Southern California Impreza Club
Go Back   NASIOC > NASIOC Chapters > Southern California Impreza Club Forum -- SCIC
Old 12-06-2004, 03:05 PM   #1
aspenwhitewrx
Member#: 24965
2002 Impreza WRX
Default Advice needed re:Black Soot and fluids
Hi All,
I'm concerned about a layer of black soot with a green fringe on the firewall inside my engine bay(behind dp and tmic). I don't know if it is from an exhaust leak, but do any of you have this? It looks a little too dark to be dirt. I don't have a turboback exhaust leak, but it might be my up-pipe to turbo junction(up-pipe leak)?
Also, I'm getting my 30K service done soon and was wondering what the best tranny and rear diff fluid is to put in my car. Thanks all.
Scott
aspenwhitewrx is offline   Reply With Quote
Old 12-06-2004, 03:53 PM   #2
phattyduck
Member#: 32955
'03 WRX Wagon
'89 3S-GTE Alltrac Camry
The 'soot' is dirt that has been caught by the greasy stuff that Subaru puts on the firewall from the factory. Its pretty nasty, but you can clean it off there if you want. If you had an uppipe leak bad enough to get stuff on the firewall, you'd hear it every time you drove.
Easiest choice for fluids is stock... otherwise, start reading up - there are lots of opinions out there.
-Charlie
phattyduck is offline   Reply With Quote
Old 12-06-2004, 03:54 PM   #3
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Sounds like a leaky uppipe gasket. Use the Subaru part, it seals great.
For the trans and diff fluid, I'd suggest using what the dealer uses while you're in the warranty period (to avoid warranty claims being denied down the line should the tranny go south).
W3rp!
-Milan
US2JDM is offline   Reply With Quote
Old 12-06-2004, 04:39 PM   #4
Psydotek
Member#: 44168
2003 Yellow WRX
with too many lights...
-Charlie
Hmmm, so that's what all that junk is... So it's totally harmless then, just really bad looking. 2 years, haven't cleaned that crap off once...
I'll get to it one day.
advice for changing automatic transmission fluid and differential fluid coldfire7 Service & Maintenance 26 09-08-2010 08:56 PM
Gun range advice needed for la and kern county hybrid gti 2 Southern California Impreza Club Forum -- SCIC 22 11-12-2008 01:23 AM
OT: Advice needed re: CFL and contest prize Picard Vancouver Impreza Club Forum -- VIC 15 02-27-2008 09:27 PM
Need advice on brake pads and fluid CletusTheDwarf Brakes, Steering & Suspension 8 05-15-2007 04:40 PM
good way to remove exhuast soot and discolor? BlowDro Interior & Exterior Modification 9 09-10-2006 08:54 PM
Message Board Statistics All times are GMT -4. The time now is 08:05 AM.
