Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 12-07-2004, 08:58 AM   #1
EA82TRally
Member#: 73270
2002 WRX Wagon
Midnight Black Pearl
Default Higher Flow Side Feed Injectors
This might be a kinda stupid idea, but I was searching the internet for fuel injectors and happened to notice something. I took a look at some fuel injectors for an SR20DET(side flow injectors) which flow somewhere in the ballpark of 370cc's. I was just wondering if these could be a possible alternative to the tiny fuel injectors that EA82T's come with, and to also see everyone else's input on the whole idea. It seems like they would work because the mounting is, or looks the same. And hypothetically speaking, I figure as long as I use the factory(240SX) fuel injector plugs, and they are the same impedance, everything should work. But since I don't think that I'll be getting ahold of any SR20DET injectors any time soon, I figured that 240SX injectors might do the trick. Right now, I can easily get ahold of some stock 240SX(side feed design[red] KA24DE) injectors from a friend of mine since they are just laying around in his garage. They look nothing like what is in the picture on this site:CLICKY They look almost identical to the SR20DET injectors on the aforementioned site, except for the fact that they are red instead of blue. I am seriously thinking of getting these injectors and seeing if they will work. What do you guys think?
Thank you for your input.
Patrick
EA82TRally is offline   Reply With Quote
Old 12-12-2004, 12:57 AM   #2
-k-
Member#: 43881
01 25RS
How do you plan to tune for the extra fuel? I don't think they will work, I have heard they can be used on the Legacy turbo with a spacer under them. If that is true they won't work for you.
-k- is offline   Reply With Quote
Old 12-12-2004, 01:34 AM   #3
Invisiguard
Member#: 43201
04 STi
07 Corvette
FWIW the nissan/NISMO injectors are a direct swap for the new STI side feeds, so if the STIs fit in yours so will the Nissan/NISMOs, good luck!
Invisiguard is offline   Reply With Quote
Old 12-12-2004, 06:38 PM   #4
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Hrrmmm
I think I have a set of Nissan injectors in my garage as well as a set of EA81-T (or EA82-T) injectors. Are the EA81-T and EA82-T injectors the same?
I'll try to line them up together tomorrow or Tuesday if I get a chance and take some pics. Should be interesting.
Kevin Thomas is offline   Reply With Quote
Old 12-13-2004, 07:17 AM   #5
Kevin Thomas
Member#: 110
1989 1989 XT6
Just got home from work. The pic isn't the best but it's all I can do for now *sleepy*. The pic is of two 1.8ltr RX turbo injectors vs Nissan SR20DET injectos. I purchased these injectors for my Outback Sport when it was turbocharged but I never had them installed. The 1.8ltr RX turbo injectors were for a turbo Subaru XT6 project I was going to do but it never got completed due to $$$ constraints.
The 1st and 3rd injectors are the RX turbo injectors while the 2nd and 4th injectors are from the Nissan.
Old 12-13-2004, 08:52 AM   #6
EA82TRally
Member#: 73270
2002 WRX Wagon
Well, maybe it was just a fleeting thought.
But, on a lighter note, I did find some adapters that MSD makes that will allow different injectors to be used(but require barbed ends to be added to work with factory fuel lines). Check them out:Straight Fuel Delivery Top Mount
**Note: Go to MSD Fuel Management; then go to Flexible hose mounting, and click; then look for part # 2140.**
I'm not quite sure how I would go about tuning higher flow injectors, but I'm pretty sure I can figure that part out when the time comes. I don't think that using injectors that flow 220-270cc's would make that big of a change at idle, considering that the factories flow 180cc's. If I'm incorrect in this theory, please correct me, but keep in mind, when I start this project I will be changing the turbocharger and exhaust system in favor of units with better and higher flow characteristics as well.
Old 12-14-2004, 12:29 AM   #7
ThuotRDX
Member#: 16106
1992 T3/T4 turbo SVX
with a 5 speed
I have been looking at nissan sidefeed 300zx injectors for my SVX project. The turbo legacy injectors should also be 370cc right?
