Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 12-15-2004, 02:58 PM   #1
suby53
Member#: 59648
97' Legacy Outback
Question Phase II?
I have a 95' impreza with the 1.8L running 9 lbs. through a t04b. Well the pistons and rings are finally worn out and need to be replaced. I have a 93 2.2L na block that I want to rebuild for this setup. My question is do the legacy turbos come with forged internals? And if so then will they work in a 2.2 na block? I only plan to run 15 psi max on race gas so I don't need the closed deck block, just the strength of the rods and pistons/rings.
suby53 is offline   Reply With Quote
Old 12-17-2004, 03:57 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
The EJ22T rods and crank are forged, but so are your stock EJ22E ones. The pistons are not forged, but are moly coated. If you do a search in the conversions forum, there is a thread called "this should be the last EJ22T thread" that contains links to everything you could want to know about that engine. Much easier than searching every single thread with EJ22T in the content. You search button works, right?
Phase Ii 5-spd Engine Phase Ii Auto Engine, Is There A Difference??? Jlynch24 Normally Aspirated Powertrain 5 12-19-2009 03:30 PM
99 Phase II ej22 into 99 Forester Phase II ej25 subiman2005 Forester Forum 2 10-18-2009 11:39 PM
Headgasket VS. Phase II EJ25 to Phase II EJ22 swap- "Simple"? 99legacyL Newbies & FAQs 0 03-01-2008 05:09 PM
Ralli Spec says I have a Phase II block with Phase I heads? Have you investigated? MY99 2.5GT Legacy Forum 3 05-22-2001 01:17 AM
What engine block do I have? Phase I or Phase II? MY99 2.5GT Legacy Forum 7 05-04-2001 12:21 AM
