +16.7 00000
5291 076 +17.8 100 +17.4 00000
5446 076 +17.4 90 +19.0 00000
5717 076 +17.0 90 +19.3 00000
5868 075 +15.9 80 +19.6 00000
6138 076 +15.5 80 +19.9 00000
6161 077 +15.1 80 +21.2 00000
6349 078 +14.5 80 +22.2 00000
6459 078 +14.3 70 +23.0 00000
6706 077 +14.1 80 +23.3 00000
6816 077 +13.5 70 +24.2 00000
6958 077 +13.7 70 +24.2 00000
calib17a is offline   Reply With Quote
Old 12-06-2004, 06:43 AM   #2
happasaiyan
Member#: 37731
1) wrong forum
2) post #1 loggers
3) RTFM
4) youre looking at the wrong column. your ign timing is ramping up to 24. your highest boost is [email protected] rpms.
happasaiyan is online now   Reply With Quote
Old 12-06-2004, 09:07 AM   #3
SGOSWRX
Member#: 10921
04 04 STi
12.8 @ 105 mph
Originally Posted by happasaiyan
1) wrong forum
2) post #1 loggers
3) RTFM
Diddo, looks very similar to my Stage 2 Map in cooler weather. I'm making about 17.2- 17.8 max boost
SGOSWRX is offline   Reply With Quote
Old 12-06-2004, 09:49 AM   #4
1/500yellowwrx
Member#: 53573
2005 STi Silver
Silver and fun
I just worked on tunning my utec. I can safely run 20psi. My afr were only 9.8-10.4. I was running a mixture of half 93 and half 100. I had zero knocks. My only mods are utec, txs tbe(no cats)and perrin shrt ram. I do alot of data logging to make sure it is not knocking. If you can find some way of getting a higher octane it would be much more safe.
1/500yellowwrx is offline   Reply With Quote
Old 12-06-2004, 08:37 PM   #5
calib17a
Member#: 64150
Default re:
Thanks for correcting me. Sorry, still new to this. Is 17.8 psi still high or is it safe for stock internals? Just modified for safer tune for 91 oct here in cali, as directed by Turbo XS tech support. Otherwise how does this data log look? I really don't plan on tuning myself, not until I get a wideband meter and understand all the perameters.
Knock on stock map? Check out my logs! strictlyJDM Open Source Reflashes 18 03-07-2009 02:13 PM
check out my 1st log! yes, there's a problem 95gstnj AccessPort 1 01-18-2009 01:36 PM
Someone check out my data logs.. midnight302 Engine Management & Tuning 4 03-03-2007 04:11 PM
anyone have a tuned UTEC stage II map? palmerx141 Rocky Mountains Impreza Club Forum -- RMIC 0 09-11-2005 02:58 AM
UTEC stage II map installed drdeuce Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 06-11-2004 09:52 AM