ThuotRDX is offline   Reply With Quote
Old 12-14-2004, 12:54 AM   #8
Invisiguard
Member#: 43201
04 STi
07 Corvette
well yes it should go without saying that you will need some kind of engine managment to scale the injectors with or you will just be running way to rich, if running at all, and probably losing power. Though the cheap trick on this is to get a MAF housing sized to match the the injectors, meaning if the injectors flow 50% more and the MAF housing is exactly 50% larger(in volume not size) than the ECU correction will be at or close to 0
Old 12-14-2004, 07:15 AM   #9
-k-
Member#: 43881
01 25RS
Legacy turbo injectors are 370ish cc
Old 12-14-2004, 10:59 AM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
i was under the impression that pink side feeds were 390cc
browns like i have in my ej20g are 425cc
if any one has 550s ill trade my 425s
Old 12-15-2004, 03:51 AM   #11
-k-
Member#: 43881
01 25RS
I have heard from 360cc to 390cc, I think 370cc is the most often quoted.
Old 12-18-2004, 11:57 AM   #12
Scott F. Williams
Member#: 13930
1999 Impreza 2.5RS
Silverthorn Metallic
Impreza GC8 MAF housing resizing
Wise words, oh Invisiguard. I'll just point out, however, that when you do this the ignition curve becomes overly-advanced due to the ECU "thinking" that the engine is at a lighter load. So, this can be a hazardous mod at worst and simply rough at best.
Scott F. Williams is offline   Reply With Quote
Old 12-18-2004, 01:00 PM   #13
Kevin Thomas
Member#: 110
1989 1989 XT6
Simply running higher octane gas could take care of this situation right?
Old 12-20-2004, 01:39 AM   #14
Invisiguard
Member#: 43201
04 STi
07 Corvette
ah indeed, good point
Old 12-20-2004, 01:48 PM   #15
sick1.8t
Member#: 22345
2003 RSX
black
its pretty common to use the sr20det injectors in the ej18's, since its a direct swap. the s13/s14 injectors are 370cc's, and the s15's are 440cc's.
sick1.8t is offline   Reply With Quote
Old 12-24-2004, 07:05 PM   #16
subiekid
Member#: 25516
1995 Legacy TURBO!!!
EJ22T/TEC3 & '12 Civic
If you are looking at 300zx injectors then you need the 95-96 style, you will also need 92-94 n/a legacy fuel rails. There is a big thread in the AFI forum started by Reddevil.
subiekid is offline   Reply With Quote
Old 12-26-2004, 12:33 PM   #17
THAWA
Member#: 44581
3 Boxers 2 AWD
3 turbo 1 6cyl & a 13BT
To get back on track, those RX injectors look strikingly familiar. To what you ask, to 84-85 300zx injectors: http://cgi.ebay.com/ebaymotors/ws/eB...category=33554
I believe that's the VG30E(T) engine. Don't quote me on that though. Apparently they only flow 160cc/min NA and 259cc/min Turbo, so I'm not sure how much of an upgrade it would be to go with those. However, you could always look at what the Z guys are doing for upgraded injectors and follow suit.
THAWA is offline   Reply With Quote
WTT: PA: PE850cc Side feed injectors for stock side feed injectors + $100 wkderf Tri-State Area Private Classifieds 7 09-19-2010 09:17 PM
STI Yellow Side Feed Injectors -- Flow Rate?? A Mystery it seems.. gomba Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 09-28-2009 07:18 PM
WTT My stock yellow side feed sti injectors for your stock wrx side feed injectors president_douche Engine/Power/Exhaust 2 05-17-2009 12:42 AM
how-to mod STI side feed injectors for Higher flow?? WRXINTX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 23 04-07-2007 06:00 PM
F/S Perrin high flow fuel rails for STI side feed injectors 99 cents eBay Ricowrx Private 'For Sale' Classifieds 1 10-19-2004 10:32 PM
